Closed Thread
Old 12th December 2007, 15:07   #1
achopraa's Avatar
Thanked: 104 Times
Unhappy Settings gone after removing HU and removing key
I want to know if the below phenonmenon is normal.
I recently installed a SONY HU (CDX-GT660US).
I had set the clock and also saved other settings.
Now when i remove the Head Unit and Remove the key of the Car, all the settings get washed away and the clock is also RESET.
Is this normal? If not how can i retain my clock and other settings.
achopraa is offline
Old 12th December 2007, 17:36   #2
Thanked: 46 Times
Not sure about other settings but the clock gets reset. I experienced the same with my GT560. But anyway, there are'nt too many settings in these HU's, apart from one or two custom equalizer settings, and some minor ones in the setup.
anuragn is offline
Old 12th December 2007, 18:15   #3
Thanked: 16 Times
What do you mean by removing the HU? :
speedzak is offline
Old 12th December 2007, 18:23   #4
achopraa's Avatar
Thanked: 104 Times
Talking
OOPS...sorry...I meant the Mouth of HU.
achopraa is offline
Old 12th December 2007, 18:45   #5
iceman91's Avatar
Thanked: 22 Times
the wiring for the battery constant and the ignition has been interchanged just get that corrected. would take 2-3 minutes
basically there is one wire which is connecte dto your battery and this retains memory in the system and one goes to ignition. they have to be swapped
iceman91 is offline
Old 12th December 2007, 19:50   #6
rohan_fonseca's Avatar
Removing the whole HU or just the face plate??
rohan_fonseca is offline
Old 12th December 2007, 19:57   #7
spadival's Avatar
Thanked: 15 Times
Go with what ICEMAN91 has suggested. I am sure its because the wires have been wrongly connected.
I have a different problem.. I cant eject the CD unless I remove the faceplate !! Is this like a safety feature in Sony HU's ?
spadival is offline
Old 12th December 2007, 20:35   #8
achopraa's Avatar
Thanked: 104 Times
Hey bro....Do u have a flip-down kinda HU or the normal kind?
achopraa is offline
Old 12th December 2007, 22:18   #9
ram_hyundai's Avatar
Thanked: 48 Times
the guys at the A S S is also not familiar with the wiring of the i10.excuse them for their ignorance and like a guru in the field ask them to reconnect the wiring.it may help on their future installations also.feeling proud to be a part of the TEAM.
ram
ram_hyundai is offline
Old 13th December 2007, 03:46   #10
the yellow and red wires are connected the other way round buddy..(+12V & ACC)
saintsinner is offline
Old 13th December 2007, 11:12   #11
spadival's Avatar
Thanked: 15 Times
You need to flip down to remove or put the CD in. I guess thats the normal one.
spadival is offline
Old 13th December 2007, 11:16   #12
iceman91's Avatar
Thanked: 22 Times
check the alignment sometimes if the slot does not match the HU and the face plate so just check that id brand new try to get replaced underwarranty or it could be just a fittign issue adn needs to be "adjusted"
iceman91 is offline
Old 13th December 2007, 11:41   #13
achopraa's Avatar
Thanked: 104 Times
Post
The one in which you the falce plate comes down and then u put the CD is called the flip down.
The other one is where the face plate has a slot for inserting the CD
achopraa is offline
Old 15th December 2007, 20:22   #14
achopraa's Avatar
Thanked: 104 Times
Default Its working....
Thanks to one and all for helping me out.
I confidently went and asked that person to swap the wires...
and voila....it works...cheers:
achopraa is offline
Old 15th December 2007, 22:18   #15
iceman91's Avatar
Thanked: 22 Times
..........cheers.......
iceman91 is offline
Closed Thread
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
Removing key scratches from a car? FaeLLe Shifting gears 41 20th July 2016 17:27
Windows vibrating & making noise after removing Sunfilm amolbh Technical Stuff 9 20th January 2014 22:59
Oil check light glows in 118NE, AFTER removing key adhiraj Technical Stuff 4 31st August 2010 21:39
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
