Old 29th February 2008, 16:06   #1
gemithomas's Avatar
Thanked: 138 Times
Default Best Sub Woofer Setup within 15K
Which is the best setup of amplifier and subwoofer for quality bass. I have Pioneer headset and JBL Ovals at rear and Round at front. Want to know about just amp and Sub. Is this budget good enough?
Old 29th February 2008, 16:47   #2
gandolf_thewise's Avatar
hey man
why dont u go for the ground zero 12 " sub and 4 ch amplifier . The amp will cost you approx 9990 and the sub for 5000- 6000. You wont regret it. Its the best you can get for the price .
gandolf_thewise is offline   Reply With Quote
Old 29th February 2008, 21:32   #3
jkdas's Avatar
Thanked: 1,436 Times
quality bass = tight bass ?
Will suggest you check out some ICE setup where tubes, ported box and sealed box are used.
I can arrange for audition of these too
My suggestion; get sealed or ported one with a mono. You may need to stretch till 20 though.
@ 15k you can get a good sub + sealed bo and a 2 channel amp.
If you buy 4 channel you can use the other pair to power the front speakers which I presume would be compos in your Fiat Adventure.
Old 29th February 2008, 22:39   #4
moralfibre's Avatar
Thanked: 6,533 Times
The best option that I can think of in your budget is:
Ground Zero Titanium GZTW 12MKČ - Rs. 5490/-
Panasonic 2-ch amp - Rs. 8,990/-
This combo has been tried and tested and yields exceptional results in that price bracket.
Use the remaining Rs. 500/- bucks for Finolex cables for powering the amplifier. I am sorry I did not consider the price for an enclosure and installation.
Old 29th February 2008, 23:14   #5
nitrous's Avatar
Thanked: 285 Times
Very good recommendation by MF.
Though If one has a 15k budget, i would recommend a mono and DVC.
My recommendation:
Sub::: Ground Zero :: Subwoofer / GZRW 12XD-AL
Amp: Kenwood Electronics - KAC-8103D Class D Mono Power Amplifier - KAC8103D 1000 Watts - KAC8103D
Old 29th February 2008, 23:17   #6
gemithomas's Avatar
Thanked: 138 Times
Now dont tell me that You Are Serious.
Old 1st March 2008, 01:37   #7
Thanked: 294 Times
I think he is quite serious here.
Old 1st March 2008, 02:07   #8
moralfibre's Avatar
My recommendation:
Saar, the sub itself is 11k . Don't know much about the amp but it surely won't be available for the prices that you see in $'s.
Quite serious there. Only problem with this alternative is that you need to buy the fusebox separately which adds up to the cost. How about increasing the budget slightly to get a nice sealed enclosure measuring about 1 cu. ft. approximately for Rs. 1500/-. Get finolex for wiring + fuse box + an RCA.
Old 1st March 2008, 10:54   #9
gemithomas's Avatar
Thanked: 138 Times
SOmehow i get a feeling that i should extend the budget upto 20K. PLease let me know the options in that case. Will it be good quality in that case. I dont want high noise levels. I want the bass to kick in at low volumes.
I see boxes and tubes. Which is better for the above requirement. And what is a ported one!!
Sorry. I am highly illeterate in this department.
Old 1st March 2008, 11:08   #10
zucchero's Avatar
i have not listen to many but the one i like are the subs from ground zero.the top end is amazing and it integrates well with the front stage.jbl is also highly recomended.
zucchero is offline   Reply With Quote
Best available powered SUB WOOFER for my ANHC sathyaprakash In-Car Entertainment 1 29th October 2009 23:22
ICE Upgrades for Verna SX - Budget 15K, Amp, Speakers and Sub newcoolgadgets In-Car Entertainment 3 21st September 2009 16:04
Any Sat-Sub speaker setups for less than 15k? pranava999 Gadgets, Computers & Software 36 11th June 2009 22:12
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
