Old 22nd July 2009, 17:22   #406
gigy's Avatar
Thanked: 41 Times
A little showoff.
A comparison of old and new amplifier, almost half the size.
Old 22nd July 2009, 17:47   #407
Thanked: 41 Times
balupunkt looks clean and nice. for how much did you buy it?
monty9991 is offline   Reply With Quote
Old 22nd July 2009, 19:55   #408
DerAlte's Avatar
Thanked: 2,879 Times
The box says "Tod Phod"!? Did you buy this in India? How much?
Old 23rd July 2009, 10:19   #409
gigy's Avatar
Thanked: 41 Times
Got the amplifier for 14.5k.
Installed it yesterday night. initially i was disappointed with the output as it was considerably low in comparison to the older one but latter found it was a setting issue in pc.
Now it rocks and i am amazed by the power of this punny little thing.
More than enough for my kind of use. Also the noise which i had has gone now, mostly must have gone due to the relocation.
i have not yet connected the rear speakers as it is broken.have already disassembled it and converted it to components but thinking what to do about crossovers.
bass remote is also to be installed , too lazy to open up the panels. when the optical cable comes i will lay it down.
install picture.
Old 23rd July 2009, 11:55   #410
Thanked: 84 Times
Originally Posted by DerAlte View Post
Of course it has a touchscreen (it is a tablet). Whether finger or stylus depends on the area exposed by an application, i.e. button or link. Daylight visibility is not bad - touchscreen is not so reflective. Of course, LCD being back-lit, colours look washed out when in sunlight. Not so much of a problem in the car, unless you have sunroof open in bright sunlight!
Thanks for your response.
The confusion regarding the Touchscreen's capability arose because my old HP tablet doesn't recognize finger touch and invariably requires the special stylus (magnetic, I guess) very much like a digitizer pad. I hope Mileap is not crippled in that way.
Digital Vampire is offline   Reply With Quote
Old 23rd July 2009, 12:40   #411
itwasntme's Avatar
Thanked: 1,734 Times
WOW! The first time I saw it the price was 31K (when Asus Eee PC was 17K). Late last year it was 21K without OS. Now 15K with OS? That's a real good deal. The only problems you need to think of are:
1. How to mount it conveniently at hand (which car?)
2. How to power it from 12V line in the car, maybe from the cig lighter (you need to physically look at the AC converter to find out it's output voltage, then get a suitable DC-DC converter, or get a car inverter)
I was amazed by the price as well but couldn't find any catch in the offer. Further, I haven't come across any totally negative review on the Net about this particular model and most users (netsurfers/students)are happy with it.
I am considering it for my Aveo 1.4 which comes with a standard double-DIN slot. My main uses will be music (need to relocate my existing single DIN Kenwood HU or just buy an amplifier - I am not a huge music buff), and navigation (by buying a separate GPS receiver).
The thing is I would prefer to tamper as litle as I can with the MiLeap so am open to suggestions!
itwasntme is offline   Reply With Quote
Old 23rd July 2009, 13:35   #412
DerAlte's Avatar
@itwasntme, would you want to start another thread? We would be wantonly trespassing on @gigy's thread otherwise!
The MiLeap is too oddly sized to consider the 2DIN space. The display bezel is just too big. Even the front to back (depth) dimension is too large to think of a drawer like arrangement in the 2DIN space, where the MiLeap could be stowed / mounted transversely.
Your only hope is monitor mounts like these, especially the goose neck ones that will mount on a seat bolt of the passenger seat and can be bent away when not in use. A bracket on top of this could secure the MiLeap for normal use. All the wiring needed could then be run up the side of the gooseneck and held in place neatly with tie straps. When you want to carry away the MiLeap (for safety), you would be able to just unplug all the plugs and jacks (power, USB, audio) and just take it away. It is a convenient way to adjust its placement to your convenience.
Old 23rd July 2009, 15:36   #413
itwasntme's Avatar
Great advice, DerAlte! I was hoping for something exactly as described by you as I am not very technical minded and most of the DIY discussions have gone at a tangent :-) The PlugnPlay method sounds best and I can simply unplug and take the unit away.
