Old 17th March 2008, 12:20   #241
Thanked: 295 Times
Originally Posted by gunbir View Post
If its strictly a space issue, why not just do a Spare Wheel Well Sub setup...
I seriously doubt that it will give the desired SPL + SQ as compared to a sealed box. I will take a SWWS setup as a juggar.
Old 17th March 2008, 12:27   #242
BHAGWAN's Avatar
Thanked: 13 Times
Angry Nice choice of words.........
The SWWS is a great solution for a poineer sub in a Maruti 800 or an Alto;
Not so sure if I would try it else where.
A Spare Wheel is seldom used, but it must be there in the car. In case of travel [out of town] or an emergency.
BHAGWAN is offline   Reply With Quote
Old 17th March 2008, 13:11   #243
Technocrat's Avatar
Thanked: 2,591 Times
Originally Posted by hydrashok View Post
I think this was discussed someplace here before, but I can't now find the discussion.
I believe it was discussed during EVO6's ICE setup in his TT where he has used this kind of sub arrangement
Old 17th March 2008, 13:18   #244
gunbir's Avatar
Thanked: 25 Times
Originally Posted by BHAGWAN View Post
The SWWS is a great solution for a poineer sub in a Maruti 800 or an Alto; Not so sure if I would try it else where.
Sir, while I honestly didn't get the above comment... Let me explain what exactly I meant:
The spare wheel stays in its place. A fiberglass enclosure is made using the inside cavity of the inverted spare wheel & the sub is installed in the sealed enclosure. Ultimate space saver, nearly entire boot remains available.
Also, I don't do juggars.
Old 17th March 2008, 13:38   #245
Bass&Trouble's Avatar
Thanked: 74 Times
Thought about that too, but the spare wheel is a real eyesore sitting in the trunk, and does not translate into a huge space saving either.
Add to that the fact that the fiberglassing + labour works out to almost the cost of the second driver causing isobarik to be more feasible.
Old 17th March 2008, 13:49   #246
gunbir's Avatar
Thanked: 25 Times
Guys, the spare wheel sits in its original location... Well anyways, seems like you guys wanted to do an isobarik.
Old 17th March 2008, 14:00   #247
Thanked: 295 Times
Have you done with FibreGlass or what I have seen in your thread is this. If done can you please post some pics.
http://www.team-bhp.com/forum/sound-...heel-well.html
Old 17th March 2008, 14:03   #248
Technocrat's Avatar
B & ajay,
this is what Gunbir is referring to:
sub-woofers-spare-wheel-well
Old 17th March 2008, 14:09   #249
Thanked: 74 Times
Right, but with the wheel still sitting inside it would be very little volume for the Im subwoofer.
In Isobaric, the enclosure volume is about 0.8 cu. ft. Plus Bhagwan had the additional sub lying spare anyway.
Btw, aapka to 10" hai, hamara 12" hai.
Old 17th March 2008, 14:19   #250
hydrashok's Avatar
I think the (above) setup was a free-air install.
Gunbir probably meant a similar install, with the difference that a small (sealed) enclosure could be made with fiberglass (moulded to the shape of the inside of the inverted spare-wheel) and fixed in the cavity made out of inverting the spare-wheel. I think such an enclosure could be made to the equivalent of at least 0.75 sq.ft volume.
EDIT: OOPS, just saw your post, B&T
Old 17th March 2008, 15:09   #251
BHAGWAN's Avatar
Thanked: 13 Times
Red face IM 12 needs 1.5 cft [I think]
If the IM 12 is used in a sealed enclosure, it need 1.5 to 1.6 cft of space - sealed enclosure.
I was using it in that manner in 2 seperate enclosures for the Skoda. However, when I put the GZ's in the Skoda these IM 12's got available. So instead of using 1 of them in a 1.5 to 1.6 cft enclosure, I decided to use 2 of them in an isobarik so as to save on space. My enclosure would drop down to .8 cft. The extra amplifier power was not an issue. I think the Steg on Bridged 2 ohm load pumps some 1K watts [I think. B & T will know the exact rating @ 12V. Sir, please do add the details.
The long and short of it, I did not want to make a 'isobarik' but made one because :-
Space Saving.
Extra Woofer was there.
Amplifier power was on tap.
Nice experiment - learning curve for me.
May not work, but I am ready to try another kind of a loading if this fails.
Old 17th March 2008, 15:13   #252
BHAGWAN's Avatar
Thanked: 13 Times
Lightbulb Tweeter Housing - Comments ??
http://www.team-bhp.com/forum/sound-...tml#post760902
No one has any comments on my tweeter housing ?
Would love to know what you think;;
Good, Bad, Ugly [yes] !!
Can I post the picture here too ? Just for the tweeter assembly ?
Old 17th March 2008, 15:16   #253
Thanked: 295 Times
K2.02
155 x 2 at 4 ohms
305 x 2 at 2 ohms
555 x 2 at 1 ohms
615 x 1 at 4 ohms bridged
1110 x 1 at 2 ohms bridged
And all the above rating are at 11 volts.
Old 17th March 2008, 15:18   #254
navin's Avatar
Thanked: 4,349 Times
arey, baba, this is a sealed iso aint it. how can it fail? sealed boxes are really tolerant. just ensure you wire the 2 drivers correctly. besides according to google-man you get 110W more than you want (1KW)! :-) LOL that too at 11V. At 12V you'll be very happy. If you need more power you can always add a BOSS capacitor.
abhi, photo kab ayenge?
Old 17th March 2008, 15:26   #255
BHAGWAN's Avatar
Thanked: 13 Times
Thumbs down Photo's are there on the other thread !!!!
I had put the snaps on the other thread;
Do I need to re-post them here ?
Yes, the enclosure is sealed.
The Baffle between the 2 woofers is 3" thinch.
The side walls of the enclosure are between 3" & 1 " Thick.
Concrete & Ceramic + Butamine Linned.
Non Parrellell sides etc.
I will post fresh pictures of the box with the carpet etc. on Wednesday.
The Install should be complete by Tuesday evening.
I still need that 9887 HU. No one seems to be having it;
How is the Elipse 7100 HU ? Any one Used it ? Recommended ?
Pune to Goa - advice on planned route would be appreciated pilbeam Route / Travel Queries 246 18th April 2014 16:12
Alpine Type-R SPR-17S component speakers - Reviews/opinions sought predatorwheelz In-Car Entertainment 17 13th April 2013 19:02
Hyundai i10 facelift EDIT: Pic on Page 7, Brochure on page 18 Simhi The Indian Car Scene 451 21st December 2010 16:05
Opinions/Reviews about Ford Fusion TDCi vineethvazhayil Hatchbacks 1 2nd April 2009 17:43
1.5 Lakhs Budget for ICE in Cr-V EDIT: Now installed Pics on page 4 Mumbaiya In-Car Entertainment 114 23rd September 2007 11:02
