Old 7th January 2008, 15:23   #31
Gill's Avatar
Thanked: 12 Times
@Navpreet great install!Congrats,effort gone into is clearly evident.Can you take closer pics of the MDF board you have used for mounting the amp on the rear seat.And if possible the pics of spare tyre cover you made out of the mdf!
I simply loved the Enc of the sub!Good to see that you have used the woodn plank to stop the sub skidding around in the boot!
Cheers!
@Clip he has used the 4 ga from battery to the block then the run of 8 ga for each amp!
Gill is offline   Reply With Quote
Old 7th January 2008, 15:25   #32
SRShrikanth's Avatar
Brilliant set-up Navpreet.
I spent one weekend only re-doing my ICE wiring to get my tuning right. And i felt exhausted at the effort.
In your case, phew....!!! I can well imagine the ever-lasting agony in getting it all together. Brilliant outcome, to say the least.
As they say, passion is the only driver that knows no boundaries. !!!
Cheers mate.
SRShrikanth is offline   Reply With Quote
Old 7th January 2008, 15:35   #33
navpreet318's Avatar
Thanked: 894 Times
yep lbm thats exactly like you have done it except that i have not used any stel ring in it.
well gunbir that sub rocks.its providing me more than the required bass.actually too much for it size.i am amazed.and its not even run in properly yet.
clip i had the sony amp from before.long time back.had i predicted this setup i would have changed the amp.never the less it is a great amp.
it wasn't present in the regular sony india range. and this one puts out 300w rms.even though one might think that sony generally over rate their amps.but this one is doing its duty well.
i am in bliss.
regarding the kenwood amp.well as you must be knowing that these infinity components require very less power.they are 90w but still they require very less firing power the kenwood is more than enough to power them.the power is just right.at full volume the sound is very clear.though the setting up of the gains is just a hit and trial method to judge what sounds sweet to the ear thats all.spent a whole day in setting up the gains.
navpreet318 is online now   Reply With Quote
Old 7th January 2008, 15:43   #34
Thanked: 894 Times
well gill the board supporting the amps is 1/2 inch mdf.as well as the wheel well cover.
making the wheel well cover is easy.
take out the flimsy stock board.peel off the board and whatever packing is there.
put it on the mdf board.and use a jig saw to cut it in the same pattern.
stick the foam blocks at the same locations as the original board and stick the carpet back on.simple.there you have it.and its strong enough even for us to sit.the wheel well in my car is empty as the wheel is too broad.its 205.so to support the sub enclosure i had to install the mdf board.
moreover it feels better than the stock flimsy board.
Old 7th January 2008, 15:47   #35
clipto333's Avatar
and like gunman said, it is easily the best looking DIY install.
clipto333 is offline   Reply With Quote
Old 7th January 2008, 15:57   #36
Thanked: 894 Times
thanks dude.hope you saw that i'm using 4g cable till the distribution block and then on its 8g.i used that power cable pack from audison which includes the cable,fuse etc.
you must be already knowing the details of that pack.
Old 7th January 2008, 16:32   #37
Dhar's's Avatar
Thanked: 163 Times
OT
please put up a pic of wheels too
Dhar's is offline   Reply With Quote
Old 7th January 2008, 16:48   #38
clipto333's Avatar
oh, sorry navpreet. i missed the 8g part in your detailed explanation. :-)
can you let me know the breakup of the cost of the install? it woul dbe nice
cheers
clip
Old 7th January 2008, 16:49   #39
chiragh_bir's Avatar
Thanked: 70 Times
absolute clean install!!
chiragh_bir is offline   Reply With Quote
Old 7th January 2008, 18:27   #40
Thanked: 894 Times
well thanks all.
dhar's the wheels are a very common design
but highly uncommon in dehradun.infact my car is the only one sporting these wheels.
i simply love this BMW replicas.they are perfect.
Old 7th January 2008, 18:39   #41
Dhar's's Avatar
Thanked: 163 Times
@navpreet
Superb alloys. Which make of tyres is that? cant make out from the pics.
All together its a helluva great machine!
Old 7th January 2008, 18:47   #42
iraghava's Avatar
Thanked: 156 Times
They are Maxxis tyres.
Old 7th January 2008, 18:50   #43
BUSA's Avatar
Awesome Alloys, What are the tires and alloy specs, how much for the alloys?
Those are Maxxis Victra MA-21, kind of VFM.
Old 7th January 2008, 19:18   #44
iraghava's Avatar
Thanked: 156 Times
Nope they are Maxxis MA-Z1.
Old 7th January 2008, 19:25   #45
BUSA's Avatar
Thanks Tire wala, i dont have that much gyaan in Maxxis as much you do
Projector setup on Swift & Some DIY also.... low_bass_makker DIY - Do it yourself 34 1st December 2009 02:04
Need help for Friends getz 1.1 ICE setup in Pune hrishig In-Car Entertainment 3 28th January 2008 16:23
Some Basic's for DIY ICE setup. subbarao In-Car Entertainment 2 25th September 2007 10:27
Audio setup for Swift gemballa In-Car Entertainment 27 20th February 2006 16:57
