Old 7th December 2012, 20:49   #826
gigy's Avatar
Thanked: 41 Times
Default Re: The CarPC / Carputer Thread
An other issue i am seeing is all tablet seem to share the same usb port for data transfer and charging, so i can't leave charger and external hard disk connected with it at the same time.
will bluetooth gps receivers work with tablet who don't have built in gps receivers?
have to get amount like this
http://www.ebay.in/itm/2in1-Tablet-C...-/280978157899
gigy is online now   Reply With Quote
Old 8th December 2012, 21:12   #827
DerAlte's Avatar
Thanked: 2,879 Times
You can do some jugaad with the cable. You just need to connect +5V to the designated USB pins on the other end (not the mini-USB side), and connect that to a mobile phone charger. Look for a cable with 2 conventional USB plugs on one end (used to come with some USB external drive housings), and a mini-USB at the other end.
Any GPS receiver (BT or USB) would work, provided they have Android drivers.
Are you replacing the HU? If you have 2DIN space, you can make a mounting for that space using clips or magnets, so that you can remove the tablet and take with you whenever necessary. The windscreen mounts would work, but they look bad.
Old 16th December 2012, 17:23   #828
diesel_maniac's Avatar
Exclamation Re: The CarPC / Carputer Thread
Hi Guys !!
I am in need of some help from fellow carputer users on Tbhp, specially based in Delih-NCR region. The situation is that I have misplaced the remote for my lilliput eby701/629 series touchscreen and need the same for activating the Auto-On function for Reverse Camera input. If anybody is using the same series monitor in their systems it would be a great help if I could meet up and use the remote to configure the function on the touchscreen.
Thanks in advance for your help and some alternate suggestions on the same.
Jasvinder
diesel_maniac is offline   Reply With Quote
Old 25th May 2013, 22:07   #829
mercedised's Avatar
Thanked: 177 Times
Originally Posted by DerAlte View Post
Go to the nearest electronics market. Someone should be able to purloin it out of a discarded desktop PSU and a 4-pole connector. Make sure it is wired correctly.
need Help Badly! When I built my Carputer, I custom fabricated the Aux-in cable from a telephone wire cable. Since then there is whining noise which increases with increase in RPM. There is no noise when the engine is off. What might be the problem and how to get rid of it?
mercedised is online now   Reply With Quote
Old 25th May 2013, 22:27   #830
DerAlte's Avatar
Originally Posted by mercedised View Post
... I custom fabricated the Aux-in cable from a telephone wire cable. Since then there is whining noise which increases with increase in RPM. ...
Oh-oh, you shouldn't have used *unscreened/unshielded* telephone wire. Please get some 2-core (2-core+shield) shielded cable and replace it.
DerAlte is offline   (1) Thanks Reply With Quote
Old 26th May 2013, 11:53   #831
mercedised's Avatar
Thanked: 177 Times
Thanks will do that, Any shielded wire is Okay? Meanwhile I googled about this issue, and some of the guys used ground loop isolator. Now what's that?
Old 26th May 2013, 12:38   #832
DerAlte's Avatar
No, your problem is RF interference because your wires aren't shielded. Adding a GLI would be an overkill.
Just use common 2 core shielded wire available in electronics shops. Be sure to look at how sparse or dense is the shield weave (hold the inner cores and pull back the outer insulation) - go for the denser weave.
Old 27th June 2013, 23:55   #833
mercedised's Avatar
Thanked: 177 Times
Will this work on my Safari 3.0L Dicor, I want to monitor engine parameters as well as error codes if any :
http://www.aliexpress.com/item/ELM32...497740602.html
Thanks.
Old 28th June 2013, 15:50   #834
DerAlte's Avatar
Will this work on my Safari 3.0L Dicor, ...
Can't really say, since the description on the site doesn't list the protocols it handles. Just says OBDII, which the 3.0l DICOR doesn't conform to. I would assume that it doesn't, since the one that I have (BT version, but everything else same) doesn't seem to understand the communications on the OBD port.
Old 28th June 2013, 18:40   #835
mercedised's Avatar
Thanked: 177 Times
So what protocols I should be looking for?
BTW, I got the GPS receiver today, ordered it at aliexpress 25 days ago. Any idea on the ideal position of the GPS receiver in Safari?
Old 28th June 2013, 19:19   #836
DerAlte's Avatar
So what protocols I should be looking for? ...
I think (I am not sure) ISO9141.2 or ISO14230 (KWP2000). Only the service guys can say for sure, if they read the manual or settings of the diagnostic hardware / software they use.
... Any idea on the ideal position of the GPS receiver in Safari?
Anywhere on the windshield side of the dashboard, maybe near either A-pillar. If the wire is long enough, you could mount it (use good double sided tape) at the top of the windshield from inside near the A-pillar, routing the wire through the A-pillar cladding. It will not be visible from outside.
Old 29th June 2013, 21:46   #837
mercedised's Avatar
Thanked: 177 Times
p
Please have a look at the details about a Diag. Hardware that was used by my mechanic, this is the manual for Tata cars, Does it help in determining the protocol used for Dicor:
http://www.x431.com/upload/testType/...TATA_13.00.pdf
Old 30th June 2013, 09:38   #838
DerAlte's Avatar
... Does it help in determining the protocol used for Dicor: ...
Sorry, no it doesn't. Your mechanic must be using their all in one product, either wired or with the BT dongle. Seems to be the right product.
I went through their website, but couldn't find a dongle (they do have one) that we can buy. Their online site is also not responding. Will try again later.
Old 30th June 2013, 10:35   #839
mercedised's Avatar
Thanked: 177 Times
Meawhile, I also found another product, it is specially designed for Indian cars, I have mailed them asking about the compatibility with Safari Dicor.
http://www.leagend.com/viewpro.asp?id=378
Old 16th July 2013, 18:28   #840
mercedised's Avatar
Thanked: 177 Times
Hello,
I am back with a new problem, now I want a bluetooth connectivity for car PC. Will I need a specific Kit for that of adding a mic would be sufficient?
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
