Old 19th March 2008, 17:16   #316
Autophile's Avatar
Originally Posted by low_bass_makker View Post
Iridium also has a 1.1 inch tweeter, The Carbon also has a 1 inch one. And I prefer both the tweeters to be on-axis as they perform better that way.
Thats you, unfortunately everyone cannot be you
Autophile is offline   Reply With Quote
Old 19th March 2008, 17:17   #317
clipto333's Avatar
It sitll does not affect the acoustics in this case.
Autophile, I dont get your point.
Navinji, although it wont affect the sound at all, after so much of hard work, it could have been better. had it been made by a noob diyer like me it would have been ok. This is made by a carpenter and they can do a much better job IMO.
Otherwise, the install is nice and clean and i like it.
LBM,
Human can localize sound much better in a horizontal plane than in a vertical plane. so even if a speaker is installed in that location, the sound seems to come from the dash at the ear level.
the path difference is also much less than placing the tweets on the dash plus the reflection would not be as much as the tweets placed on the dash.
So i think it is a good location to place drivers there.
clipto333 is offline   Reply With Quote
Old 19th March 2008, 17:21   #318
zucchero's Avatar
thats true clipto and morever the distance of both the drivers are 'almost' same hence creating a better soundstage.
zucchero is offline   Reply With Quote
Old 19th March 2008, 17:24   #319
Autophile's Avatar
I think it is the other way round. One has to put delay to the driver which is closer to the user not to that which is most far away.
Tweeters are never delayed as they are the reference points of the system and adding the delay to the tweeters will ruin the imaging. Thats why competitors prefer kicks as it gives maximum physical distance to the tweeters from listener. Midbasses are delayed to achieve stage height and better integration with tweeters finally the subwoofer is delayed to match with the front stage.
I would put delay in the front stage that to the sub. The speaker on the right will get the max delay as it is closest to the driver.
Adding delay on the passives is pointless unless you have same distance of Midbass and Tweeter from listeners ears.
Old 19th March 2008, 17:26   #320
Thanked: 294 Times
Originally Posted by zucchero View Post
lbm,almost all the cars have tweeter facing each other in kick panels for a larger soundstage.i was running my md102 located behind side rear view mirror facing each other and that was the time when the sound stage was at its best but unfortunately there was a lot of reflected sound from the windshield.
I have not seen installs where tweeter are in kick facing each other.
Old 19th March 2008, 17:28   #321
zucchero's Avatar
well you are the googlemaster.i am sure you will find them once you start searching bro!!!!!!
Old 19th March 2008, 17:31   #322
Thanked: 294 Times
Originally Posted by Autophile View Post
LBM both are speakers - transduces, they make sound hence they are no different.
But which part of the sound spectrum they produce can make hell lot of difference. You can localize a tweeter but not a woofer. But they both are TRANSDUCERS.
There are many I think you have capabilities to google them atleast. More over the tweeters cannot really face each other as there is part of dashboard and transmission tunnel as a obstruction in between them in every car. We are not talking here / taking examples of "Flintstone Cars".
So what will happen to the sound reflected by the part of dashboard and transmission tunnel as a obstruction in between them ???
Old 19th March 2008, 17:32   #323
Thanked: 294 Times
One i have seen bro. That is in the SK`s car
Old 19th March 2008, 17:35   #324
Autophile's Avatar
Unfortunately thats a start point LBM. The search goes on.
Old 19th March 2008, 17:38   #325
zucchero's Avatar
no bro ,sk car was different.it was 3 way set up my friend with a dedicated midrange.we are talkin about 2 way my brother.hope you are not down with APPLY FIZZ
and btw that was the best of best midbass install i had ever heard.phenomenal midbass.
Old 19th March 2008, 17:41   #326
zucchero's Avatar
lbm the only problem with the reflected sound is that you feel multiple sources of sound as if there are more number of speakers!!!!!
Old 19th March 2008, 17:48   #327
Thanked: 294 Times
But the tweeter play a important role in imaging and sound stage.
Are at office and it is not APPY FIZZ time. cheers:
Yahoo! Image Search Results for kick panel installs
A few kick panel install And I see in every car the drivers are facing the listerner on the opposite seat.
And the people at Hertz has some thing to say something about it..
Name:  suggeted angle.JPG
Old 19th March 2008, 17:50   #328
Thanked: 294 Times
dear lbm i am running them ON-AXIS.
Sir they are not ON-AXIS. They are OFF-AXIS in your car.
Old 19th March 2008, 17:52   #329
zucchero's Avatar
but you are not using HERTZ right,then why to copy them!!!!!!!
Old 19th March 2008, 17:53   #330
zucchero's Avatar
lbm i know my car and equipment better than you.when was the last time you had a listen to my dyns??????
Pune to Goa - advice on planned route would be appreciated pilbeam Route / Travel Queries 246 18th April 2014 16:12
Alpine Type-R SPR-17S component speakers - Reviews/opinions sought predatorwheelz In-Car Entertainment 17 13th April 2013 19:02
Hyundai i10 facelift EDIT: Pic on Page 7, Brochure on page 18 Simhi The Indian Car Scene 451 21st December 2010 16:05
Opinions/Reviews about Ford Fusion TDCi vineethvazhayil Hatchbacks 1 2nd April 2009 17:43
1.5 Lakhs Budget for ICE in Cr-V EDIT: Now installed Pics on page 4 Mumbaiya In-Car Entertainment 114 23rd September 2007 11:02
