Old 18th February 2008, 18:21   #1
NOTORIOUS's Avatar
Thanked: 89 Times
Default Help to hook up a mp3
A Warm Hello To All
I want a simple question which i myself cant figure it out .i have this HU in my friends car and now i want to hook up a MP3 player to it. i have a cable with me which has a 3.5 mm head phone pin and on other side, it has 2 rca pins. now the question is that does it have a aux input ?????
i have searched on the net and found this
  • Auxiliary Input CD-RB10 or CD-RB20 required
please help me ASAP !!!!
This is the HU
This is the cable that i have
waiting for your replys
NOTORIOUS is offline   Reply With Quote
Old 18th February 2008, 18:25   #2
Thanked: 13 Times
Even if the HU has an aux in, you need an RCA cable with single 3.5mm jacks at either end.
The manual should tell you if it has a 3.5mm aux. If no and the HU has CD changer module at the back then you need to use the following jugaad : Pioneer IP-BUS Hack
Old 18th February 2008, 20:36   #3
NOTORIOUS's Avatar
Thanked: 89 Times
Originally Posted by NOTORIOUS View Post
A
How much they cost???? Any Idea where i can get them in delhi. i know only one place and one person in delhi, Gunbir Ji from Driven
Old 18th February 2008, 20:48   #4
DerAlte's Avatar
Thanked: 2,879 Times
Yes, the Pio manual for FH-P5000MP says you need those cables that you mentioned (CD-RB10/20) for connecting the EP-to-RCA cable that you have.
Is the HU in India or in US?
LBM-maharaz, your wizardry is required for this: does he need to buy the cable or is there an ersatz available? Is the Pio cable readily available?
The method in S0uljah's link should also work, One wouldn't expect the IP-Bus pin-out to be different.
Old 18th February 2008, 21:58   #5
NOTORIOUS's Avatar
Thanked: 89 Times
Thanx For THe Manual
It Is in India
LBM Ji , Kitthe Ho ????
I dont want to do this because HU is not compleatly mine
Old 18th February 2008, 23:34   #6
rohan_fonseca's Avatar
Tried that works well.
rohan_fonseca is offline   Reply With Quote
Old 19th February 2008, 11:44   #7
Thanked: 13 Times
You dont have to do any mods to the HU and the hack works like a dream.
If your friend can afford the original cable then go for it... these cheap 10rs sasta jugaad type stuff is exciting though
Old 19th February 2008, 13:39   #8
Thanked: 21 Times
Cool
Yup the jugaad will work just fine. But if you want a ready made solution you can ask Rana @ Driven. I remember they used to have them.
Old 19th February 2008, 18:39   #9
NOTORIOUS's Avatar
Thanked: 89 Times
Thank You Very Much For Your Help Sir
Any reliable Place in delhi where i can go for this jugaad ????
Old 12th January 2009, 16:26   #10
Shakensoul's Avatar
Thanked: 222 Times
Hey ICE gurus, need help with a basic and repetitive question
I have a Sony CDX-F7700 HU which does not have USB support. I am pretty satisfied with the CD playback quality, however the CD burning task has got boring. Now I want to connect a normal MP3 player (not an IPOD) through the stereo headphone jack of the MP3 player to the AUX-in at the rear of the HU. Do I need a simple RCA to stereo cable to be able to connect or any other specific cable ? How will be the sound quality ?
Link to the HU specs.
CDX-F7700 (CDXF7700) : Manual : Car audio : Sony
Diagram of the back of the Sony HU.
Shakensoul is offline   Reply With Quote
Old 12th January 2009, 17:01   #11
Thanked: 89 Times
Notorious, The wire won't cost you more than 10 or 20 bucks, get it from nehru place. I'm slightly disoriented at the moment. Have u figured whether the player has aux in or not?
sukrit7 is offline   Reply With Quote
Old 13th January 2009, 11:08   #12
DerAlte's Avatar
The AUX-in is the left-most pair of RCA sockets, indicated in the diagram by "BUS AUDIO IN / AUX-IN".
Ask for an EP-to-RCA converter cable - one end will have the plug that goes into the headphone socket of your MP3 player, the other end will have a pair of RCA plugs that go into the RCA sockets of the HU.
Help needed for installing a rear tow hook on Ford Endeavour Gill22g 4x4 Vehicles 6 27th September 2011 14:22
Bull Bar, Rallye 3003 & Pintle Hook gd1418 Modifications & Accessories 4 3rd February 2010 12:21
CD MP3 or DVD MP3 player - Budget 10K romyeo4u In-Car Entertainment 8 28th January 2010 17:42
JVC SV3104 VCD/MP3 player fitted. Need help on VCD screen v12 In-Car Entertainment 2 5th September 2005 09:38
