Old 5th January 2008, 12:42   #61
iraghava's Avatar
Thanked: 156 Times
Originally Posted by clipto333 View Post
it is a good decision to go for the 0g wiring. You have a crdi? or petrol.
Going by the CNG cylinder in the boot, I would say Petrol! Unless he uses that to store extra diesel
Old 5th January 2008, 13:24   #62
clipto333's Avatar
haha. didn't realize there is a tank in the boot. lol.
clipto333 is offline   Reply With Quote
Old 5th January 2008, 14:30   #63
Gill's Avatar
Thanked: 12 Times
Congrats!
Great effort on enclosure,though could have increased the width a bit!
The sub seems to be a real beast,such a huge variation in power handling after break-in period!
Reviews on the product,shall be appreciated as it's the first Hifonic install i have seen!
Gill is offline   Reply With Quote
Old 5th January 2008, 15:20   #64
Thanked: 294 Times
First for the north india I think so, SS what do you say ?
Old 5th January 2008, 15:57   #65
nice. good job paras. congrats and enjoy the music.
now, what you will have to change is that sony amp. BTW whats the model no of the sony?
see, if you are fine with it, then keep it, but you will hear a difference for sure when you upgrade to a better amp. baaki, if you happy, we happy. :-)
can you switch off the lights(sub, comps)
i once tried to get the MDF cut from professional aari wala(table saw?) he cut it wrong. it took me 2 days to correct everything and i ended up with a small enclosure. lol now i DIY.
Hey Rishabh,
well, its a sony 554.. nearly 2 yrs old..i will be changing it but not now, there are some pretty good amps by EFX.. or else there is blaupunkt..
my ride is a petrol, converted to CNG. though it runs on petrol most of the time..unless i go to delhi..
the comps are wired directly to the remote turn on of the HU.
the sub is wired to the remote turn on too, but i have put a switch in between.
for the MDf cutting, i made the aari wala keep 2 soot extra, and then used a randa for finishing.. it was a tough job, but it feels so goood....
saintsinner is offline   Reply With Quote
Old 5th January 2008, 16:03   #66
Originally Posted by low_bass_makker View Post
Hmm...nice amp 1600 x 1 at 1 ohms. that is some serious ****. How much damage ? And waiting to hear the install.
waiting to hear the install, well you are the chosen one.. tommorow sunday.. you are in for it.. i have done some DIY damping in the boot, will go in for more damping after meeting you...as it is needed
Old 5th January 2008, 16:04   #67
Originally Posted by nitrous View Post
Haanji!
Btw, whats the discoloration around the centre of the subs??
this is my great Nokia N70
Old 5th January 2008, 16:04   #68
its a closed loop CNG sir.
Old 5th January 2008, 16:10   #69
Congrats!
yes Gill saab, no one to help me, i wish you guys were here
the brutus sub is a beast provided the right power and enclosure, there is a guy running 2500RMS into two subs!
OT - the XXV series sub and amp are simply amazing!!!!!!
more on the brutus below -
Old 5th January 2008, 16:13   #70
Yes sir, roger that
i'll call you tommorow and land somewhere around before lunch...
where is Satya????????????????????
Busy guy...
Old 5th January 2008, 21:33   #71
DerAlte's Avatar
Thanked: 2,879 Times
Congratulations, @ss, well done!
That sounds like a lot of elbow grease went in. The job I have always hated in carpentry is planing, and I am still waiting to buy an electric planer.
(For folks not used to Hindi measurements and terms: 1 soot = 1/8"; randa = planer; aari = saw; aari-wala = guy who operates the electric saw)
You said earlier that you have used nails ! Sacre bleu, sacrilege!!! Unlike screws, nails are likely loose grip in MDF over time.
Old 5th January 2008, 21:37   #72
Thank you sir, and thanks for the english terminology. i have used very few screws, mostly on the corners and for the port. but the nails are pretty thick and big ones, will post a sample
Old 6th January 2008, 00:50   #73
Thanked: 294 Times
Carpenter.
SS the nails will get lose. Delarte is correct. I would recommend to put screw when you get time as it will make the enclosure rock solid. Drill a hole first and then the counter then the job will be easily be done.
Old 6th January 2008, 00:53   #74
Carpenter.
Ya, i'll do that. tapered SS screws will be fine na...
Old 6th January 2008, 01:49   #75
Thanked: 294 Times
SS-> Stainless Steel
No need to get them use normal wooden screws which have a flat head and half taper thread.
Speaker Enclosure Volume Calculator
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
To upgrade or not to upgrade? Steeroid Tyre & Alloy wheel Section 22 20th June 2007 19:13
Your Pre-TBHP ICE setup; Why did you change/upgrade/feedback jkdas In-Car Entertainment 77 9th October 2006 14:49
ICE upgrade for Skoda karthik247 In-Car Entertainment 34 22nd March 2006 23:31
