Old 25th January 2008, 14:55   #16
Thanked: 45 Times
yes...to avoid lens change!! he advised me so..
rajivanoj is offline   Reply With Quote
Old 28th January 2008, 17:19   #17
kuttapan's Avatar
Thanked: 12 Times
LBM, DO you have any idea what ERROR 25 is?
kuttapan is offline   Reply With Quote
Old 28th January 2008, 19:15   #18
CrAzY dRiVeR's Avatar
Thanked: 19,895 Times
Guys, it seems only my rewritable discs are creating problems with the HU (Error 17). So, problem might be with the discs afterall.
Old 28th January 2008, 22:28   #19
Thanked: 294 Times
not here..
And also I have not experienced my self
Old 28th January 2008, 22:35   #20
Thanked: 282 Times
i also get this error 11 in my pioneer head unit when i try to play cdrw .no problems with cdr.
needforspeed88 is offline   Reply With Quote
Old 30th January 2008, 15:47   #21
kuttapan's Avatar
Thanked: 12 Times
Ok. Error 25 is when you try to play two CD's at once. Took both out(after several tries), put one back in and voila..MUSIC is back !
Old 5th February 2009, 14:56   #22
Thanked: 58 Times
LBM, I am getting Error 23 while playing MP3 disc. I guess I screwed up something while making it. This is what I did. Copied all my songs folders from pen drive to disc, it automatically burned it using default Vista writer. Did I made any mistake here ? I have P4050 installed by you only
sam003 is offline   Reply With Quote
Old 24th March 2009, 12:17   #23
sahilj's Avatar
Thanked: 31 Times
Unhappy Pioneer DEH 2190 UB Headunit - Help
A friend of mine got a pioneer DEH 2190 HU with front USB access. When she put the 1 GB pen drive it works fine, when she puts a 4 GB drive, the HU displays an error!
What could be the problem? does it not support 4 GB drives?
Please help!
Last edited by Jaggu : 24th March 2009 at 12:24. Reason: Please continue here, also search before opening new threads. Thanks
sahilj is offline   Reply With Quote
Old 6th April 2009, 14:19   #24
@sahilj
I have the same 2190 UB in my car and it read my 8 Gig USB drive without any problem.May be the drive is corrupt or something . Format it and try again .
jmddis is offline   Reply With Quote
Old 3rd June 2010, 11:07   #25
bblost's Avatar
Thanked: 6,980 Times
I get to see a Error-17 on my Pio.
If I remove and reinsert the cd containing mp3', it works just fine.
If I switch to radio, it works fine.
Any idea...what might be causing this.
Old 3rd June 2010, 11:35   #26
sammyboy's Avatar
Thanked: 351 Times
^^ i used to get the same error for mp3s in my Pio, the remove and insert worked fine for a while. THen it stopped reading them completely. Now all MP3s have started giving me this error. None of the MP3/WMA cds work on it now. I get error 23 on all mp3 cds.
sammyboy is offline   Reply With Quote
Old 5th June 2010, 14:40   #27
mithun's Avatar
Thanked: 59 Times
Maybe the lens has gone bad !
Old 18th July 2010, 13:10   #28
Epic's Avatar
Thanked: 424 Times
Default Error 11 with iPod NOT CD/MP3!
Hi all,
Did'nt want to open a new thread since I found this one but noticed that in this thread had Pioneer Headunits showing an Error 11 when a CD/MP3 is being played. I have a different issue.
I am using the Pioneer DEH-P6950 and the reason I chose this over the Pioneer 7950 is mainly because of the function to operate the iPod directly from the headunit itself. Now, Ive been using this headunit with my iPod since the past 4 years and have had absolutely no issues what so ever! However, I had recently given my car to the workshop which required them to open the dash board and hence remove the headunit for their work.
When I got the car back, I noticed that the headunit plays well and then shows an Error 11 after around 10 minutes of playing. It also happens that it does not show an error but the music just stops playing. In order for it to start plaing again, I have to switch off the headunit, remove the panel, fit the panel again and switch on. This sometimes has to be done more than once. Now, this happens only when I am playing music through the iPod only and never happens when I am playing CDs/MP3s or the Radio. Is this a problem with the headunit or the connection cable that directly connects the iPod to the headunit?
Kindly help!!
Epic is offline   Reply With Quote
Old 18th July 2010, 19:32   #29
DerAlte's Avatar
Thanked: 2,879 Times
Isn't the iPod connector coming out from the rear? Quite likely the cable is loose at the rear of the HU. Take it back to the workshop and ask them to fit it back properly.
Old 3rd August 2010, 10:02   #30
Visaster's Avatar
Thanked: 199 Times
Dont ever think of getting the lens changed, its a complete waste of time, money and mind. Just go and get yourself a new player if it starts showing error messages when you put in a CD, or if your CD plays for sometime and then an error msg comes up.
Visaster is offline   Reply With Quote
Need help in installing the Pioneer head unit(5950) in the dashboard(ac contols) Pras_gethigh In-Car Entertainment 3 27th February 2009 00:38
Front detachable face plate of Pioneer head unit stolen bkm In-Car Entertainment 4 1st December 2008 21:02
Pioneer 5750 Head Unit neverclever In-Car Entertainment 4 14th June 2005 07:09
