Old 13th December 2007, 18:17   #1
Default ICE FOR MY i10
hey guys my budget is very low arnd twenty thousand buck for my ICE.
a normal configuration with..
1.amplifier.
2.cd/mp3 player 1din good mp3 quality.
3.sub.
4.speakers front/rear .
with a good sound quality an heart pounding bass.please mention the model no.and brand of the products..
help me out...
navin00 is offline   Reply With Quote
Old 13th December 2007, 20:36   #2
Magma's Avatar
You have a decent budget
well the audio gurus here will definetley give you sound advice
my newbie suggestions
HU
Pioneer 5950HU grey - 5500-5800rs
JVC -KD g634 about the same cost ( i think cheaper)
front component speakers : Illusion EL6.1 ,JBLGTO607,Blaupunkt Veloctiy172 , Hertz Dieci i think DSK 130/165 - approx 6000rs
rear speakers : Ground Zero GZ 6*9 , JBL 937 , hertz DCX 690 ( a bit expensive) Blaupunkt ( new series called ODX)
Amp
kenwood 4 channel KAC 8401, Pioneer 6300F ,JBL CS60.4 ( i heard the repalcement of this amp is better) or Blaupunk GT4 - grey mkt 5500-6000 and with bill about 7K
there youve crossed your budget!
Magma is offline   Reply With Quote
Old 14th December 2007, 14:07   #3
montyguru's Avatar
Cool
1.amplifier.
3.sub.
help me out...
20k is not a very low budget.
take a basic HU around 5-6k
take a 4-channel amp around 7-12k and a pair of front components around 6-10k
take a ported enclosed sub, jbl or blau or a base tube.
if you want heart pounding base, then consider a mono block amp dedicated to the sub and a 15" sub, or 2x12" or 2x10". for this you have to raise your budget.
montyguru is offline   Reply With Quote
Old 14th December 2007, 14:57   #4
vebmetal's Avatar
Thanked: 15 Times
The GT4 is available with B&W for Rs. 6,000 - 6,300. I don't think you can get Blaupunkt in grey.
Also, when people recommend amps they should mention a caveat that decent wiring would run the person 2.5K to 3K. I know that's something that shocked me, and threw off my budget, but generally someone new to ICE would not know that the wiring itself can be so expensive. Ditto for damping.
vebmetal is offline   Reply With Quote
Old 17th December 2007, 14:45   #5
Default Matching System
Hey guys i appreciate ur views..but i want best matching system according to sound output as u know my budget 20k...help me out
Old 17th December 2007, 16:34   #6
CrAzY dRiVeR's Avatar
Thanked: 16,769 Times
What kind of music do you listen to?
Old 17th December 2007, 17:07   #7
Bass&Trouble's Avatar
Thanked: 71 Times
Hook up with some Kolkata Bhpians willing to give you a demo. Lots of guys running good systems.
Old 17th December 2007, 17:12   #8
sucka's Avatar
HI ,
20k is a pretty decent budget to start with,
i think you should check this out
http://www.team-bhp.com/forum/ask-gu...k-25k-30k.html
you must go in for
A good HU (with 3RC out) : a good Pio will be around 5-6k
A pair of front Comps : Hertz DSK series/Jbl/Illusion 5.5-6k
A pair of rear Co-axials : Hertz DSK series/Jbl/Illusion 4-5k
sucka is offline   Reply With Quote
Old 18th December 2007, 12:42   #9
manojgautham's Avatar
Thanked: 11 Times
20k is very tight. You will have to extend the budget a little or go for some escond hand set.
Magma has listed out the prices very well. However that does not include a sub and you said you wanted it.
manojgautham is offline   Reply With Quote
Old 18th December 2007, 14:31   #10
Default Components speakers dilemma..
hey guys what does the components speakers delivers?
1)good crispitality
2)good bass.
3)is that necessary to hook it up with amp as there is not much space in the front gate to deliver good booming sound,is that good to spend in components...?
4)what if i go for front co-axials whats the diff in the output.
5)can i connect a 4ch. amp to both components and subwoofer,does this compromise sound quality..
Old 18th December 2007, 15:23   #11
groom's Avatar
Thanked: 187 Times
i got a system fitted for my i10 ...
there are big issues with mounting the system in i10 ... read through carefully ...
