Old 25th February 2008, 20:59   #1
dinu2506's Avatar
Thanked: 349 Times
Default Advice on DVC subs
Dear Gurus, I have recently upgraded the audio on my Honda Civic with a 4 channel amp for the 4 speakers and a monoblock amp for the sub.
I have a JBL GT5 12" sub that has a 4 ohm impedence. My monoblock is a JBL GTO3501 with 225W RMS at 4 ohm and 360W RMS at 2 ohm. Since my sub is a 4ohm impedence, the mono pushes only 225W RMS. What are my options for presenting a 2 ohm load to the amp so that it can push its full 360W. I do not want to add one for sub in parallel.
If I put a 4 ohm dual voice coil sub and wire it in parallel, I should be able to get a 2 ohm load. Will this be a good option to fully exploit the mono amp? If so, can you suggest some brand of subwoofer that has a 4 ohm Dual voice coil that can be wired in parallel. I searched the site but JBL only has 2 ohm dual voice coil sub, which if wired in parallel will present a 1 ohm load which my amp cannot run.
Seeking your advice on this and let me know the approx price. I can use the existing enclosure, so looking for a 12" sub.
dinu2506 is offline   Reply With Quote
Old 25th February 2008, 23:30   #2
nitrous's Avatar
Thanked: 285 Times
JBL has a GTO 1204D sub which is a 4 ohm DVC.
There is this Ground Zero 400W, 4 ohm DVC which is highly recommended and costs around 5.5k.
Old 26th February 2008, 00:56   #3
Thanked: 294 Times
You will be happy with 225 watts of power. Try to listen to it first before going further. Or you can go to a shop compare the sound of a 4 ohms DVC sub if you find it better go for it. Like nitrous has mentions two subs.
Old 26th February 2008, 01:29   #4
shuvc's Avatar
Thanked: 287 Times
Which Ground Zero sub is this?
Old 26th February 2008, 01:51   #5
Thanked: 294 Times
I think nitrous has mentioned the Titanium series sub but they are 4 ohms SVC.
Old 26th February 2008, 08:39   #6
dinu2506's Avatar
Thanked: 349 Times
Thanks Nitrous. I checked the JBL site and this model is not shown. Only GTO 1202D which is a 2 ohm DVC. Has it been discontinued and if not, what is the price?
Thanks for the advice LBM. I will try and audition before going for anything.
Also reminds me, Gurus, are there any 2 Ohm SVC's available in 12" and would be great to know the price as well.
Last edited by Technocrat : 26th February 2008 at 08:51. Reason: Consecutive Posts Merged
Old 26th February 2008, 10:54   #7
sonic_boom's Avatar
Thanked: 12 Times
If you are looking for VFM then you can go for Pioneer TS-W307 D4. It's available for around 3-3.5K in delhi.
sonic_boom is offline   Reply With Quote
Old 26th February 2008, 17:48   #8
panky12345's Avatar
Thanked: 149 Times
yeah, and the headache comes free of cost.
panky12345 is online now   Reply With Quote
Old 27th February 2008, 10:28   #9
sonic_boom's Avatar
Thanked: 12 Times
That's not VFM .... that's a freebie .
Old 27th February 2008, 15:25   #10
nitrous's Avatar
Thanked: 285 Times
Guys, JBL subs cost as much as Pioneer subs in the market.
Old 27th February 2008, 16:00   #11
dinu2506's Avatar
Thanked: 349 Times
Guys, can you tell me the price of JBl GTO 1204? I cannot see this in the JBL site. Is it still available?
Old 28th February 2008, 08:10   #12
dinu2506's Avatar
Thanked: 349 Times
No response from anyone? Any feedback from users of JBL GTO 1204 DVC?
Old 28th February 2008, 11:49   #13
navin's Avatar
Thanked: 4,282 Times
dinu, PM Sam. he's the JBL-guy.
Old 29th February 2008, 18:50   #14
dinu2506's Avatar
Thanked: 349 Times
I am planning to go in for a JBL GTO1264 sub. This is a 4 ohm dual voice coil sub. It will be wired in parallel to present a 2 ohm load to the amplifier. My query is as follows
The power handling of the sub is 300W RMS. The amp I have (JBL GTO 3501 monoblock) pushes out 360W RMS to a 2 ohm load. Can gurus advice whether this will damage the sub. I don't go to high volumes normally. Is it always required that the sub should be rated higher than the amp.
Old 29th February 2008, 23:41   #15
nitrous's Avatar
Thanked: 285 Times
No, dinu. U won't damage your sub and infact,it is always recommended to have a power of around 10% more than the sub's spec for better quality.
Also, the 360W from the JBL 3501 mono is rated at 14.4V current(as per CEA2006A compliance).Real world conditions(stock alternator in an average car) isn't always 14.4V .ie. less than 360W .
This applies to all amplifiers.
10" DVC subwoofer???? Ajaybiz In-Car Entertainment 16 1st September 2009 10:59
4 ohm DVC sub and JBL 1004 LionX In-Car Entertainment 27 28th August 2009 19:57
Biamping DVC sub. Is it possible ? akg7091 In-Car Entertainment 12 11th September 2007 15:47
URGENT: 1202D or 306 DVC abhibh In-Car Entertainment 7 7th May 2007 17:17
JBL 12" DVC, your opinions ? s0uljah In-Car Entertainment 33 5th May 2006 13:25
