Old 13th November 2009, 07:37   #46
Mi10's Avatar
Thanked: 1,455 Times
I am planning to run 3 Amp Set up.
one 2-Ch for front stage
one 2-Ch for rear fills
one Mono for Sub stage
Will one 0/1 AWG POwer kit suffice this requirement or it makes sense to buy a 4 gauge dual Amp power kit ?
Mi10 is offline   Reply With Quote
Old 13th November 2009, 09:58   #47
Thanked: 39 Times
Hi mate, just wanted to understand why are you going for two 2-ch amps for your frontstage and rearfill instead of a single 4-ch (unless you already have 2 amps lying around)- because a single 4-channel amp would be more cost-effective (VFM, consider 1 DLS RA40 vs 2 DLS RA20s), needs less space in the car and less cabling, so less strain on electrical system and less chances of anything going kaput.
greenh0rn is offline   Reply With Quote
Old 13th November 2009, 10:27   #48
Mi10's Avatar
I get your point.
But, My front stage needs more power than my rear fill. THere is no such amp (within my budget) that gives differential outputs except the JL 450/4 V2.
I know its a tremendous amp but, it weights close to 20 pounds. And My sources in US cant carry anything above 15 Max. Also, its priced above $450 which is a strech in my budget.
That leaves me with two choices;
one to forget about the rears, and
other is to get two 2 Ch Amps.
i wanted to buy a good AMP kit thats when i got confused about tall these gauges and measurements.
An help in deciding the Amp kit would bgreatly appreciated
Both the two Ch give out less tha 130 RMS per Ch @4 Ohms
and My Mono rated at 320 RMS@ 4 Ohms
Old 13th November 2009, 12:45   #49
Thanked: 39 Times
Which 2-ch amps do you have in mind?
Old 13th November 2009, 12:47   #50
Mi10's Avatar
RF Power T400-2 (120W RMS x 2; 400W RMS Bridged)
and
RF Punch P300-2 (75W RMS x 2; 300W RMS Bridged)
Old 13th November 2009, 13:02   #51
Thanked: 39 Times
Hmm as LBM says, a 0-gauge cable going into a distri block would be much more than enough- from the block you could feed 4-gauge to mono and 4 or 8-gauge to each of the two-channels.
What this setup gets you is one less cable running from your battery to the amps- so theoretically, lesser chance of EMI.
DIY Interconnect cables. need help. clipto333 In-Car Entertainment 15 30th July 2007 16:45
Malfunctioning cables, help honda_dude Modifications & Accessories 1 12th March 2007 17:09
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
How to determine what size Power Cables for ICE? Answers inside... gunbir In-Car Entertainment 96 8th May 2006 11:34