Will certainly start a thread as soon as I chose between spending 15k for alloys or the carputer :-(
Old 23rd July 2009, 23:19   #414
srikant's Avatar
Thanked: 9 Times
If you don't mind my saying so, one needs to look at the real critical items: mobo, PSU, cabinet etc. before the peripherals. Or did I miss something? If the mobo that you select does not have an FDD connector (quite likely), that SSD will be a waste.
I am only in planning stage and doing some research on the same. Just posted em for your opinions. Will put up details once things are finalised at my end. I am doing it in collaboration with my friend.
Originally Posted by gigy View Post
SMPS12 is only 60w output capable, not of use for your kind of plan. i don't find automotive functions like wide input voltage, crank protection and amplifier thump in it. a unknown brand also. i think for these critical things you should stick with iride or import stuff proven, like in mp3.com. i dont think it will be any cheaper also.
Whats the plan with gsm antenna?
Have you got quote for the components?
Avoid converters for laptop hard disk and go for sata with lock or solid state DOM with good read/write speeds.
Which motherboard you are planning to use?
I am not as knowledgeable as you are in this field of computers and electricals. I am just googleing around to find more info and also going through thread of yours to learn some stuff before putting money to it. If every thing goes well i should be ordering for the components by August second week.
I am going to Kuwait for 10 days in between . So i ll have to plan things after i am back by mid of August. Will keep you all posted.
Your points noted. Planning to buy DC-DC converter from iride as you suggest.
Was thinking if i can use the GSM antenna to increase reception of mobile for net connecting using the same in the Carputer. That s because in Kerala we have bad reception for signals of all networks.
srikant is offline   Reply With Quote
Old 24th July 2009, 18:35   #415
gigy's Avatar
Thanked: 41 Times
Use of the HCL leaptop is a good option in the price it is available now. more good for chauffeur driven type where it can sit nicely behind driver seat. you got to give it power, audio and gps connection only. brackets for this is readily available. for front install little innovation of mounting will be required to give neat look.
My 6x9 split out. midbass is already installed back the tweeters are yet to go for want of how to mount it. plan to use metal paper clip glued behind it. if i could get a pair of crossovers it will be better stagged.
Old 25th July 2009, 13:16   #416
gigy's Avatar
Thanked: 41 Times
For those of you looking at umpc and Eeepc installs i stumbled upon these videos, thought might help.
Old 28th July 2009, 19:18   #417
gigy's Avatar
Thanked: 41 Times
I got this frame (ABS PLASTIC FRAME 629-701-Black) from bybyte.com with great expectation to make my carputer one single double unit but it went to become a total loss. the frame dosen't fit the lcd model IRV-070BY from iride. it is short by 2mm in height. in the process i have now damaged the connector on the lcd and its ribbon as well. after putting it back into its default case i have only white display, so time for new lcd.
The iride lcd panel is made by hitachi.
Old 28th July 2009, 19:36   #418
spadival's Avatar
Thanked: 16 Times
Oh no.. Check with Sheldon if he has a spare connector and ribbon from a broken LCD. He is in Mumbai as well.
No point getting a new LCD just because the old one needs some spare parts.
spadival is offline   Reply With Quote
Old 28th July 2009, 20:02   #419
Thanked: 13 Times
Wouldn't hurt asking sheldon for a 2 DIN frame solution. I believe he does them. He used to stock a kitted LCD with swift 2DIN console.
suneet_ag is offline   Reply With Quote
Old 28th July 2009, 22:53   #420
Thanked: 84 Times
Could you please throw some light on the brackets available to hold the HCL leaptop?
I saw the leaptop in Croma and seems like a good buy for the price and for basic carputer use. But it is out of stock since last 5 days. I guess @15K, there are lots of takers for the HCL Leaptop.
Has anyone opened up the Leaptop to see if the touchscreen is bonded to LCD or just a cheap overlay? I guess it is an India specific model and information about it is scarce.
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
