Old 1st October 2014, 16:01   #301
Thanked: 7 Times
Default Re: ICE for Innova
Separate usb cable having female connector from back of car player is there.
Update : if I connect iPhone with lightening connector to this usb cable, everything is fine. If connect usb flash drive, then also it works. But my iPod doesn't work. Well I see all controls on HU and song being played only audio is not heard. My iPod is touch 1st gen having 3.1.3 software.
One suspect is cable from JVC is not compatible.
dineshnan is offline   Reply With Quote
Old 1st October 2014, 18:42   #302
sridhu's Avatar
Thanked: 1,116 Times
Originally Posted by DerAlte View Post
That Sony is better than a Sumoku, but not by much. Definitely not in the same league as a powered Blaupunkt or JVC.
Underseat powered subs neither go low nor loud. They do give a feeling of bass, slightly less than that of a pair of good 6x9 coaxes.
If you buy a powered sub - underseat or regular - it becomes a must that at least the front components are amped. Otherwise, it will be as before that bass overpowers other frequencies - difficult to tune. If you have a 4 channel amp, you can get the Polk 8" (with box; unpowered passive, sealed box) underseat subwoofer, and power it by a bridged pair of channels from the amp.
What set up would you recommend, @derAlte?
- Amp: 2 channel? 4 channel?
- Front components
- Rear?
- 3rd row (mine is a 7 year old innova)?
- Sub woofer - active or powered from the amp?
The dealer throws up a lot of BS about class a, class ab and class D amps. Monobloc etc.
Please let me know what set ups I should audition. (LIke I said, I am a noob at this)
Thanks a ton.
PS: My HU is a Pioneer DVD unit. Quite happy with it.
sridhu is offline   Reply With Quote
Old 6th October 2014, 14:38   #303
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by dineshnan View Post
... Update : if I connect iPhone with lightening connector to this usb cable, everything is fine. If connect usb flash drive, then also it works. But my iPod doesn't work. Well I see all controls on HU and song being played only audio is not heard. My iPod is touch 1st gen having 3.1.3 software.
The Aux-in part (red/white/yellow) is incidentally in the same cable, but that is nothing to do with the USB part. The USB part is working properly. Nothing wrong with your iPod Touch either.
I suspect it is the cable that you are using between the iPod and the USB female connector on the JVC cable. Borrow another cable and check. Apple protocol is unchanged for playing media, so it is only the cable that might be at fault.
Originally Posted by sridhu View Post
... - Amp: 2 channel? 4 channel?
- Front components
- Rear?
- Sub woofer - active or powered from the amp?. ...
The dealer is giving sales spiel, and wants to sell what he has. Ignore.
* Amp: Get a 4 channel Kenwood M846 or JBL x646 - will suffice your needs. 2 channels for driving front components, 2 channels bridged to drive a sub. Less than 6K
* Front components: Audition Infinity Ref, JBL, Polk, Morel, Boston, etc. and decide which one you like. ~6K
* Rear (doors) - round coaxials of same model series are front components. ~2-3K. Drive these with the *front* channels of the HU
* Rear (3rd row) - 6x9 ovals - JBL, Infinity, Polk, Pioneer etc., mounted on hatch. ~3-4K. Drive these with the *rear* channels of HU
* Alternately (no coaxials on rear doors), mount a pair of 6x9 ovals in boxes, and keep them below the rear seats (2nd row), driving them with the *front* channels of the HU
* Get a Polk 8" sub in sealed box (prefinished Polk box) and keep it below either of the front seats. Drive it with the bridged rear channels of the amp
DerAlte is offline   (1) Thanks Reply With Quote
Old 17th October 2014, 22:45   #304
Thanked: 11 Times
HI ,
I planning to book a GX and looking at options for a good double DIN music systems. My requirements are.
1) max budget for HU is 15 to 18 K.
2) It should be a touch screen DVD one.
