Old 16th July 2013, 19:01   #841
DerAlte's Avatar
Thanked: 2,879 Times
Default Re: The CarPC / Carputer Thread
What software are you using on the Car PC (OS, control center etc.)? You would need at least a BT USB dongle and a mic, but it is not a simple addition to a PC.
The right thing to do would be not to associate BT-based call handling with the PC, but instead handle it with a kit from Parrot or Nokia - either independent one with it's own speaker, or through the HU through Aux-in.
Old 16th July 2013, 21:03   #842
mercedised's Avatar
Thanked: 177 Times
I am using Windows XP, CF 4.0. Yes, I want to associate BT based call handling with carputer. The kits cost a bomb don't they? ( for what they serve). Please advice. Could you share your Carputer configuration and any pics. if you have.
Old 17th July 2013, 17:50   #843
DerAlte's Avatar
Originally Posted by mercedised View Post
I am using Windows XP, CF 4.0. Yes, I want to associate BT based call handling with carputer. ...
CF has BT handling built in, provided you have BT with your board. Look for a USB BT dongle if your board doesn't have it built in (most boards don't). The dongle would come with it's drivers.
Old 21st July 2013, 10:59   #844
mercedised's Avatar
Thanked: 177 Times
Just wanted to share that I got working Mireo MMI v8 maps in my car pc. Although the Mireo Design is a little difficult than Garmin. If anybody needs them, PM me.
mercedised is offline   (1) Thanks Reply With Quote
Old 25th July 2013, 14:55   #845
S_U_N's Avatar
Thanked: 383 Times
For those car PC enthusiasts, here is one more DIY (but perhaps with lesser efforts).
http://www.flamelily.co.uk/2013/05/r...-car-computer/
I have ordered my Rpi, but not for usage in the car.
But perhaps that might change in the future.
S_U_N is offline   (1) Thanks Reply With Quote
Old 3rd August 2013, 21:52   #846
mercedised's Avatar
Thanked: 177 Times
Hello, after some googling I came to this website which contains manuals to the Diagnostic tools used by TASC. They use Samtec HSlight II Interface. As shown here in the link http://www.samtec.de/?id=53&L=1 for engine diagnostics by laptop.Please download the 4th file and have a look at it from this link http://ed.tatamotors.com/frmHelpDocuments.aspx
Does it give any idea on the OBD protocol\ISO used by Dicor 3.0?
Old 4th August 2013, 16:06   #847
DerAlte's Avatar
... Does it give any idea on the OBD protocol\ISO used by Dicor 3.0?
Thanks, but no - neither gives pertinent information. Tata document has no mention of it. Samtec document talks of a superset (ISO 9141).
I did some experimentation with my ELM327 dongle and an Android App called OBD Car Doctor. The App finally latched on to ISO 14230-4 KWP (either 5 baud init or fast init) as the protocol on the ECU side. Unfortunately nothing seemed to flow after that - still trying to figure out.
DerAlte is offline   (1) Thanks Reply With Quote
Old 7th August 2013, 19:46   #848
mercedised's Avatar
Thanked: 177 Times
Hello,
I have installed a mic and a bluetooth dongle in my carputer. Now, I want to pair my phone for receiving calls/play music via bluetooth through carputer. Could you guide me with the settings?
Thanks.
Old 28th November 2013, 19:51   #849
mercedised's Avatar
Thanked: 177 Times
Could anybody help me with Centrafuse. I have 4.2.7 and it has stopped creating playlists, all the songs that i play are queued in to the Now playing list. Any clues?
Old 2nd December 2013, 22:05   #850
mercedised's Avatar
Thanked: 177 Times
^^The above problem has been solved. I reinstalled .Net framework 4.0 and SSCE runtime SP2.
Old 21st January 2014, 09:17   #851
mercedised's Avatar
Thanked: 177 Times
Got into another problem, the PC restarts on starting the car, earlier it did'nt used to happen. What might be wrong?
Old 21st January 2014, 09:18   #852
gigy's Avatar
Thanked: 41 Times
Car battery crank voltage low so battery need replacement or the PSU needs replacement
Tablet or Smartphone as a CarPC (Carputer): Things to watch out for malgudi In-Car Entertainment 5 27th October 2014 17:42
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
Streetaddict's CarPC/Carputer StreetAddict In-Car Entertainment 22 12th November 2010 01:50
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Honda Civic VTI - CarPC + PowerBass/JBL ICE stapi In-Car Entertainment 17 20th October 2008 10:16
