Old 9th August 2012, 01:02   #781
esteem_lover's Avatar
Thanked: 451 Times
Default Re: The CarPC / Carputer Thread
Originally Posted by DerAlte View Post
with engine switched off
- Brakes will work, and properly - the brake system is not linked with engine running or not.
Sir Mustache-ji ,what kind of car are you talking about here ? In my ever so humble experience, all the modern cars with "Power brakes" (which ones do not have ?), the brake system is linked with the engine running and "providing the power assist", right no, sirji ? Yes, the brakes WILL work without the engine running, only you have to stand on the brakes here.
Old 9th August 2012, 13:35   #782
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by esteem_lover View Post
Sir Mustache-ji ,what kind of car are you talking about here ? ... Yes, the brakes WILL work without the engine running, only you have to stand on the brakes here.
Sir john-ji, were you trying to contradict me, or were you trying to make the same or some other point? Though we are seriously OT in this thread:
- Rear brakes, drums usually, will work properly without boost
- Discs require vacuum-assist definitely, and vacuum comes from engine operation
- Most cars here have discs in front and drums rear
- If the car is on a 0-45deg incline with engine off, and is at rest, the rear drums exert enough force to hold it still. And, one doesn't have to 'stand' on the brakes (helps if one just pumps the brake pedal a couple of times)
- In the above case, if after the car comes to rest the driver switches off the engine and forgets to (or decides not to for whatever reason) use the handbrake or the brake ... hehehehe the design / technology shouldn't be blamed, since if the car is moving ->
- The behavior, and contribution from drums v/s discs, is quite different. If braking from, say, 50Kmph to 0, discs are more efficient / effective than drums. But, if braking from 10Kmph to 0 (with engine off), the drums are enough. No?
Q.E.D.!
Shall we get back to talking CarPCs, sir?
DerAlte is offline   (1) Thanks Reply With Quote
Old 9th August 2012, 15:03   #783
Thanked: 451 Times
Just pulling your mustache, lol.
I am hooked to this WELCOME - DETNA.
Some of these products are fantastic and uber cheap too, wonder if there is any kind of warranty on them !
All-in-one Car Bluetooth Rearview Mirror Kit (GPS, DVR, Wireless Camera and More)
Multi-Media Video Glasses (50 Inch Virtual Screen, 4GB Internal Memory)
Old 9th August 2012, 21:43   #784
lateshnair's Avatar
Perhaps they did not associate it with the fact that during cranking, the power to the Cig Lighter sockets is switched off! The only way the charger can get damaged
Hi DerAlte - Pardon me but I would like to disagree with you. I have ford fiesta and the cig lighter socket gets power all the time, no matter if the engine is running or not. Even during cranking the power to lighter is not switched off. Probably some cars might have that safety feature, which you're talking about.
I guess you need to explore your car a bit more.
I'm a noob when its comes to cars technical features but having said that I'm exploring it all the time and am learning faster here with team-bhp.
- Yes, with engine off the power steering does not get power assist.
- Once used to a power steering vehicle, it get quite difficult to switch back to a non power assist. In sudden situations when engine cuts off and if your vehicle is rolling back, it can get quite difficult. I have experienced it.
Not required unless one is trying to do like Bangalore auto drivers - coasting down a slope with engine switched off
I own a diesel car so I have not reached that stage yet to save fuel
Really? I seriously doubt that.
- One sometimes needs to use the rear-view cam with engine off. Typically, this is at a stop light with engine off, and one wants to check how much space one has behind to reverse the car if the guy in front is having a problem
Yes, agree with you, that's experience talking. Thanks.
Sorry for diverting the thread. Lets get back to carputer.
I'm going order this one and try it out. Until my carputer is ready.
Note from Team-BHP Support: Please use "multi-quote" option rather than posting back-to-back.
lateshnair is offline   Reply With Quote
Old 10th August 2012, 11:39   #785
Thanked: 451 Times
Will be waiting for your review.
Please call them and check for warranty and conditions if any.
