Old 2nd January 2008, 12:25   #16
Thanked: 294 Times
Hmmm my favorite topic. I once got banned for it also and I still dont know till date how they did that... anyyways.
Like Tanveer and Delarte has said voltage are like this...
Originally Posted by DerAlte View Post
Slight correction:
12.6-12.8 : Engine turned off, only battery
13.1-13.6 : Engine running, electrical accessories running, battery charging
14.4 : Engine running, over-rated alternator + regulator, no other electrical accessories running (except ICE) and battery fully charged
Battery is 12V NOMINAL; does not mean voltage at the terminals cannot be more.
So in the real world the amp must be rated at 12 volts not 14.4 volts. The CEA standard recommends 14.4volts but in the real life situation 12 volts it is.
So when ever buying a amp check out the 12 volts rating. not the 14.4 unless you are upgrading your electrical system.
I would like to add some thing here that the STEG are rated 11 volts not even 12 and never 14.4 and the main reason to buy them was this.
Steg
So choose your amp wisely.
Ok now about 16 volts setups. Like Del bahi has suggested that can be very much possible but one will have to put and additional alternator to power the Amps. It can give out 16 volts and the whole amp circuit will be isolated from rest of the car electricals. For this the amps are special one...like this one...
:: Ground Zero :: Amplifier / GZPA 1.10000spl
It can take upto 18 volts. And for powering it one can use these 9 battries in series to give out the power to run this beast which can give 11000 watts rms.
:: Ground Zero :: Batterien / GZBP 2.6000
Now the question arise what do you want. How long do you plan to play ? If for few second then put additional batteries so that the voltage dip is reduced to some extend, but make sure you give enough of time to keep them charged.
Old 2nd January 2008, 12:39   #17
amit_sound's Avatar
Nice info guys....
BTW as i said i have no intension to go over board with the Volts. It just a question that popped up and i felt that it worth getting more info on the same. Such info is always beneficial for ICE lovers and me.
No doubt that STEG is a beautiful amp to have.
amit_sound is offline   Reply With Quote
Old 2nd January 2008, 13:28   #18
clipto333's Avatar
and your system will be marginally loud with an addition of 500w. it wont be that noticable IMO.
even i thought of mounting another alternator with a seperate battery cause my lights used to dim alot. but then i upgraded the power cables to 25mm^2. every thing is good now and with the engine running, the voltage remains between 13.5-13.8v with every damn thing running. i will check again though. im gonna upgrade the main power cables of the electrical system(the big 3) soon.
clipto333 is offline   Reply With Quote
Old 2nd January 2008, 13:36   #19
Thanked: 294 Times
I think it will make a little difference and will be easily measured by a SPL meter.
Old 2nd January 2008, 13:52   #20
clipto333's Avatar
i wasn't talking about the electronic spl meter but pure leather meter. our ears. lol
what will be the difference in terms of decibels? less than 1 db? let me know
Old 2nd January 2008, 13:55   #21
sgiitk's Avatar
Thanked: 3,883 Times
Originally Posted by amit_sound View Post
Fine... but what if i want to go upto 16.6 V....just a question, not my intension
Guys have bench tested the amp, and as said above it draw 2700 RMS @ 14.4 V, and 3200 RMS @ 16.6 V. So how can car electrical be pulled up to 16.6 V then?
Any attempt to charge at above 13.x volts will dramatically reduce the battery life due to severe over charging.
So you have two alternatives - use a separate generator (alternator or whatever) to get your 16.6V or use a dc to dc converter. I would suggest the latter, but whether you will get one for 16.6 is not known. You may have to settle for 15 or 18.
Old 2nd January 2008, 14:03   #22
clipto333's Avatar
a dc-dc convertor will be quite expensive considering the power requirements of the amp. its like using an amplifier to power an amplifier. a second alternator regulated at 16v would be a better option.
car manufacturers are already in the process of upgrading the charging system to 42v nominal. i think that will be good. but it will really complicate things for a diyer.
cheers
Old 2nd January 2008, 14:11   #23
Thanked: 294 Times
I would put it as tympanic membrane not leather ( leather means processed skin)
In terms of db from 2000-to-2500 the db change will be 1 db change. and 1 db is quite easily observed by human ear or tympanic membrane
Old 2nd January 2008, 14:27   #24
sgiitk's Avatar
You will still need a storage. So we will have a battery with say 7 or 8 cells!