1) Door installation - Instalaltion dept is too critical ... so if you are expecting a bigger speakers to fit ..then gone... you will be dissapointed
2) Door installation will also give some vibrations
3) Mounting the head unit - u gottu remove a tonne of components and fit the unit - my suggestions is get a 2DIn system and fit them by an expert who has already done an installation for i10...this head ache is similar to verna
4) If you are an ardent fan of ground thumping bass with limited resource then without thought head for a plank and place your three way or way way speakers in the dickey
for a pricey and classy installation
1) take thin line series speakers and install them in the doors
2) use an amp and redirect the low freq to a bass tube at the rear
3) component output can be installated just above the hand rest in teh front door .. will send pictures of my installation soon ...
the system i installad in my i10 - Blaupunkt London Mp37 Head unit,
Thx - 672, thin line series in the front (with component output), THc 172 at the rear ...
strictly should be done by someone who has already fitted the system in i10.. else your car will go for dogs ...
groom is offline   Reply With Quote
Old 18th December 2007, 21:42   #12
Magma's Avatar
1)good crispitality
2)good bass.
Component speakers come as a total set of 4 speakers ( 2 midrange/woofers that are mounted in the stock location and 2 small 1" tweeters which have to be mounted seperately by cutting either the door panel or the a pillar or the dash). the woofers delivers mid and low frequencey sounds and the tweeter deliver higher pitch-
Now these speakers are crisper than regular co-axial speakers.
However if you not so very particular about the music quality then car co-axials would do for a layman. i mean i was happy with them in my old car.
Listen to a regular co axial setup if you are happy then go for them.
( also remember that the component speakers will reguire cutting into panels of your car)
Yes component speakers perform better with an AMP. You truly appreciate them with amp.
However there is nothin wrong if you dont use one.it just boils down if youre willing to spend, cause with an amp will come the AMP wiring cost which will set u back by 2-3 thousand rs
if you go for front co axials sound quality will differ a bit
to a begginner i dont know how much difference it will make, so i suggest you hear a setup with co axials , if your happy you can go for them
Yes you can use 2channels of a four channel amp to drive the front component speakers and then bridge the other two channels to drive your subwoofer
Your rear speakers if any can be driven by the HU itself.
i suggest if you are a layman and dont want a sub just go for good rear triaxials that offer good bass
Brands like ground zero , lightning audio and JBL GTO937 to some extent
Old 18th December 2007, 22:18   #13
montyguru's Avatar
Smile component speakers
1)good crispitality
2)good bass.
a component set is basically 2 or 3 speakers which are wired through a crossover. the crossover divides the frequencies, so the high frequencies go to the tweeter, the mids to the mid range, and lows to the mid-bass.
if you have a hi-power Head Unit with 18w RMS or typically a 55x4, you can run components directly too.
there is a difference in clarity and soundstage, which is more substantial if you amp them. the components will give you flexibility to fix tweeters where you like them to be.
booms are best left to subwoofer, which you won't be able to fit in "the front gate" coz there might not be enough space.
you can use a 4 channel amp for one pair of components and one woofer.
Old 18th December 2008, 11:24   #14
Default ICE and my i10
Guys,
I am getting a new i10 net week and am totally confused how to go abt it.
Have gone over the messages and replys posted here and got familiar with some basic stuffs so that I now at least know what people talk about.
Now my questions -
1> I know stuffs are cheap in grey market.. But how cheap? They dont give any bills or warranty and I dont personally know any installer to be sure that he will do everything right. So is it advisable have the dealer fit the ICE in??
2> My budget is 15 - 18k and what I need from it is a nice SQ and clarity, I like to increase the bass and trebel on the music I hear. Other stuffs apart from MP3, WMA etc is that I want is bluetooth, USB and Aux in.
From all the messages I read here I inferred that Pioneer is better than Sony. How true is that?
3> Do we have models in pioneer which has Bluetooth along with USB and Aux in
4> I have the following two Quote .. One from the car dealer and one from some other guy -
From Car Dealer --
Sony HU with BlueTooth and Aux in - 8990/-
JBL 652 - 3000/-
JBL S 396 - 4500/-
Speaker plank - 1500
Total Cost -- 16000/-
The other quote -
Front speaker sony component - 3490/-
Rear speaker JBL GT-5-963 - 3950/-
Plank - 900/-
Total cost -- he's ready to do it in 17000/- with bill and warranty
Which is a better configuration ?
Can you guys suggest something better than this in the same range?
~rahul
rahul95ee17 is offline   Reply With Quote
Old 18th December 2008, 12:04   #15
navin's Avatar
Thanked: 3,885 Times
From Car Dealer --
JBL 652 - 3000/-
JBL S 396 - 4500/-
The other quote -
Plank - 900/-
Most car dealers are more expensive that good car audio dealers. Pioneer HUs have been less troublesome than Sony HUs and lastly very few on TBHP favour Sony speakers over other brands.
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
All i10 & i20 owners, I need feedback EDIT - Booked i10 AT Asta Tejas@perioimpl Hatchbacks 89 12th October 2011 14:58
Vista safire aura , punto1.2 active, i10 magna kappa1.2,ritz lxi. EDIT : Booked i10! anusha_snh Hatchbacks 66 25th October 2009 16:43
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
