Old 22nd January 2008, 15:36   #31
Sam Kapasi's Avatar
Thanked: 1,473 Times
I am going to put a Finolex subwoofer in my car. Then I'll show you silly fellows.
Old 22nd January 2008, 16:05   #32
vebmetal's Avatar
Thanked: 15 Times
But if one got typical multistrand power cable that was as flexible and had the same grade of copper as the power cable used in audio it would work just as good.
How much would this cost? (i.e. for installing one 4 Ch amp, 60W x 4 RMS driving 2 front components and one 12" sub).
vebmetal is offline   Reply With Quote
Old 22nd January 2008, 17:17   #33
reignofchaos's Avatar
Thanked: 1,302 Times
Err pardon me but why is everyone recommending monster? Atleast for home audio, monster cable is overpriced generic crap. Are they any good for car audio?
Old 22nd January 2008, 17:29   #34
Thanked: 13 Times
8 gauge is more than sufficient in your case(as long as you dont plan to do any serious amp upgrades). So you need to purchase 10sq mm of any good brand of household cable.
Do a search it's been discussed as much as Bhajji's supposed abuses.
Recommended Power and Ground Cable Sizes
Old 22nd January 2008, 22:58   #35
Thanked: 294 Times
where are the links Sam Bhai. We all at T-bhp wanna see.
Old 23rd January 2008, 11:10   #36
navin's Avatar
Thanked: 4,282 Times
You mean bus-bar right?
Old 23rd January 2008, 11:33   #37
Bass&Trouble's Avatar
Thanked: 71 Times
Cannot more agree with you. But I think the suggestions are based on the fact that if you can get it for the price of crap, get it.
Old 23rd January 2008, 12:47   #38
iraghava's Avatar
Thanked: 156 Times
What a fitting reply!
Old 12th November 2009, 18:06   #39
Mi10's Avatar
Thanked: 1,459 Times
First things first, the 3 page of gyan just refused to get into my head.
and now to my question
My Amp's (RF Prime 500.1) recommended Power wire Gauge are 4 AWG and Speaker wire gauge are 8 AWG.
Can i use a 1/0 AWG kit for the Power wire. (assuming that i use 8 AWG for speakers)
If yes, will it harm my Amp or Sub in any way ?
Thanks in advance
Mi10 is offline   Reply With Quote
Old 12th November 2009, 21:39   #40
Thanked: 39 Times
Thanks in advance
Mi10, what you are asking is essentially this:
My wife's mother recommended a 18 karat gold necklace. Can I get a 22 carat necklace for my wife? If yes, will it harm her neck in any way?
Now go figure
greenh0rn is offline   Reply With Quote
Old 12th November 2009, 21:41   #41
karankapoor's Avatar
If the recommended wire gauge is 4 gauge then why you want to use a 0 gauge wire ?
If you are running more then 2 amps on the same cable say about 1kw load then 2 gauge wire will work you can use the 0 gauge cable also incase you are planning a bigger amp/amps in near future. Use this cable till the D.Block, From there you can use a 4 gauge cable to hook the amps.
For speaker and sub wiring use 14 gauge for speaker and 12 gauge for sub-woofer.
karankapoor is offline   Reply With Quote
Old 12th November 2009, 22:42   #42
somebodystopme's Avatar
Thanked: 17 Times
Now go figure
LOL nice one buddy. Howz you??
@mi10. You can use any 25sqmm cable in place of 4AWG (which is exactly 21sqmm) available in your local electrical market take 6-7 Meter of the cable should suffice. There shouldnt be no harm even if you use 0AWG which is approx 50sqmm. Just the cost of cable increases.
Cheers.
somebodystopme is offline   Reply With Quote
Old 13th November 2009, 00:04   #43
Thanked: 294 Times
Now go figure
LOL nice one
For speakers 14 (2 mmsq) gauge is good but for the sub I would not use anything below 10 (5 mmsq) gauge. I am using 8 gauge my self (8 mmsq) it help in keeping the damping factor high.
Cheers.
Very true.
I think he is saying 1/0 that is 70mmsq that would be overkill. 0 gauge (50 mmsq) that is more than enough for even three amps.
Old 13th November 2009, 00:27   #44
Originally Posted by low_bass_makker View Post
but for the sub I would not use anything below 10 (5 mmsq) gauge. I am using 8 gauge my self (8 mmsq)......
I think you wanted to say use anything below 10 gauge.
What if the 3 amps are rated at 1000 to 1500 wrms each .
Old 13th November 2009, 01:11   #45
Thanked: 294 Times
Yes, In gauge lower is thick and in MM it is done via cross-section area.
If the amps are lets take 1250 rms and take them as d-class becasue class ab high wattage amps are rare so there final load would be 1250 / 0.9 -> 1388 watts and that woud be 1388 watts / 12 volts -> 115 amps. So for three amps it would be 346 amps...Hmm YES it can work very fine. Also in Car amps the current rating is not continous duty like in industrial applications. So the wires can be a bit overrated.
Here is a chart for the same.
Originally Posted by gunbir View Post
This will help:
In the above photos the 1/0 wire is take which is 53 mmsq which can take 350 amps so 70 mmsq would surely take much more. Also the amp taken above is a Class AB which are 50 % efficient. But Class D are more efficient in range of 80-90 %.
DIY Interconnect cables. need help. clipto333 In-Car Entertainment 15 30th July 2007 16:45
Malfunctioning cables, help honda_dude Modifications & Accessories 1 12th March 2007 17:09
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
How to determine what size Power Cables for ICE? Answers inside... gunbir In-Car Entertainment 96 8th May 2006 11:34