This has been bandied around for quite some time. The idea is to switch to thinner wiring, and also feed the increasingly power hungry accessories. The cost savings led to trucks going 24V. However, 42V means all auto electrics has to change. New batteries, new alternators, new everything.
Old 2nd January 2008, 15:57   #25
clipto333's Avatar
what ever membrane lol.
in this case, its 2700 to 3200w. so its less than 1 dB. would you invest in a separate charging system for less than 1 dB gain in output?
yeah, storage will be a problem. but there should be battries rated at 16 or 8v.
i think it will have dual outputs. for low power devices it will have 12v. and high power will be 42.
with the power hungry electronic stuff this is a good thing to do. there is no other option i guess.
cheers
clip
Old 2nd January 2008, 16:09   #26
Thanked: 294 Times
Sir If I am competing in a SPL competition I would defiantly invest to extract max from my setup because each DB counts.
Sir I also seriously doubt the 42 volts setup. I think it will be either 24 volts or 48 volts because of the standard batteries available in the market and not 42 volts.
Old 2nd January 2008, 16:31   #27
sgiitk's Avatar
Lead Acid batteries are 2V nominal (2.2 actual) per cell. So 16V = 8/7 cells, 18V = 9/8 cells depending on whether your unit can handle voltages higher than the nominal voltages. Popular battery ratings are 6 and 12V. This is why trucks have 2 x 12V. So you will either have to stack/add single cells or use three 6V units. This does not look too good to me. .
Old 2nd January 2008, 18:48   #28
DerAlte's Avatar
Thanked: 2,879 Times
Wouldn't raising the ground end of the battery (zener / reversed diodes) be simpler than making a custom battery for getting >16V on the PS line?
* The battery is only being used for regulation and off-line power, not main power source - Amit's application needs (3.2 / 0.6) KW!!!
* The relatively slightly lesser power store (6 cells) will not substantially affect the application - the battery will discharge in 23 minutes instead of 29 (assuming 1 battery of 130AH; ICE running totally off the battery)
* Anyhow, this is a theoretical exercise (Amit has already mentioned he is not really doing it, he only wants to know)
The issue here is not of redesigning the system, but extracting "the last drop" from the standard system for competitive purposes, as LBM had put it. The same Olympic (doping) rules should apply.
IMHO Amit will not be satisfied even if the electricals were to change to 24V (as we have been expecting to happen for the last couple of years) or 48V. It is just that then he will talk about raising the bar to 33.2V, then 66.4V, so on and so forth... there is no end to human desire
Lage raho, Amit-bhai!
Old 2nd January 2008, 22:50   #29
amit_sound's Avatar
if SPL it is....then every db counts. If i hit 150 db.....i would not mind investing 20k to go to 151 db.
Love for SPL u see.
Old 4th January 2008, 16:43   #30
panky12345's Avatar
Thanked: 149 Times
achha one thing more.... is there a standard to determine how the amp would behave (read output) at different volts. Like I have an amp which is 230 W @ 2 ohms @ 14.4V then ??? W @ 2ohms @ 12V?
Different Service Schedules for Different Cars Vishesh Technical Stuff 22 15th August 2012 17:07
Cost of ECU - Indica Lsi | Different Dealers ,different prices ! shiva_cool87 Technical Stuff 6 7th January 2010 17:43
Is the immobiliser technology different in different cars? n.devdath Technical Stuff 3 12th November 2009 18:59
How different fuel brands work on different cars-Fifth gear video nitrous Technical Stuff 2 18th March 2007 12:05
Different Speaker Brands = Different sound for same/similar music ? normally_crazy In-Car Entertainment 10 29th August 2006 12:05
