Old 21st January 2008, 18:49   #16
Thanked: 13 Times
Originally Posted by low_bass_makker View Post
Ok took out few of my instruments and did some measuring. Test was a comparison of two different wires.
Thats the thumb of a master installer
Good work!! this will help the DIY people and those on a budget. After reading Sam & your writeup on the power cables thread it helped me assist my friends in building their system on meager budgets. Its funny how people suddenly change their opinion and say the setup doesnt sound good when they find out the cables are not branded for car audio.
Copper is Copper is Copper, baaki the quality you please tell us.
Old 21st January 2008, 20:07   #17
i have been unable to find a place in mumbai that sells 10sq or 8gauge finolex power cable .
i have tried the electrical market in south mumbai called "lohar chawl".
they stock finolex there but when i enquired about my purpose they said i needed finolex "Auto" cables which they didnt have.
help.
i would also like help with an installer in mumbai, specially someone who can do some fibre glass work.
i have a getz and i plan to install rear 6*9's on the boot sides (not on rear parsel shelf).
since i would like to have a neat clean look and DONT want BOXs i was thinking a fibre glass moulding that would allow me to install the speakers on the boot sides is a good way of maximising boot space.
please help with such an installer.
khuz1979 is offline   Reply With Quote
Old 21st January 2008, 21:06   #18
DerAlte's Avatar
Thanked: 2,879 Times
Try any other brand such as L&T or Havell. It need not be auto cables, as long as it is a reputed BIS-marked multi-strand cable.
Good idea, that! But it need not be FRP - you can use 0.75" MDF too for the same job. You just need a good carpenter to make it look OEM. Navin or @b&t can suggest an installer who can do FG.
Old 21st January 2008, 21:52   #19
adityamunshi's Avatar
Please answer my question too !!
Originally Posted by adityamunshi View Post
adityamunshi is offline   Reply With Quote
Old 21st January 2008, 21:53   #20
Gill's Avatar
Thanked: 12 Times
LBM bai ji n Deralte,
Great write up's,helped a lot in knowing things better!!DerALTE,i took time to understand your post though!!
LBM BAI ji,it would be more helpfull if you conduct the copper test of two cables,if possible of different brands of cable.Put up the findings in the STICKY thread which is on power cable..
Cheers!
Gill is offline   Reply With Quote
Old 21st January 2008, 22:17   #21
Thanked: 294 Times
So the normal house hold wire company fall short by approx 1 mmsq from what they claim it to be so it is less than 1 % short.
Normally if we take 4 awg wire it is compared to 25 mmsq indian wire so we are 6 mmsq short that is nearly 25 % less. But according to the American standard it is 21.3 mmsq so we are approx 9 % short still.
Few correction guys the house hold wire is 4 % less and according to the AWG standard it is 11 % short.
Sorry for the error.
Old 21st January 2008, 23:48   #22
blueraven316's Avatar
Thats a pretty decent RC cable, Have been using Scosche cables for a long time for many installs and none have given a problem till now. Good VFM, but you can get it in India itself for Rs 750, so buying on crutchfield is no sense at all.
blueraven316 is offline   Reply With Quote
Old 22nd January 2008, 05:08   #23
ScarySkulls's Avatar
Thanked: 19 Times
The outside diameter of the household wire is 11.1 mm and that of the caraudio wala was of 10.5 mm. It show that the insulation is thicker in the case of caraudio wala cable
Car Audio cable has lesser outer diameter and that shows that it has thicker insulation.
Please explain.
P.S.>> Mitutoyo is very accurate. I have used it in bikes, and can confirm the accuracy part. What model are you using?
ScarySkulls is offline   Reply With Quote
Old 22nd January 2008, 05:48   #24
aah78's Avatar
Thanked: 1,751 Times
Arrow eBay
Have you tried eBay? The Scosche kits are available for $10 ($25 incl. shipping within the US).
I agree - you can use Crutchfield as a base for what you're looking for and buy it from elsewhere - cheaper. No sense having your friend lug just a pair of RCA cables all the way across a few continents & oceans.
aah78 is offline   Reply With Quote
Old 22nd January 2008, 10:03   #25
How good are the Rockford fosgate cables ?
Old 22nd January 2008, 11:13   #26
panky12345's Avatar
Thanked: 150 Times
WOW! thats some interesting findings LBM. Given the differences as you pointed out, I think its wiser to go in for household wala cables (yeah I have savings on my mind!) as (to me) apart from the flexibility issues, there's nothing much to gain. Baaki toh, there is no end to spending money (I think I'll leave it like this else you'll get offended ;-))
Thanks for the inputs, but couple of things here:
1. Please go ahead with copper testing and post the results here. I'm supposed to buy cables and this would be something helpful to me.
2. Please let us know the brand names of the wires that you used.
Old 22nd January 2008, 11:39   #27
Bass&Trouble's Avatar
Thanked: 71 Times
Abe LBM, kya yaar? Pet pe laat? Just ordered a big shipment of uber cool cables.
I'm sure you can do 6dB more than your current XXX.X dB if you use my high quality car audio cable.
Old 22nd January 2008, 13:15   #28
navin's Avatar
Thanked: 4,286 Times
Like I said earlier car audio cable is usually more flexible than typical power cable. Also some power cable is not OFC and that reduces it's conductivity.
But if one got typical multistrand power cable that was as flexible and had the same grade of copper as the power cable used in audio it would work just as good.
Old 22nd January 2008, 13:33   #29
panky12345's Avatar
Thanked: 150 Times
and one good desi brand would be ???
Old 22nd January 2008, 15:17   #30
panky12345's Avatar
Thanked: 150 Times
They make some really nice speaker cables. Stick to monster, if getting from US. You'll find some great deals @ ebay.
DIY Interconnect cables. need help. clipto333 In-Car Entertainment 15 30th July 2007 16:45
Malfunctioning cables, help honda_dude Modifications & Accessories 1 12th March 2007 17:09
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
How to determine what size Power Cables for ICE? Answers inside... gunbir In-Car Entertainment 96 8th May 2006 11:34
