Old 29th July 2012, 06:30   #766
lateshnair's Avatar
Default Re: The CarPC / Carputer Thread
anybody tried andriod pc setup in car with a touchscreen monitor? Need some info about the touch screen and gps drivers
Installing android on Intel PC platform is what even am trying to do for my carpc. I have not started on it yet. I will definitely share if I come across something useful.
Have you followed these steps to install ?"How to install Android or run as live CD on PC or Netbook"
lateshnair is offline   (1) Thanks Reply With Quote
Old 29th July 2012, 12:41   #767
gigy's Avatar
Thanked: 41 Times
I need the display powered to use reverse or when i need to connect the tv out feature from mobile phone when the pc is not ON. I had used a physical switch to control power to pc when required.
Don't want to use a pc platform in android. looking to adapt something like this. this has hdmi out so cant connect with present display i have but can use a adapter in between.
http://www.detna.com/shop/gadgets/ta...-4gmini-tv-box
Old 31st July 2012, 23:56   #768
lateshnair's Avatar
Very tempting, is it available in India? Ebay India have no listing
lateshnair is offline   Reply With Quote
Old 1st August 2012, 03:01   #769
gigy's Avatar
Thanked: 41 Times
That site is Indian based in banglore. i have ordered raspberry Pi since vga and audio out feature was needed for me to use with existing equipment from same site. Will get in about two weeks time.
http://www.detna.com/shop/gadgets/ta...pi-sbc-model-b
Old 1st August 2012, 08:32   #770
lateshnair's Avatar
Awesome! However the review says its very slow but I would say big deal. For <3k this is very good.
Lets us know your experience with it and how you're planning to set it up.
cheers!
Old 1st August 2012, 09:46   #771
bhp_maniac's Avatar
Thanked: 90 Times
You can get it from dealextreme.com. Available for around 50$
bhp_maniac is online now   Reply With Quote
Old 1st August 2012, 11:57   #772
lateshnair's Avatar
Thanks bhp_maniac
@gigy - Did you check this -->
Android Ultimate In-Car OEM System - Remote Bluetooth Touch, HDMI Mirroring
This is impressive as well
Old 1st August 2012, 12:56   #773
bhp_maniac's Avatar
Thanked: 90 Times
Thanks bhp_maniac
Thanks for sharing. That seems to be the ultimate choice for in car integration of your devices
Old 2nd August 2012, 11:34   #774
I would go with Respberry Pi. With little working around with the software, it would make ultimate In-Car entertainment system.
I would still like to have some info on interface for OBD......like
https://play.google.com/store/apps/d...l.torque&hl=en
But this one for Android
shanks
myshanks is offline   Reply With Quote
Old 3rd August 2012, 21:36   #775
badboyscad's Avatar
Thanked: 153 Times
Does the Raspberry Pi have 4 channel audio output?
I guess the 3.5mm jack is only 2 channel.
badboyscad is offline   Reply With Quote
Old 4th August 2012, 08:51   #776
DerAlte's Avatar
Thanked: 2,876 Times
If you really want 4.1 sound, you should use an external USB-based sound card, instead of the buit-in audio. Most of the USB-based sound cards have Linux drivers.
DerAlte is offline   (1) Thanks Reply With Quote
Old 8th August 2012, 11:56   #777
DerAlte's Avatar
... couple of my friends kept complaining that their mobile car adapter kept getting damaged, infact one of them even got his phone damaged. Usually it gets damaged while cranking the engine, they said. ...
Perhaps they did not associate it with the fact that during cranking, the power to the Cig Lighter sockets is switched off! The only way the charger can get damaged is if it is a cheap, badly designed piece. Which might also explain a mobile going bad - if the charger is putting out a large spike when power comes on. Even then, I would disbelieve what was told. The most common problem is the charger not mating with the CL socket - comes loose sometimes.
... When the engine is not running why would we want to change to reverse. Infact when engine is not running, my ford's steering become hard like hell and brakes too( it becomes virtually impossible to use the brake when engine is not running. Ofcourse handbrake works.
I guess you need to explore your car a bit more.
- Yes, with engine off the power steering does not get power assist. Not required unless one is trying to do like Bangalore auto drivers - coasting down a slope with engine switched off
- Brakes will work, and properly - the brake system is not linked with engine running or not.
- One sometimes needs to use the rear-view cam with engine off. Typically, this is at a stop light with engine off, and one wants to check how much space one has behind to reverse the car if the guy in front is having a problem
Old 8th August 2012, 15:10   #778
esteem_lover's Avatar
Thanked: 445 Times
Raspberry Pi
gigy, how are you planning to mount it ? Any enclosure available ?
Old 8th August 2012, 15:27   #779
srishiva's Avatar
Thanked: 816 Times
Hope no one tries to coast with engine off to discover if brakes work!
srishiva is offline   Reply With Quote
Old 9th August 2012, 00:51   #780
gigy's Avatar
Thanked: 41 Times
I am waiting for the pcb to arrive. Will mostly pick up a diy cabinet from electronics market and liik to place inside the lcd casing.
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
