Old 23rd May 2010, 04:10   #631
frankmehta's Avatar
Thanked: 2,334 Times
A big HELLO to everyone guys!!
A few quick questions!!
1. Has anyone attempted Time Alignment and been successful at it? I have seen a LOT of information on mp3car.com, but would love it if someone from Team bhp has actually got time alignment done in his car pc.
2. How many people are actually using Centrafuse 3.0 for sat nav? I have the Nav version, but I don't know where to buy (?) the ALL INDIA maps from. Which sat receiver to use? I think GlobalSat BU353 with SirfStarIII chipset is fine. Please advice.
3. Which is a NICE keyboard + trackpad solution available in India?
4. Which OBD protocol does my Ford Fiesta 1.6 Petrol support? Which scanner to get? Will I be able to LOCK DOORS, OPEN AND CLOSE WINDOWS etc when I sync my car pc with the ECU using the OBD?
5. Which MINI ITX/MICRO ATX cabinet would you advice? I intend to have a lot of components going in, so the ventilation must be good. Size wise, it should not be too large even!
6. How does one pair a mobile? With a bluetooth dongle, I know, but how does one manage the microphone? If it is on throughout, it will give constant feedback in the speakers. Is there a software feature in Centrafuse to switch on the microphone when there is a phone call, and back off when there is none?
7. Do we need to place a fuse between the battery and computer?
more questions soon, I am sleepy ;-)
Old 23rd May 2010, 15:12   #632
ghpk's Avatar
Thanked: 193 Times
I am not running a car PC yet (not able to get LCD) but i've few things which can help you.
3). use as small as possible keyboard for that extra comfort, one designed by lenovo specifically mentions carputer,
5). use a Acrylic sheets, and get a cabinet designed which best suits you.
you'll easily be able to drill holes to fit your equipment, especially using 2-3 FANS would be easy this way.
you would also be able to mod this cabinet with more space management by sticking Nuts anywhere using epoxy(Araldite) and then fix your extra part to it.
Another option which would look cool but with a little bling would let you have a see thru CPU, L.E.D. chassis fans would let you instantly know if they are working or Not.
6). you'll be able to make use of centrafuse and mic will come on only on calls.
7). A fuse is a must, Although a fuse would be in DC-DC power supply board but a fuse near the point you bring +ve from, will certainly give you an extra protection. A extra step would ensure you don't damage your car wiring as power would cut in case of mishandling from under bonnet fuse itself.
Old 23rd May 2010, 16:02   #633
frankmehta's Avatar
The Lenovo one is pretty expensive! I was looking at the Reliance Kiosk ones with the trackball!
I can arrange for something like that!
That is good news!
What amperage fuse should one use?
ONE MORE QUESTION:
Are the rear view cameras available in the market capable of switching inputs automatically on LCD screens when the car is put into reverse gear? OR are the LCD screens smart enough to switch to another source when they sense a signal on the other input?? Asking this as I don't want to get a reversing camera that needs sources to be switched to and fro manually. It will not serve it's purpose.
Old 23rd May 2010, 16:42   #634
ghpk's Avatar
Thanked: 193 Times
I think using a 15-20 Amp fuse would be OK.
Camera switching will hunt something and update you later.
Old 23rd May 2010, 19:30   #635
frankmehta's Avatar
eBay India: holux M-1000C Bluetooth GPS receiver (item 270581760737 end time 27-May-2010 17:22:51 IST)
IS this a better bet than the traditional GlobalSat Bu 353?
Old 23rd May 2010, 22:23   #636
frankmehta's Avatar
ONE more from me, CAN CENTRAFUSE be CONTROLLED via an MCE remote?
Old 24th May 2010, 01:17   #637
nisarg86's Avatar
Thanked: 12 Times
Frank. CF can not be controlled via MCE remote. CF uses Hotkey such as Ctrl+Alt combination.
I am going to try that soon.
You can buy the maps from Satuguide.in Go for BU353. Lots of folks on MP3car uses BU353 including myself. Tried and tested.
I ordered mine from Welcome to Usb.brando.com and it is working fine.
I am yet to TEST OBD with carpc. probably in next car. Swift D is not supporting any commercial OBD scanner.
I would say go for DIY. Acrylic case would looks nice. but acrylic would take RFI as oppsed to Metal case. You can get the mo-co-so case with 1x expansion slot.
Yes. CF will manage it everything. CF will mute the MIC whenver it is not in use.
Yes. 15A would be good.
nisarg86 is offline   Reply With Quote
Old 24th May 2010, 09:36   #638
Thanked: 41 Times
4. I dont know if any ODBII scaner works with ford cars, but even it does it wont be able to lock the doors or roll up or roll down the windows etc. IMO
5. IF you like DIY then make your own of Acrylic sheet and you can out some leds inside to make it glow. or buy it off iride.in they have a discount avalible on these cases on MRPs.
7. Yes, fuse is must. because you will be running +ve wire direct from the battery to the PSU.
you can come up with as many as question you want TBHP's DIY section has all answers to them
monty9991 is offline   Reply With Quote
Old 24th May 2010, 21:50   #639
StreetAddict's Avatar
Thanked: 45 Times
There are specific models which allow the auto-switching feature. They switch to the AV2 input when a 12v signal is supplied to them.
IRV-070GL VGA Touchscreen*-*iRide Technologies
In other ones, you would manually need to select the AV2 when switching to rear view camera.
StreetAddict is offline   Reply With Quote
Old 25th May 2010, 00:16   #640
nisarg86's Avatar
Thanked: 12 Times
Yes. There are 3 wires attached with LCD. you need to connect them with reverse light wire. When you slot in your reverse gear LCD will automatically switch to AV2. and when you slot back to neutral or any gear, LCD will display VGA (PC Input).
Old 25th May 2010, 19:40   #641
frankmehta's Avatar
Guys, which is the BEST reversing camera available??? I want one with GOOD resolution and infra red nightvision.
Old 25th May 2010, 20:10   #642
frankmehta's Avatar
Rearview Reverse Camera for FORD MONDEO FIESTA FOCUS(2C - eBay (item 250636796751 end time Jun-20-10 02:16:17 PDT)
This one just has me sold! Any way to get these cheaper in India?????
W CAR REAR VIEW REVERSE CAMERA WIDE ANGLE NIGHT VISION - eBay (item 330425822772 end time May-25-10 21:47:29 PDT)
This one looks like it has IR LED's which might help at night. Looks more practical and more robust than the above link.
Please advise.
Old 25th May 2010, 20:21   #643
ghpk's Avatar
Thanked: 193 Times
Frank you may also like this
Keyboard with Touchpad
Old 25th May 2010, 20:23   #644
frankmehta's Avatar
Thanks for the link mate. Looks good!
Old 25th May 2010, 21:21   #645
ghpk's Avatar
Thanked: 193 Times
can you share, have you purchased the LCD and DC-DC power supply yet ?
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
