Old 7th January 2008, 10:12   #61
ScarySkulls's Avatar
Thanked: 19 Times
Yes mate. Backtrack a few posts. He has posted the cost.
ScarySkulls is offline   Reply With Quote
Old 7th January 2008, 11:35   #62
navpreet318's Avatar
Thanked: 894 Times
yep mate.got the prices long time back.thank you.
and yes scary "mille sur mera".lol
navpreet318 is offline   Reply With Quote
Old 7th January 2008, 13:26   #63
navin's Avatar
Thanked: 4,282 Times
Originally Posted by Autophile View Post
Subs - 20Hz - 50Hz (2nd Order Subsonic & 4th Order Low Pass)
Woofers - 50Hz - 90Hz (2nd Order Highpass & 2nd Order Low Pass)
Front Stage - 90Hz - Till Wherever it extends (2nd Order Highpass)
did you try an overlap. I would try pushing the front down to say 65Hz.
did you notice a need for the "rumble" filter?
Old 7th January 2008, 14:42   #64
Thanked: 294 Times
I think 65 Hz at 260 watts will be to much for any Midbass when played at loud volumes.
Navin Ji in what context are you referring the rumble filter (high pass), PXA can do that.
Old 7th January 2008, 15:56   #65
navin's Avatar
with CDs I have not found the need for a filter to filter out 20hz, unless ofcourse it was exciting some room nodes. I believe in keeping it simple and unless the filter made an audible difference there would be no need for it.
Old 8th January 2008, 10:22   #66
Autophile's Avatar
You need to use subsonic filter in case of high powered IB sub sections.
Autophile is offline   Reply With Quote
Old 8th January 2008, 10:40   #67
Thanked: 294 Times
Very true..It helps a lot to clean out the low end rumble. Also when I want to play loud and with kick I use subsonic till 30 hz or a little more and boost some at 50-60 hz as required to get the desired kick
Old 8th January 2008, 11:10   #68
Bass&Trouble's Avatar
Thanked: 71 Times
... and in the case of high power ported systems.
Old 8th January 2008, 23:05   #69
rocksterraghu's Avatar
Thanked: 95 Times
Whoa! Superb install! If not for Team-BHP, I would have never even imagined glorious installs like this.
Two thumbs up!
ICE' ing the White Beast- Scorpio VLX 8 Seater prithvi_seln In-Car Entertainment 38 21st October 2010 10:52
"Barracuda" Autopsyche Octavia - ICE Install pics gunbir In-Car Entertainment 64 14th July 2008 13:22
Chennai to vizag (1928 kms) on my new Beast! (EDIT: Beast=Fiesta 1.6 zxi Petrol) gopal.putrevu Travelogues 19 18th April 2008 13:35
"IMAGE" Autopsyche Lancer ICE Install Pics gunbir In-Car Entertainment 53 20th September 2006 01:06
"VEGA" Autopsyche Lancer ICE Install Pics gunbir In-Car Entertainment 18 1st May 2006 15:06
