Old 13th November 2008, 12:54   #226
Thanked: 41 Times
guys.. any updates on the OBD scanner?
monty9991 is offline   Reply With Quote
Old 18th November 2008, 11:54   #227
gigy's Avatar
Thanked: 41 Times
Spadival,
Are you still with baleno if not whats the new car? were you successful in getting the data on to CF? will the cable from iride work out of the box, i will take some time to get back on car due exams. meanwhile got a usb radio but its not working. dont have time to research on it as of now.
monty9991, are you getting the cable made?
Old 20th November 2008, 14:48   #228
Thanked: 41 Times
well i have no idea to where to start .. just confused, but i really want to do this.
Old 20th November 2008, 15:04   #229
spadival's Avatar
Thanked: 15 Times
Originally Posted by gigy View Post
Spadival,
Still with Baleno. I am not getting the data onto CF. Currently, its only raw data that I am able to see on a com port monitoring software. Somebody would still need to code some software to request data and display it in human readable format.
Cable from iRide will NOT work at all. I bought this cable from a US website. Very expensive - But I bought it at a time when USD-INR exchange rate was a bit more favorable. If you know your electronics, you can probably DIY the cable yourself.
spadival is offline   Reply With Quote
Old 20th November 2008, 16:07   #230
gigy's Avatar
Thanked: 41 Times
that particular cable looks like its only wires and no electronic components in it. is it so? then its not a problem in making it. can also use bare pins for trial. as mentioned in the site did you get many free softwares along with it?
Old 20th November 2008, 16:24   #231
Thanked: 41 Times
well in an alot there are only 3 wires on the OBDII connector i.e. +ve, -ve and communication as mentioned earlier. so i guess i need only one wire from the OBDII port to the serial port connector as i dont need -ve and +ve for the pc.
now, on which pin does that comm. wire goes on serial port as there are nine pins on it.
how about baleno, is it the same 3 wire OBD II connector?
Old 21st November 2008, 13:39   #232
spadival's Avatar
Thanked: 15 Times
The connector on the Baleno has 16 pins instead of 9 that you have mentioned for Alto. So while the physical connector is OBDII compliant, the protocol and the wiring is not, because there are only 3 wires - connected to PIN 9 (data link), PIN 5 (GND) and PIN 16 (12V).
There are wiring diagrams on the web on how to build your DIY cable. But you should ensure that the signalling voltage and the baud rate required by the ECU is supported by your cable. All this was a bit beyond my current knowledge of electronics and so I decided not to fry my ECU with my half baked knowledge .
Old 21st November 2008, 17:00   #233
Thanked: 41 Times
and now at the end of the day we dont know what baud rare is required:(
hope we get up with something soon..
Old 24th November 2008, 17:44   #234
Thanked: 41 Times
guys i just found out that ALTO's ECU supports ISO or KWP protocol.
source :- OBD-II Hardware
so do i need to buy a scanner that supporys ISO snd KWP protocol?
edit: i have pin number 5,7,and 16 pinouts on the OBDII port
Old 25th November 2008, 18:09   #235
gigy's Avatar
Thanked: 41 Times
got this usb fm but still figuring out how it works. the software which can with it is useless. keeps crashing in xp and vista while setting ststions. anyone used this before. can you recommend any other software or driver for centerfuse.
The CarPC / Carputer Thread-001.jpg
Old 26th November 2008, 21:42   #236
Thanked: 41 Times
no idea about this but i wish we had satellite radio in India for cars.
Old 28th November 2008, 11:44   #237
spadival's Avatar
Thanked: 15 Times
Gigy, I had the same radio - PCear. I was able it get it to work on my laptop. Afraid there is no other software other than one provided. Funny, the software was pretty stable. Somebody was working on a driver for Roadrunner (not Centrafuse). If you search for PCear on mp3car.com, you should be able to find the thread.
Only problem I had was that installing it in the car didn't work out. The antenna is not good enough and there is too much interference from the LCD screen and I am not able to catch any station. Even the car's Head Unit's radio reception is better with the LCD switched off. I tried putting some DIY aluminium foil (as suggested on mp3car.com) behind the LCD screen to prevent the interference, but no use. So I just switch off the LCD if I need to listen to the radio
Old 30th November 2008, 17:06   #238
gigy's Avatar
Thanked: 41 Times
I lost the setup file for IRV-070BY VGA Touchscreen from iride. had to format the carputer today and then realized the cd is not traceable. if anyone has a copy of it please mail me at gigykarunan at rediffmail.com
Old 30th November 2008, 20:25   #239
smokin's Avatar
Thanked: 13 Times
Yup i have one saved in my computer will send it tomorrow as it's a 16 mb file and my home computer has a slow connection
smokin is offline   Reply With Quote
Old 30th November 2008, 23:29   #240
gigy's Avatar
Thanked: 41 Times
thank you very much for the file
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
