Old 1st February 2008, 10:37   #16
navin's Avatar
Thanked: 4,286 Times
Originally Posted by adityamunshi View Post
I have another question about amps, Other than making the music louder, how does the amp help ?
an amp can control your speakers better and hence not only can you play louder but you will find that the bass is better defined. A good amp that complements your speakers will also make the mids and high frequencies sound smoother.
Old 1st February 2008, 11:03   #17
nishantgandhi's Avatar
Thanked: 151 Times
In the context of my setup, (four speakers running off the HU) what will be the difference at the same volume ?
I am no ICE guru, but from what I have learnt and gathered on TBHP forum - an amp helps deliver cleaner, richer sounds. There is less to almost nil distortion (unless of course you crank up the volume to the max!). Basically the HU in built amp is of a low power rating so it cannot provide adequate juice to the speakers and hence the sound will not be amazing. It will be good nonetheless, but not best.
It's like the difference between 'a must have' vs 'a nice-to-have'
nishantgandhi is offline   Reply With Quote
Old 28th February 2009, 00:23   #18
Question humming sound from the amp.
well i have a question. my speakers make a very irritating humming sound all the time . the mechanic says that its because of the amplifier and this happens in case of every amp. Is it true ? I have even got a noise filter installed. what is the solution to this problem ?
manujkansal is offline   Reply With Quote
Old 28th February 2009, 00:39   #19
abhinav.gupta88's Avatar
Thanked: 310 Times
Aha,
You've got pioneer right?
Does it increase with RPM.
Is it like a whistle?
Old 28th February 2009, 00:55   #20
no it is not that. that is the sound of race . well that is not the case with me. actually its a general humming sound which increases with increase in volume.
Old 23rd June 2009, 17:50   #21
Sportsmind's Avatar
Thanked: 28 Times
Red face Amp heating
I had my ICE upgrade completed last week, with a hertz amp and a polk sub. The amp is installed under the front passenger seat. I have been observing that it gets heated very fast. Is this normal. Hope there is no need for worries when i do the long trips of 8 and 10 of drives, when i normally have the ICE running non stop.
Sportsmind is offline   Reply With Quote
Old 23rd June 2009, 18:31   #22
Sam Kapasi's Avatar
Thanked: 1,473 Times
Amplifiers do get hot, quite hot in running.
However if your amplifier is heating up to I-cannot-touch-it hot in a few minutes of switching it on, you may have a problem.
If you want to be sure that there is no short-circuit, turn the amplifier on with no volume and leave it on for a few minutes. The amplifier should not be hot to touch, just warm. If it is still hot, you have a problem.
Old 23rd June 2009, 19:19   #23
Sportsmind's Avatar
Thanked: 28 Times
Thanks sam, shall do the checks as you mentioned.
Old 23rd June 2009, 21:22   #24
Thanked: 39 Times
Sam what part inside would be the problem here- can't imagine the entire board heating and transferring its heat to the outer casing.
greenh0rn is offline   Reply With Quote
Old 24th June 2009, 00:28   #25
ghpk's Avatar
Thanked: 193 Times
It should be your Power IC or Power Transistor which gets heated up.
Wrong connectivity/improper grounding can be 2 prime causes.
Old 24th June 2009, 01:50   #26
Turbo Head's Avatar
Thanked: 83 Times
Check it out for proper earthing, that is the culprit most of the time, the headset and the amp both have to be grounded properly to avoid any sort of humming.
Aha,
Dude it has nothing to do with pioneer
Any headset/amp which is not grounded properly will do this
Turbo Head is offline   Reply With Quote
Old 24th June 2009, 10:15   #27
navin's Avatar
the borad is not phyically connected to the casing (which usually is also the heat sink). If the output transistors are being forced to carry too much current then they will heat up and since they are connected to the casing (heatsink) the caing will heat up. The cause for this however could be anything from a short (usually short circuit protection will trip), to a passive component going south and hence dumping too much bias current into the output transistors etc..
Old 24th June 2009, 13:23   #28
Thanked: 39 Times
Thanks Navin. My other query was about the casing/heatsink- many guys (including me) put the amp on the back of the rear seat in a hatch, so suppose if we are packing the boot with bags for a trip, which will effectively suffocate the amp (some bags might get touchy-feely with the amp's casing)- will this affect heat dissipation majorly, causing either of a) amp tripping, b) bags catching fire?
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Help: Setting amplifier amit_sound In-Car Entertainment 11 9th March 2007 09:15
Help me with my amplifier WILDTHING In-Car Entertainment 1 2nd January 2005 11:32
best subwoofer-amplifier combination for Rs.10-15k nitrous In-Car Entertainment 14 1st November 2004 13:21
Pioneer Speakers - Which one with 944 amplifier? GTO In-Car Entertainment 7 12th May 2004 22:40
