Old 9th February 2008, 12:08   #31
Thanked: 294 Times
Look at Qms. Also I suspect that the BL and Mms numbers of the IDMax will be higher (than those of the IDQ) but the BL/Mms ratio of the IDmax will be lower than the IDQ.
my guess is that in a ported box the IDq will play louder than the IDmax while the IDmax will suit a sealed box more.
BTW you will not need the full 500W to push the IDQ (in ported box) to it's limit though. It is not the ammount of power you use but the highest clean/transient perfect SPL one can achieve that is important.
Navin Ji I agree with you 100 % one does not need so much power to play music. SPL is another story. I was just comparing the two at same power level.
BL -> The magnetic strength of the motor structure. "Expressed in Tesla meters, this is a measurement of the motor strength of a speaker. Think of this as how good a weightlifter the transducer is. A measured mass is applied to the cone forcing it back while the current required for the motor to force the mass back is measured. The formula is mass in grams divided by the current in amperes. A high BL figure indicates a very strong transducer that moves the cone with authority!"
Mms ->The driver's effective mechanical mass (including air load), in kg. "This parameter is the combination of the weight of the cone assembly plus the ‘driver radiation mass load’. The weight of the cone assembly is easy: it’s just the sum of the weight of the cone assembly components. The driver radiation mass load is the confusing part. In simple terminology, it is the weight of the air (the amount calculated in Vd) that the cone will have to push."
Car Audio: Thiele-Small Parameters
Old 9th February 2008, 12:17   #32
navin's Avatar
Thanked: 4,282 Times
At the same power level...
Firstly putting the IQd in a sealed box would be handicapping that woofer as it is not in it's best element there.
So if you wer to compare the IDq in a ported box and the IDMax in a selaed box both boxes being appropriately designed I would say that the IDq would really rock with a good 100W amp while the IDmax would need a 300W amp to produce the same SPL. Now if you could get the same SPL (and SQ) with less power which woofer would you prefer?
Old 9th February 2008, 12:20   #33
iraghava's Avatar
Thanked: 156 Times
@ Aman - LOL!! Fantastic comparison man!
And I don't think there is no meter to measure horniness of a girl
LBMji please pay a little more attention in the English ki kunji thread by our Yeti Singh! You need it!!
Old 9th February 2008, 12:24   #34
navin's Avatar
I thought we got beyond this *spanking Rags*
Old 9th February 2008, 13:26   #35
amangujral06's Avatar
@navin - when girls step in, no other comparison is big enough
amangujral06 is offline   Reply With Quote
MUL's Dzire,what is exactly wrong? Why So much Delay in delivery? ECM The Indian Car Scene 162 24th August 2010 13:37
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
Not exactly a street Experience pramodkumar Street Experiences 16 29th July 2009 14:23
Health and Fitness of TBHP members. What do you exactly for fitness? anujmishra Shifting gears 2 8th September 2008 12:21