3) Should support the latest music file format.
4) Should support USB etc.
5) Should be compatible with reverse camera.
Also suggest a good place to buy and install in Bangalore.
Gopi
shalini_g is offline   Reply With Quote
Old 18th October 2014, 15:06   #305
Thanked: 11 Times
Originally Posted by shalini_g View Post
HI ,
Gopi
Can some one give some suggestion ?
Old 18th October 2014, 17:19   #306
Thanked: 389 Times
Try JVC KW AV50 , thats what I had , I got it from the showroom at the time of delivery , I don't remember how much I payed for it exactly. It does suit most of your requirement , do check on the price part once.
girimajiananth is offline   Reply With Quote
Old 13th March 2015, 11:41   #307
I have the stock ICE on my three year old Innova VX which I plan to replace now. The sound from the stock system and speakers was barely OK, and I could not connect my IPOD or Pendrive to this system. However, I bore with it till now but to avoid any problems with the warranty. Now that the warranty period is over, I would like upgrade this system. My budget is about 50K, and I listen to soft music (mostly movie songs and bhajans) - nothing loud.
I am thinking of going in for a 2-DIN system which will have bluetooth inputs for my IPOD / Phone / USB stick. I will not watch movies on this screen, but I would like it to have good resolution for me to read the menus easily. I also wish to connect a reversing camera to this system.
Ideally, I would like to continue to use the audio controls provided on the steering, but this is not a must - I can live without them.
I request the advise of the gurus on how I should proceed with the upgrade. Will changing the Head Unit alone make some difference to the audio quality or should I look at changing the stock speakers (which I understand are very basic) as well? Since I only listen to soft music, should I consider installing an Amplifier or will the HU alone suffice? Any recommendations on the Head Units / Speakers /Amp would be welcome.
One more advice I would be thankful for. Is it OK if I get this upgrade done at a Car Accessories shop, or should I look at going to a specialist in car audio systems? I live in Hyderabad but I do travel quite a bit to Bengaluru and Mysore. Any recommendations on where I can get this done in a proper and reliable manner? Thanks.
vartakavi is offline   Reply With Quote
Old 18th March 2015, 23:51   #308
Thanked: 157 Times
I have gone through an upgrade on my VX (Speakers, HU). My suggestion is to first upgrade speakers to components on first a) just the front and then b) all 4 doors. (I have infinity 7xx reference speakers). The c) step is to upgrade the HU d) is to get an amp and subwoofer. Do it step by step and stop where you feel satisfied!
My suggestion is to try the Toyota service center or someone else recommended by them (a 10-15% extra charge is little compared to lifetime peace - you can always ask the dealer to fix things (fear of escalation to Toyota) but the accessory walah will very quickly look the other way.
Buffetfan is offline   (1) Thanks Reply With Quote
Old 19th March 2015, 06:31   #309
Thank you. So far, I have been going to In Decars in Banjara Hills for my car's accessories. They in fact have a shop inside the Toyota Dealership in Madhapur.
I have two reasons to replace the HU - one is as a monitor for the rearview camera and the other is to get Bluetooth hands free facility for my mobile.
May be I can look at doing this step by step, starting with replacing the HU and only the forward speakers. Then the rear speakers, then an amp. I probably will not need a sub-woofer at all.
I heard good things about Infinity speakers. Will certainly look at them. Could you please tell me how much you paid for a pair of Infinity 7 series component speakers? Any suggestions on the HU?
Replacing our 2 lakh km Innova - Toyota Innova Crysta vs Ford Endeavour icyspikey SUVs, MUVs & 4x4s 31 16th May 2017 18:48
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
Innova'tive Interiors :D (My Mica Grey Innova with Refreshed Interiors) Bhushanrulz Test-Drives & Initial Ownership Reports 45 26th July 2011 00:48
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Budget ICE for INNOVA sudheerys In-Car Entertainment 17 20th October 2006 10:14
