Old 3rd February 2008, 14:30   #31
Thanked: 294 Times
Chalo till then we will wait..
Old 3rd February 2008, 16:17   #32
navin's Avatar
Thanked: 4,286 Times
Originally Posted by Bass&Trouble View Post
Since you mention that the noise vanishes when you run the sub using the rear pre-out, this has something to do with the head unit's subwoofer pre-out . Show a good technician please.
this is what lead me to believe that the pre out RCA might have got hit in transit and caused a loose solder on the PCB. In our days they used to screw th RCA to the back panel but today the RCAs are soldered directly to the PCB.
Originally Posted by Sam Kapasi View Post
I need to know - The noise - is it a Krrr krrrr, gssss gssss, prrp prrrp or a klick klick.
Johy, the sounds Sam are refering to might have nothing to do with audio. ;-)
Old 4th February 2008, 20:34   #33
johy's Avatar
Thanked: 373 Times
Infractions: 0/1 (5)
Lightbulb Update: El-Chepo solution?
Well folks, today morning I called the Clarion Distributor for India in Delhi (Supreme Audiotronics Pvt. Ltd. @ 11-25791140) to direct me to the nearest authorized service center and hey presto they tell me there is a center in Siliguri. I get to that place first thing and after the technical spent a greater part of one hour on the HU, checking for loose solder, etc., concludes he can't find anything wrong. What he does is removes the solder for the preouts and resolders them. Anyways.
So this evening I take my car to the installer to try out the resoldered HU and no luck! Same old scratchy sound.
Then he says let me try one last thing, gets this El-Chepo "Chicago 5-band in dash graphic equalizer with line driver" and connects the sub's RCAs via this gadget and OMG the scratchy sound is gone!! He says the gadget is working as a "filter." Any ideas folks how to explain this? I am dumbstruck. Thinking of going ahead and ordering a better equalizer for the same task, not for any equalizing functions, but really for the filtering.
I don't want to go back to the Pioneer 5850 HU after listening to this Clarion.
So is this the solution (pic below). Alternatives?
Edit: ImageShack seems to be acting up, not able to post a pic of the Chicago eq.
johy is offline   Reply With Quote
Old 4th February 2008, 21:01   #34
Bass&Trouble's Avatar
Thanked: 71 Times
When connecting the Chicago, are you sure he used the sub output of the head unit to connect to the input of the equalizer? Or did he use some other output like front/ rear?
Anyway, try using a ground loop isolator before jumping into an equalizer.
Old 4th February 2008, 21:11   #35
johy's Avatar
Thanked: 373 Times
Ajay ji,
I am sure he used the violet preout for the sub from the HU. I cross-checked by increasing/decreasing the Sub volume from the HU (which does not increase/decrease when using the front/rear preout). Also, the installer turned off the Eq function on the Chicago Eq, but kept it powered on -- and the scratchy sound was not there (both with and without Eq function on).
Please tell me what an Ground Loop Isolater is.
The very first day of install, the installer did use a "filter" which looked somewhat like this
http://www.team-bhp.com/forum/iipcache/120089.jpg
It did not help. Is the ground loop isolator different from a so-called filter?
Old 4th February 2008, 21:19   #36
Thanked: 71 Times
What you have posted is indeed a ground loop isolator.
Let me get back to you tomorrow on this. Will ask around if anyone else with Clarion head units ever faced a problem like this.
Old 4th February 2008, 21:22   #37
johy's Avatar
Thanked: 373 Times
Okies, but the one I saw said "filter," and not "ground loop isolator." Look forward to your input. Also, will specifically ask the installer if he has a thing sold by the name "ground loop isolator."
Old 4th February 2008, 22:16   #38
Thanked: 26 Times
Ajay, after upgrading from the Pio 5750 to the Clarion DXZ775USB, i did face the problem of hissing and clicks while using the horn, the problem surfaced in the speakers & not the sub. It was infuriating.
The installer tried everything and yet the problem persisted. All the options mentioned here were tried out. Even i'd read about noise suppressors/ ground isolators and thought that the isolator was my only hope. But then, as a last resort, we changed the RCA's and presto, the clicks & hisses were gone.
Funnily, the same RCA's were in use with my previous HU and the problem never arose. Just a change in HU and this is what hit me. Anyways, as they say, alls well that ends well.
Hope this helps.
St. Anger is offline   Reply With Quote
Old 4th February 2008, 22:28   #39
Thanked: 294 Times
Johy I think try what St.Anger is saying maybe it might help.
Old 5th February 2008, 07:17   #40
johy's Avatar
Thanked: 373 Times
Hope this helps.
Wow St. Anger, your problems seem so very identical to mine!
Please tell me which RCAs you were using previously and which ones you changed to. I am using a Scosche now and the reason we did not try changing the RCAs was that these are good ones. Still, I can try some other ones and see.
The preouts of the Clarion are all high voltage (5.6 volts if I am not mistaken). Maybe that is the reason?
Hope it works - will try it today.
Old 5th February 2008, 10:03   #41
Thanked: 26 Times
Lightbulb
I was using RCA's by Kicker. Funnily, though the sub RCA was the same, though an older series, that particular one remained unaffected. Am currently running two RCA's of unknown parentage but my problem's solved.
Am going to test them out again today as one opinion i got is that sometimes a particular RCA might not be compatible(didn't know that RCA's had compatibility issues) still, am doing up an uncle's marina today and plan to continue with those RCA's if they work fine.
Will report back tonight.
My hunch is that the HU is fine, the source lies elsewhere. Meanwhile, try lowering the gains on the subwoofer and see if that has any effect.
Old 5th February 2008, 11:02   #42
Thanked: 294 Times
No this cant be the reason.
Old 5th February 2008, 11:21   #43
johy's Avatar
Thanked: 373 Times
@Thanks LBM.
@St. Anger and B&T Tried changing the RCAs to Earthquake. Tried the Ground Loop Isolator - no luck :-(
Seems I have to go for an equalizer now. I have the option of taking the Chicago one. Any other suggestions?
Old 5th February 2008, 13:21   #44
Sam Kapasi's Avatar
Thanked: 1,473 Times
Oh for God's sake. Why would you buy a nice HU and connect it to a Chicago equalizer.
Johy, I am afraid I simply cannot allow you to do this. There has to be another way around this.
Old 5th February 2008, 14:53   #45
johy's Avatar
Thanked: 373 Times
I know Sam, I am just frustrated. The Chicago Eq is an insult to the HU.
My options:
1) Live with the scratchy sound (you can barely hear it with the music playing) - but just that thought it is there drives me crazy.
2) Get it repaired (seems unlikely)
3) Dump this HU and get a new SQ HU. Can't live with the old Pio 5850 now.
4) Any other solutions? An Alpine Equalizer? Or a Kicker? Or a Clarion?
Defective Skoda Laura? Nope, defective dealer! Sam Kapasi The Indian Car Scene 146 22nd April 2018 21:41
Clarion Vs Alpine Vs Pioneer Vs Kenwood EDIT - Its a Clarion DXZ 785 USB Invinsible In-Car Entertainment 797 2nd June 2012 20:49
Jarring noise front brand new left front speaker skrules In-Car Entertainment 13 26th December 2011 10:53
Its Clarion's small brother with +bonus! ( Clarion 576 usb ) Dhams In-Car Entertainment 51 28th February 2010 23:25
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
