Old 12th March 2008, 22:56   #61
amit_mechengg's Avatar
Thanked: 1,556 Times
me too in same boat.
Old 12th March 2008, 23:04   #62
abhibh's Avatar
Thanked: 34 Times
Originally Posted by vebmetal View Post
And is the GT5-12 available in grey and at what price?
GT5-12 is available for Rs.3500 with B/W. Grey should be around Rs. 2500
Old 12th March 2008, 23:19   #63
gt5-12 will run underpowered on my sony 2 channel amp thats for sure. it needs 250 watts rms and i can give 130 watts rms
Old 12th March 2008, 23:25   #64
abhibh's Avatar
Thanked: 34 Times
GT5 is 275W RMS and GT4-12 is 250W RMS. I still prefer GT4 series.
I also suggest you change AMP or buy another amp like kenwood 8401 for Rs 4700 and use that amp for sub and sony for speakers.
Old 12th March 2008, 23:36   #65
kenwood specs :
  • Maximum Output Power: 640W
  • Rated Output Power (14.4V )
    60W x 4 at 20-20kHz 0.08%THD (4-Channel Mode) (4 Ohms)
    60W x 2 at 1kHz 0.08%THD + 180W at 1kHz 0.8%THD (3-Channel Mode) (4 Ohms)
    180W x 2 Bridged at 1kHz 0.8%THD (4 Ohms)
    90W x 4 at 1kHZ 0.8%THD (2 Ohms)
it is again the same not enough to power 275 watts
Old 12th March 2008, 23:50   #66
how is the pio 510 amp? its a mono amp
Old 12th March 2008, 23:54   #67
vebmetal's Avatar
Thanked: 15 Times
^ amit, AFAIK (and I am a noob), the RMS powers of the sub/speaker and amp don't need to match up. In fact the amp should be lesser than the sub's rated power, otherwise if you take it to full, you may blow the sub.
e.g. My Illusion EL 6.1 components are rated 75W RMS, but I am only running them off a HU which I think feeds them 22W RMS or so. They still run awesome! (but it means that with an amp they will perform even better!)
So from whatever I have been able to gather from this forum, the 8401 will give you a good enough sound with any of the subs talked about in this thread.
vebmetal is offline   Reply With Quote
Old 13th March 2008, 00:13   #68
but today i saw it practically, when i put my philips sub on jbl 75.4 it sounded much much better than on sony 2 channel, and the same ground zero which played very well on jbl 75.4 didnt sound good on my sony amp
Old 13th March 2008, 00:15   #69
vebmetal's Avatar
Thanked: 15 Times
World of a difference between those two amps!
Old 13th March 2008, 00:19   #70
thats what i think. u need a better power to run those subs. atleast u need a 200 plus watts on ur amp.
Old 13th March 2008, 10:21   #71
zucchero's Avatar
its allways better to have more power(headroom) than to run the subs underpower.if the sub is under power then there are more chances for the amp to clip and the subs to distort.
its allways better that you have powerfull amp and use the GAIN to feed them the correct requirment.
zucchero is offline   Reply With Quote
Old 13th March 2008, 11:09   #72
Thanked: 294 Times
Very true. But it is most difficult to observe that a sub is clipping, where as in the case of tweeter is the most easiest.
Old 13th March 2008, 11:35   #73
swapnil.rahate's Avatar
Thanked: 7 Times
How would the GT 5 sub and GT 5 Amp combination be??? Will it sound good ? What will be total cost of both in mumbai????
swapnil.rahate is offline   Reply With Quote
Old 13th March 2008, 13:09   #74
JayD's Avatar
Thanked: 2,008 Times
The CS 1204(old GT-4) comes to around 2.4-2.5K, whereas the GT-5 is around 2.9-3K in grey. I'd say would be the best options in this price range.
Old 13th March 2008, 13:53   #75
vebmetal's Avatar
Thanked: 15 Times
These prices sound good! So out of the CS1204 and the GT5, which would sound better off a Kenwood 8401 feeding it 180W RMS?
Kenwood 8401 vs 8404 adityamunshi In-Car Entertainment 12 22nd March 2009 16:30
bling on with kenwood sub suprateep In-Car Entertainment 24 25th February 2009 15:25
Cheapest SQ sub+amp combo greenhorn In-Car Entertainment 29 18th October 2008 16:51
Wanted: New or Used Kenwood 8401 Amp MillionSwords Shifting gears 0 31st January 2008 17:24
Settings For The 8401 Amp vigsom In-Car Entertainment 0 29th December 2007 21:24
