Old 18th February 2008, 02:10   #16
Thanked: 17 Times
Finally! Eh?
I'm sorry for the delay bro!
Congratulations! You have a very good system now. I know it's still half way, but it's already a good one. Enjoy!
Now, did you say bright? Hell!! That's strange. Really strange. Because that HU never was bright when I had it. I strongly recommend you to check all aspects once again. Start from the crossover and every connections. If it persists, then please explain how it's connected to the amp and speakers. Also try using the defeat option in the HU so that there ain't any artificial boost to the sound.
One important thing to note: use normal, good quality audio cd for testing and not Mp3s.
And regarding the burgers, I had tried that trick once and the bugger didn't bulge. You may try too. Or you can resort to his own special emotional blackmailing. But all for the HU only. Forget the tube.
Old 18th February 2008, 09:15   #17
Thanked: 13 Times
Thumbs up
Thanks Shrivz, Veb, Ramie and the others for the compliments and wisecracks
Originally Posted by hydrashok View Post
Good to see you did not compromise on the fronts at all!
And it is good to see the alphanumeric reptile making some solid contributions to the ICE Scene
PS: Don't return the HU. Swap it for 5 Burgers
The front is where its at! The reptile has realized the value of the head and will take it back when the time comes to install in his VDi.
Originally Posted by abhibh View Post
Ahhh atlast Souljha Boi is ready to CrankDat. Nice and clean setup man very very good. psst psst add 5 more burgers and keep the basstube too
Paaji, basstube will be disconnected its not fitting into the scene at all.
...But all for the HU only. Forget the tube.
Chetta THANK Y-O-U! No apologies necessary!!!!
Brightness was also to do with the amp gain setting I reckon.
Crossover has been set to -3db. Defeat also being used
The brightness was tackled once Satya tuned the head. I havent spent more than 20mins with the HU yet but need to learn.
Unfortunately no end of burgers will work. I will give him burgers to take the basstube though!!!
Old 18th February 2008, 09:49   #18
shuvd's Avatar
Congrats S0uljah! Nice set of equipment you got there!
shuvd is offline   Reply With Quote
Old 18th February 2008, 10:15   #19
Thanked: 294 Times
Hmm so finally it is done. Congrats. And enjoy music.
Old 18th February 2008, 10:35   #20
DerAlte's Avatar
Thanked: 2,879 Times
Congratulations, @s0uljah, enjoy your music!
@br must be doing a good job with your head!
Now that should be brought to the notice of Mr.Hegde - a definite case of inducing a public service person with enticements!
Old 18th February 2008, 14:07   #21
rjstyles69's Avatar
Thanked: 795 Times
Congrats Anirudh and finally suzie is all set to sound nice with the ICE.
When do we get to audition this and have maggie shake his booty ?
Old 18th February 2008, 14:31   #22
theMAG's Avatar
Thanked: 1,574 Times
During the next asteroid hit.
Old 18th February 2008, 15:49   #23
Bass&Trouble's Avatar
Thanked: 71 Times
s0uljah: Very interesting report, lol. The Alpines are not as bright as you describe them to be. Neither is much else in the chain. Make sure you have switched off MX etc if it exists and the EQ is flat. The Lucents dont need any attenuation from the crossover ideally, and last of all from the head unit. Also ensure that the tweeters are connected in correct polarity while you're at it.
So, you'll be giving head to the reptile when his VDi comes? Please post photos of that.
Old 18th February 2008, 18:31   #24
Thanked: 13 Times
Thanks ShuvD, LBM, DerAlte & Riju.
@B&T : MX is off and with the defeat function sound is a lot cleaner. EQ is also flat but like I said need to master the HU and also spend some time tweaking the amp.
Can only expect good things to come from here on!!
Re: reptile it his the alpine headunit that he had lent to the madmullah that Im now using. So no graphic stuff for you sorry
Old 18th February 2008, 19:20   #25
reignofchaos's Avatar
Thanked: 1,303 Times
Congrats . When do I get an audition? Wanna know what this illusion mania is all about.
Old 18th February 2008, 19:31   #26
shrivz's Avatar
Thanked: 92 Times
Soldier! the Lucents are laid back.. I found them really laid back in amey's car..
Well.. keep us updated on what was the culprit..
cheers!
shrivz is offline   Reply With Quote
Old 18th February 2008, 21:02   #27
v1p3r's Avatar
Thanked: 27 Times
When? Maybe you didn't do it right. After all, every reptile has his price.
Old 19th February 2008, 00:58   #28
Thanked: 13 Times
Thanks ROC, audition can be had anytime your to come by. Hopefully soon I will have a sub to match the lucies.
Shrivz mamu, woh sahi baath hai. Need to consider all the suggestions given by Zak and B&T at leisure and check / tune thoroughly. Also the amp.
Old 19th February 2008, 02:55   #29
Thanked: 17 Times
Oh my gosh! Some reptiles forget what happened around them when they're busy sinking themselves into Zingers and Maharajas (the latter doesn't digest well in some reptile's stomach either).
I also offered him a Pioneer DvD HU if he allows me to keep this. But sometimes, he talks sense and said no!
Old 19th February 2008, 08:46   #30
hydrashok's Avatar
... I also offered him a Pioneer DvD HU if he allows me to keep this. But sometimes, he talks sense and said no!
So the alphanumeric reptile does know his ICE
Around Pune: Dancing in the rain, Dancing on the roads & Going Green - Tamhini pjbiju Travelogues 17 24th July 2013 10:08
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
