Old 4th April 2008, 22:21   #16
Thanked: 41 Times
Originally Posted by low_bass_makker View Post
Hmm yes you are right. I think monty9991 was getting confused with woofer t-nuts.
well i meant these Tnuts for fiberglassing not for making MDF woofer box.
monty9991 is offline   Reply With Quote
Old 5th April 2008, 00:35   #17
Thanked: 294 Times
Only the name is common but the purpose of this t-slot nuts is quite different and unique.
Old 5th April 2008, 08:10   #18
headers's Avatar
Thanked: 464 Times
Correct..
Old 5th April 2008, 12:20   #19
asejwal's Avatar
Thanked: 15 Times
Default Dear LBM!
Forgive my ignorance....But what sort of a subwoofer is that? Why is it so massive at the bottom and what does it achieve with that heavy a bottom?
I hope you'll reply to my stupid question!
asejwal is offline   Reply With Quote
Old 5th April 2008, 12:50   #20
Thanked: 294 Times
No your question is not at all stupid. But I think some times my question are stupid.
Anyways it is a SPL subwoofer here are its specs..
:: Ground Zero :: Subwoofer / GZPW 15
Old 5th April 2008, 15:11   #21
Thanked: 41 Times
you are right.
Old 5th April 2008, 20:29   #22
vikram_d's Avatar
Thanked: 940 Times
@LBM - I would recommend you also get lock nuts for the allen screw setup that you have done. Or at the very lest get some spring washers. Either of these things will ensure that the screws dont loosen over extended periods of time.
Old 5th April 2008, 23:42   #23
Thanked: 294 Times
Hmm I agree. I also planned to use the loctite thread locker solution also.
Old 6th April 2008, 02:15   #24
vikram_d's Avatar
Thanked: 940 Times
Loctite will also work.