Old 10th August 2012, 13:26   #786
srishiva's Avatar
Thanked: 933 Times
Man, I just ordered something from Detna. Within a minute, a guy calls and says if he can send it NOW !
They have cool products. Hope they work flawlessly
srishiva is offline   Reply With Quote
Old 10th August 2012, 13:38   #787
Thanked: 451 Times
gigy, how are you planning to mount it ? Any enclosure available ?
Originally Posted by gigy View Post
I am waiting for the pcb to arrive. Will mostly pick up a diy cabinet from electronics market and liik to place inside the lcd casing.
saw these pics on the internet, wonder if they are available in India.
The CarPC / Carputer Thread-side3.jpg
And here's one by a 12 year old girl using LEGO
The CarPC / Carputer Thread-286241.jpg
Think I should ask my son to design one too.
Old 10th August 2012, 14:36   #788
gigy's Avatar
Thanked: 41 Times
Lego looks best. Waiting for Bluedart delivery today.
Sd card is ready with xmbc for first trial. I might also go for that 5k rear view lcd with gps support for nav.
Old 10th August 2012, 15:47   #789
Thanked: 451 Times
One problem I see in this is that there are connectors on every side, hence a compact install may not be possible.
Old 10th August 2012, 22:12   #790
lateshnair's Avatar
This company have some amazing gadgets at decent price tag. Well not sure about the quality and warranty yet but it is sure tempting. Check this out 7inch touchscreen at just 4500rs
7 Inch Touchscreen LCD with VGA (In-car Entertainment, PC, POS)
Old 11th August 2012, 11:38   #791
Hmm looks interesting worth a try
shanks
myshanks is offline   Reply With Quote
Old 12th August 2012, 20:55   #792
DerAlte's Avatar
Hi DerAlte - Pardon me but I would like to disagree with you. I have ford fiesta and the cig lighter socket gets power all the time, no matter if the engine is running or not. ...
Oh, you most certainly may. But, cutting off power to all loads other than the ignition system during cranking (not engine running as you put it) is an automobile industry design standard, and I wouldn't expect Ford to have done otherwise. At the same time, I will not be surprised if they did the reverse. The only way one can get uninterrupted power is if directly wired from the battery.
... In sudden situations when engine cuts off and if your vehicle is rolling back, it can get quite difficult. I have experienced it. ...
Yes, does require some muscling, but if the car is rolling it is not that bad. At rest with engine off it is rather very difficult.
... Really? I seriously doubt that. ...
1. I explained above
2. Don't carry doubts, please do check and be aware
Old 17th August 2012, 19:35   #793
gigy's Avatar
Thanked: 41 Times
Got the pi and a small keyboard with track pad. cant figure out how to get touch screen working, so this will be in use for sometime.
The CarPC / Carputer Thread-picture-053.jpg
The CarPC / Carputer Thread-picture-055.jpg
The CarPC / Carputer Thread-picture-056.jpg
The CarPC / Carputer Thread-picture-058.jpg
The CarPC / Carputer Thread-picture-059.jpg
gigy is offline   (1) Thanks Reply With Quote
Old 30th August 2012, 03:09   #794
lateshnair's Avatar
Gigy - How did the setup go? Where you able to figure out how to get the touch screen working?
Old 30th August 2012, 11:00   #795
gigy's Avatar
Thanked: 41 Times
A silly mistake by me fried the Pi before i realized and its story ended in a tragic burn out. Pictures of final setup below and as you can see i used all black wires inside it, hence didn't realize the 12v and 5v lines got interchanged during final assembly. otherwise it was good in function.
Now want to try out Intel DN2800NT. need a compatible hard disk for it for slim mount to push it in the slot where the OBD port of Octavia exists.
Other idea was to use the amkette evo tv in car but want a model with 1gb ram.
The CarPC / Carputer Thread-img_20120823_085647.jpg
The CarPC / Carputer Thread-img_20120823_085701.jpg
The CarPC / Carputer Thread-img_20120823_085712.jpg
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
