Old 10th March 2008, 11:30   #1
Deeps's Avatar
Thanked: 67 Times
Default Sony HU stopped reading RW discs!! Whats the solution??
Guys, I've started facing some problems with my Sony 250S HU after using it for just over 15 months. The problem is that when I insert a computer generated RW cd, it displays "error" and rejects it. If i then wipe the Cd and re insert it, the Cd plays on usually the third attempt.
These are the things i have tried. I have used a cd lens cleaner (dry type) and have had the HU taken out and cleaned by a guy in Sec 16 Noida. He used acetone and a cotton stick to wipe off the dust. Did not touch/clean the lens itself though saying that it will be ruined.
So guys is lens replacement the only way out?
Deeps is offline   Reply With Quote
Old 10th March 2008, 11:45   #2
navin's Avatar
Thanked: 3,885 Times
your CD laser might have gotten weak. CD lasers loose power even if not used.
Old 10th March 2008, 11:47   #3
Thanked: 116 Times
Can this be corrected; or one has to replace the whole system?
\N
ntomer is offline   Reply With Quote
Old 10th March 2008, 11:50   #4
try cleaning the Head..It may solve the problem temperorily..Sony Heads always show problem after 1 year use...
kphilip is offline   Reply With Quote
Old 10th March 2008, 12:55   #5
esteem_lover's Avatar
Thanked: 445 Times
Replacing the laser is almost as expensive as getting a new system, moreover it is not a recommended exercise.
Old 10th March 2008, 13:11   #6
praveen_v's Avatar
Thanked: 120 Times
The problem is not with sony HU's alone. Even my Pio refuses to play the same cd-rw that it used to play before and the cd is not scratched. So i guess the laser might have gone weak. No amount of head cleaning solved the problem and it's now starting to throw errors on even new cd-r's after it plays for 2-3 times.
praveen_v is offline   Reply With Quote
Old 10th March 2008, 18:50   #7
amitwiz1's Avatar
A major reason why I decided on getting a USB HU !! I had similar problems with an older Pionner in my Alto
amitwiz1 is offline   Reply With Quote
Old 10th March 2008, 19:00   #8
toiingg's Avatar
Thanked: 70 Times
And i thought that i was the only one facing this problem.
My solution was kinda old skool, i stopped using CD-RW's. Lol.
toiingg is online now   Reply With Quote
Old 10th March 2008, 21:35   #9
abhibh's Avatar
Thanked: 33 Times
Best idea. What i have seen is a CD-RW costs Rs 40. and a normal CD costs Rs. 10. Appx life of CD-RW is 10 writes Max now days. I still have CD-RW with me which didnt worked after 2 - 3 times of use.
So best idea is to just write CD's
Old 11th March 2008, 09:55   #10
Deeps's Avatar
Thanked: 67 Times
So I guess I'll have to go for a new USB HU. Any suggestions which one to go for..price should be minimum. And can i exchange the sony HU??
Old 11th March 2008, 10:41   #11
abhibh's Avatar
Thanked: 33 Times
Yes you can exchange the Sony HU just dont tell him it doesn't Read CD-RW. Just play a normal CD in it.
USB HU range starts from ~4.5K grey. For 4.5K you can get Kenwood 436U/4036U and JVC Front USB input. Pioneer 4050 is around 5-5.5k depending upon city.
Old 11th March 2008, 12:16   #12
Deeps's Avatar
Thanked: 67 Times
Thanks Abhibh. And how much can i get for the Sony HU. A new one is now 3700/-
Old 11th March 2008, 12:30   #13
deeps , pioneer is the best among low end models.. I've used sony hu for 1 year and it started showing this reading problem, My friend too had a similiar complaint..We both have shifted to pioneer now and so far no complaints ..I suggest u get a good pionner HU..
Old 12th March 2008, 13:36   #14
mithun's Avatar
Thanked: 49 Times
Deeps : Is the normal CD-R working fine ?
Old 13th March 2008, 13:14   #15
JayD's Avatar
Thanked: 1,996 Times
If u exchange it for a new one, you may get around 1.5k Approx. I'd say, if you are happy with the present HU except for the RW issue, stop using CD-RW's! simple! else, exchange it for a new one. repairing the lens may be an expensive affair.
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
Whats the solution to Windscreen scratches that cause glare? rahuldeodhar Technical Stuff 18 14th September 2008 11:23
Which amp is better Sony XM-554ZR or Sony XM-ZR604? prakasse In-Car Entertainment 3 5th November 2007 16:29
Sony 5505 HU not reading MP3 sudhir_nyc In-Car Entertainment 32 5th November 2006 19:18
Sony CDX-GT250S + Sony XS-GF6932 aalaap In-Car Entertainment 13 20th September 2006 13:31
