Old 18th February 2008, 15:58   #31
anonymous's Avatar
Thanked: 15 Times
Originally Posted by vebmetal View Post
Ok then, so these are my best options?
1) Ground Zero 30T
2) Ground Zero TW12MK2
3) JBL CS1204
Can someone mention the prices of all these 3?
anonymous is offline   Reply With Quote
Old 18th February 2008, 16:22   #32
simply_sunny001's Avatar
Thanked: 15 Times
here you go :-
1) Ground Zero 30T --- 6K
2) Ground Zero TW12MK2 --- 5.5K
3) JBL CS1204 --- 4K
simply_sunny001 is offline   Reply With Quote
Old 18th February 2008, 17:19   #33
anonymous's Avatar
Thanked: 15 Times
Originally Posted by simply_sunny001 View Post
here you go :-
JBL CS1204 --- 4K
Is it with enclosure or without?
Old 18th February 2008, 17:47   #34
shuvc's Avatar
Thanked: 287 Times
Without. The CS1204B (I think) with the JBL box has a 7.9 K mrp.
Old 18th February 2008, 18:15   #35
anonymous's Avatar
Thanked: 15 Times
Thank you.
I think you are also running Ground Zero TW12MK2 with KAC8401. Are you satisfied with the performance?
Old 18th February 2008, 18:56   #36
shuvc's Avatar
Thanked: 287 Times
I'm driving the GZ with bridged channels of a JBL 75.4. Underpowered for the sub, but good enough for me. It's nice and punchy.
Old 19th February 2008, 15:03   #37
anonymous's Avatar
Thanked: 15 Times
So has anything been decided yet?
Old 19th February 2008, 16:41   #38
vebmetal's Avatar
Thanked: 15 Times
Waiting for someone to offer me a secondhand one, as a new sub is out of my budget. Classified Ad posted here.
vebmetal is offline   Reply With Quote
Old 20th February 2008, 15:58   #39
anonymous's Avatar
Thanked: 15 Times
One of my friend got JBL CS1204B without box in 2700 (WB&W) and paid 300 bucks for mdf box.
I hope its not fake but he said that when he went to the shop, the guy first asked whether he wanted fake or original product.
The deal is looking yummy. What will be the difference between JBL Box and local box as far as SQ is concerned.
Old 20th February 2008, 16:18   #40
DerAlte's Avatar
Thanked: 2,879 Times
... What will be the difference between JBL Box and local box as far as SQ is concerned.
Possibly non-ideal dimensions - affects intended / expected SQ. Definitely fit and finish.
Old 20th February 2008, 16:38   #41
rocksterraghu's Avatar
Thanked: 97 Times
JBL enclosure for 1204B is simply awesome. Like DerAlte mentioned, the fit and finish, quality of the enclosure and most importantly the size may be compromised. 300 bucks for the enclosure is too low. I suspect some cheap plywood here.
rocksterraghu is online now   Reply With Quote
Old 20th February 2008, 17:28   #42
Thanked: 294 Times
Ya it will be a marine grade wood box. I would not suspect much more there. The 0.75 inch thick MDF is approx 30 per sq feet. If I take a 1 cuft box it will have minimum of 14 inch per side that would be 8.2 cuft of wood include approx 10 % wastage that would be 9 cuft. So the raw material alone would cost Rs 270.
Old 20th February 2008, 17:35   #43
DerAlte's Avatar
Originally Posted by low_bass_makker View Post
Ya it will be a marine grade wood box. ... raw material alone would cost Rs 270.
This crazy man has an HP scientific calculator embedded in his brain!
Old 20th February 2008, 22:52   #44
navin's Avatar
Thanked: 4,284 Times
except that he calculated area in cu.ft!
Old 21st February 2008, 09:09   #45
ScarySkulls's Avatar
Thanked: 19 Times
As LBM pointed out, the raw material alone is almost that much or for maybe a bit more.
Definately not MDF. Particle board maybe.
ScarySkulls is offline   Reply With Quote
Kenwood 8401 vs 8404 adityamunshi In-Car Entertainment 12 22nd March 2009 16:30
bling on with kenwood sub suprateep In-Car Entertainment 24 25th February 2009 15:25
Cheapest SQ sub+amp combo greenhorn In-Car Entertainment 29 18th October 2008 16:51
Wanted: New or Used Kenwood 8401 Amp MillionSwords Shifting gears 0 31st January 2008 17:24
Settings For The 8401 Amp vigsom In-Car Entertainment 0 29th December 2007 21:24
