Old 18th December 2007, 13:27   #1
arunkumar_rec's Avatar
Default FM radio signal amplifier- is it available?
I am in Mysore. If I want to hear FM stations of Chennai or Coimbatore, it is not possible. Is there an amplifier available to amplify the radio signals?
Thanks.
Arun
arunkumar_rec is offline   Reply With Quote
Old 18th December 2007, 13:40   #2
tsk1979's Avatar
Thanked: 16,420 Times
Go for a bigger antenna.
you get an extendable windscreen antenna. which can go upto 2 meters wide.
Old 18th December 2007, 13:45   #3
Tanvir, Correct me If I am wrong. Longer the antenna there are more chances that it will start dancing heavily when the car is moving and will hit the roof very often. And also wont it look odd to have a 2 metre long antenna.
Please clarify.
Thanks.
Arun
Old 18th December 2007, 13:46   #4
Technocrat's Avatar
Thanked: 2,589 Times
Tanveer is this the one whihc is mounted on roof i.e. something like what comes with Getz & Swift ? How much does it cost ?
Old 18th December 2007, 13:48   #5
@Technocrat, I am having a Getz with this antenna as a default. But it doesn't help.
Old 18th December 2007, 13:59   #6
tsk1979's Avatar
I am talking about this
FM antenna should be horizontally mounted on windshield. Normally the stock antenna is very small, and therefore needs strong signal. With the above antenna(which is a modified version of that Old time V antenna from TVs) you can get good reception even when the signal is low.
Old 18th December 2007, 14:08   #7
Tanvir, does this need any special attachments/modifications? Looks like you are using the modified antenna.
Old 18th December 2007, 14:51   #8
tsk1979's Avatar
I am not using modded antenna. I am using the stock one. This I saw in a taxi. It actually sticks to windshield, but in this case its fallen.
No mods needed. Just stick it to windshield. In the city you can keep it short(arms not extended), to get better reception you can increase the arm length.
Old 18th December 2007, 14:55   #9
Technocrat's Avatar
Aargh cant view pics due to office proxy :(
Old 18th December 2007, 15:00   #10
PatienceWins's Avatar
Thanked: 284 Times
Great. Any idea where can I get it in Bangalore, the installation and the cost?
PatienceWins is offline   Reply With Quote
Old 18th December 2007, 15:03   #11
Su-47's Avatar
Thanked: 94 Times
tsk, What is that red colored LED doing in the antenna?
Su-47 is offline   Reply With Quote
Old 18th December 2007, 15:22   #12
tsk1979's Avatar
Try the budget accessory shops
Giving out red light?
Old 18th December 2007, 16:23   #13
Su-47's Avatar
Thanked: 94 Times
I meant to ask if its presence is related to antenna in some way. In other words, do you know if the antenna is a powered one (with LNA). It appeared excessive to route a supply cable to just glow the LED for a passive antenna.
Old 18th December 2007, 16:35   #14
tsk1979's Avatar
Its a passive antenna, the LED is for "show".
If you get a passive antenna of size closest to your required frequency, you will not need boosting and you can catch FM even 100kms away.
for example the Aveo antenna can catch FM beyond Karnal, however in case of my indica, the small antenna gives up around Sonepat.
Old 18th December 2007, 22:02   #15
montyguru's Avatar
Smile FM booster
Thanks.
Arun
hi. there's an FM booster available for 900 rupees. i have ordered one. if it is satisfactory, i'll inform you. company claims a 35 dB gain, clear reception is areas of poor signal and a CD quality sound. though i don't think that'll enable you to catch chennai or coimbatore signals. i think FM broadcasts through local stations and not the satellite - does anyone know how FM is broadcast?
montyguru is offline   Reply With Quote
The Amateur Radio (Ham Radio) thread bejoy Shifting gears 102 11th October 2017 10:43
Radio Auto Launched! Radio TUK TUK RW9763 Street Experiences 2 24th November 2010 15:17
Radio signal Problem in ALTO navin00 In-Car Entertainment 7 13th September 2008 15:42
