Old 4th January 2008, 17:56   #31
Thanked: 13 Times
Exclamation
Originally Posted by panky12345 View Post
is there a standard to determine how the amp would behave, Like I have an amp which is 230 W @ 2 ohms @ 14.4V then ??? W @ 2ohms @ 12V?
Similar doubt...Which amp ?
If Im not mistake our beloved 75.4 came with ratings of 14.4v as well as 12v. So does it mean depending on the time (driving, no lights or A/C) the baby is infact capable of putting out a little more due to a cleaner higher power supply?
Old 4th January 2008, 17:57   #32
Thanked: 294 Times
achha one thing more.... is there a standard to determine how the amp would behave (read output) at different volts. Like I have an amp which is 230 W @ 2 ohms @ 14.4V then ??? W @ 2ohms @ 12V?
It will depends on lots of parameters. So one cannot say thumb rule can be 20 % less.
Old 4th January 2008, 18:05   #33
panky12345's Avatar
Thanked: 149 Times
what parameters LBM? Can you please elaborate? If I need to find out how my 301.1 behaves @ 12 V, how can I?
panky12345 is online now   Reply With Quote
Old 4th January 2008, 21:10   #34
clipto333's Avatar
Originally Posted by low_bass_makker View Post
Sir If I am competing in a SPL competition I would defiantly invest to extract max from my setup because each DB counts.
Sir I also seriously doubt the 42 volts setup. I think it will be either 24 volts or 48 volts because of the standard batteries available in the market and not 42 volts.
for a competition, even i would do that. i was talking about normal operation(listening to music) i a competition 1 db is a lot. one can loose by .1db.
and regarding the voltage, i will confirm. let me find that article. it said the battery voltage will be somewhere in the 35-40v range and the alt would put out 42v.
it could be 48v but not in this article. it was 42v im sure. i will confirm once i find and read it again. i could be wrong.
cheers
clip
clipto333 is offline   Reply With Quote
Old 4th January 2008, 22:47   #35
Thanked: 294 Times
Sir all depends on the amp power supply. Some are rated at 14.4 volts and some at 13.8 and some at 12 and some at 11 also. Normal car voltage I would take as 12 volts after all the accessory are working. So consider the amp which is having 12 volts anyday.
This happens because the power supply of these type of amp is not regulated. when the input increases the output increases. but in a regulated amp if there is variation in voltage till they are rated at they give full output.
Old 5th January 2008, 02:49   #36
clipto333's Avatar
lbm, even if the amp is rated at 14.4v one can approximate the output level at 12v. so, one can get an amp which has higher output at 14.4v than required. this will make sure one has the required output at 12v. for e.g. one if one has a 1000w sub he can get an amp which is rated 20-30% more than the sub at 14.4v. i think it is quite doable. what do you say?
and how much would a tightly regulated amp cost? i think they should be quite expensive. one has to buy something like audison or steg to have a 12v ratiing,
Old 5th January 2008, 13:18   #37
Thanked: 294 Times
It vaires from Model to model. Like the Alpine MRD-M1005 was like this
1000 x 1 at 2 ohms 14.4 volts
700 x 1 at 2 ohms 12 volts
700 x 1 at 4 ohms 14.4 volts
500 x 1 at 4 ohms 12 volts
Not the new series PDX amp from Alpine is having these specs.
1000W x 1 at 2 ohms 14.4 volts
1000W x 1 at 4 ohms 14.4 volts
one more model of pioneer 3000 spl its
1000 x 1 at 4 ohms 14.4 volts
500 x 1 at 2 ohms 14.4 volts
Now I think you got a good picture so there is no thumb rule for the amp specs that is why the CEA rating is made so that to compare there are certain parameters. in which all the parmeters are kept constant to get a stable result.
Yes STEG has a regulated supply down to 11 volts. anything till 11 volts it will give the same rated output.
Old 6th January 2008, 00:39   #38
navin's Avatar
Thanked: 4,282 Times
The Steg will work fine but your headlights might dim a bit at 11V.
Old 6th January 2008, 01:39   #39
Thanked: 294 Times
Very true Navin Ji. But one very interesting thing I wanna add here. I have installed HID in the projector and in the fog lights also. When I increase the bass the fog light HID dims with the music but not the projector one. So I think the Project HID ballast are better built and have a more regulated output when compared to the fog light ballast.
Different Service Schedules for Different Cars Vishesh Technical Stuff 22 15th August 2012 17:07
Cost of ECU - Indica Lsi | Different Dealers ,different prices ! shiva_cool87 Technical Stuff 6 7th January 2010 17:43
Is the immobiliser technology different in different cars? n.devdath Technical Stuff 3 12th November 2009 18:59
How different fuel brands work on different cars-Fifth gear video nitrous Technical Stuff 2 18th March 2007 12:05
Different Speaker Brands = Different sound for same/similar music ? normally_crazy In-Car Entertainment 10 29th August 2006 12:05
