Old 1st February 2008, 15:39   #31
panky12345's Avatar
Thanked: 150 Times
Originally Posted by saintsinner View Post
where can i get the application form from??
blueraven in your case.
Old 1st February 2008, 15:47   #32
Ok, that ways,
I also have video of a GZ 15 incher on an IB running on a hifonics amp.
i the mean time, i'll text Blueraven...
saintsinner is offline   Reply With Quote
Old 1st February 2008, 17:25   #33
Thanked: 294 Times
Incentive for expanding the dealer network?? huh! B&T where are you?
May be maybe not
It was only one and I got it.
Old 1st February 2008, 17:37   #34
Tool's Avatar
well bro lbm ,
i dont want a disco on wheels nor do i want to show off.
Just want the ability to play loud if i choose to do so . And am scared that 2 will shake my car loose. LOL
Most of the time i dont listen to my music loud..mostly around 75-90 DB.
But what i am looking for is more pronunciation of the really low freq's , 25-38 HZ at decent volume levels.
Will always keep the box sealed for the tight Sq they provide.
So would i get more with 2 subs or 1 is good enough ? Guruji's ???
Thanx guys. .
O.T. - Cant wait for my ID max. Also am thinking about the KTX100EQ imprint thingy. Any suggestions ?
Maybe i should revive my old thread.
Sorry for the Hi-jack didnt mean to.
Tool is offline   Reply With Quote
Old 1st February 2008, 18:20   #35
Thanked: 294 Times
Originally Posted by Tool View Post
well bro lbm ,
Thanx guys. .
That can be done with a well designed ported enclosure that to with a single sub and with good SQ also
Also which music material is at 25-30 Hz region you tend to listen.
Old 1st February 2008, 18:47   #36
Tool's Avatar
Mostly Psy Trance bro LBM.
Dark russian Psy has some mental low end and that too @ over 150 BPM.
Also some of the psy trance music i make ( amateur musician ).
basically even at low volumes i want to feel low end bro.
thanks again
Old 2nd February 2008, 11:20   #37
Thanked: 294 Times
thanks again
Few tracks names, I can also listen to as I am lover of LOW_BASS
Old 2nd February 2008, 12:26   #38
Bass&Trouble's Avatar
Thanked: 71 Times
Go for two subs. All of the above symptoms call for this remedy.
Old 2nd February 2008, 12:36   #39
nitrous's Avatar
Thanked: 285 Times
Ajay saar, why would you suggest two subs instead of one (keeping the wattage equal)?
Is there an advantage?
Old 2nd February 2008, 12:54   #40
navin's Avatar
Thanked: 4,286 Times
less cone movement per db of SPL. less cone movement often translates to better defined bass.
Old 2nd February 2008, 23:39   #41
Tool's Avatar
That is very very true navinji. Thank you for that.
Have now decided to get 2 sub for sure .
But for the time being will get 1 and try it out for a bit. Than order the 2nd once i decide to sell my IDQ's.
No point in keeping 4 subs and also it is easier on my pocket too hehehe.
Well 1 sub is already on its way . i better make up my mind fast on the IDQ's. Its just i really like them too..LOL.
Old 3rd February 2008, 00:40   #42
blueraven316's Avatar
or there is also Polk Audio SR124. Doubt you will find them in Delhi.
Polk SR is nowhere close to being an SPL sub. It does not even come with recomended ported enclosure volume suggections.
Panky: Your budget will dictate a lot of things and choices, so whats the total budget for a pair of subs ?
blueraven316 is offline   Reply With Quote
Old 3rd February 2008, 01:00   #43
DRAGONLORD's Avatar
Bro, I learnt one think when i picked up my Infinity Sub and amp, you need a full balanced package of ICE in your car to get the best effect. So now I'm saving up for component speakers too which will compliment my sub and amp. What is the rest of your ICE setup made up of ? You may have to upgrade your speakers at the same time to get the best effect.
DRAGONLORD is offline   Reply With Quote
Old 3rd February 2008, 01:44   #44
Tool's Avatar
hey bro dragonlord...
umm dunno if the post was meant for me but well you can check out the following link for info on what i have in my car.
http://www.team-bhp.com/forum/indiancarpicture-427.html
big boom guys..
Old 3rd February 2008, 18:40   #45
Thanked: 71 Times
The recommendation was specifically for Tool. He listens to a lot of psy music from what I understand. Like Navin said, to keep excursion low and for speed, two subs would be a good idea. In fact, 3 x good 10"s would be perhaps better. In most psy music the bass line is pulsating and rapidly changing. As Tool mentioned, some of the stuff is 150 bpm+.
Shallow-Mount Subwoofers harish_K In-Car Entertainment 15 8th July 2011 20:14
jelly subwoofers ?? - Why is this happening? Tool In-Car Entertainment 14 31st January 2008 11:35
Alpine subwoofers for sale blueraven316 Shifting gears 16 26th March 2007 01:08
Impedance of Subwoofers 929RON In-Car Entertainment 36 31st August 2006 14:28
6x9 Subwoofers theEnd In-Car Entertainment 16 31st July 2006 13:57
