Old 14th March 2008, 10:11   #16
dinu2506's Avatar
Thanked: 349 Times
keep in mind that in all probablity your box size will double.
I am planning to add an additional identical box rather than one unit having two subs. This way I will have the flexibility to run one sub (@4 ohms), two subs (@2 ohms) or none at all (in case I need boot space).
Any problems you forsee in this arrangement?
dinu2506 is offline   Reply With Quote
Old 14th March 2008, 13:20   #17
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by dinu2506 View Post
a) Which is a better option? (No issues with losing space in the boot)
For once, there is someone who cares less for stupid suitcases and more for gorgeous woofers. cheers:
Old 14th March 2008, 14:50   #18
navin's Avatar
Thanked: 4,286 Times
[quote=Bass&Trouble;758135For once, there is someone who cares less for stupid suitcases and more for gorgeous woofers. cheers:[/QUOTE]
One could always go isobarik and get both - suitcases and 2 woofers in a car.
Old 14th March 2008, 14:56   #19
amit_mechengg's Avatar
Thanked: 1,556 Times
ha ha! i take out the sub and hide it in my park when my dad is supposed to take the car.
Old 14th March 2008, 16:36   #20
navin's Avatar
an isobarik sub can be made pretty small. Just ask Bhagwan.
Old 27th March 2008, 19:23   #21
dinu2506's Avatar
Thanked: 349 Times
Finally, I have added one more subwoofer in parallel to the existing subwoofer. Anwar also made a custom fibreglass enclosure inside the boot. Minimal space lost in the boot inspite of having 2 subs. Performance is rocking. I need to get a grill for one of the subwoofers. There was no stock with Anwar. Here are the pics
Old 27th March 2008, 23:47   #22
Thanked: 71 Times
Congrats dinu! That's a very good looking install! Great choice of equipment AND installer!
Old 28th March 2008, 09:52   #23
BHAGWAN's Avatar
Thanked: 13 Times
Lightbulb Would the amp drive it ??
cheers:
Thanks Navin !
I would have enjoyed the job;
However, our frind is in Bangalore.
Besides, Anwar is a great installer - one of the best that there is !!!
The Isobarik may not have worked;
You see, his Amp may not have had the power to drive both the subs - the spl would have been half !!! Please do keep that in mind.
I guess, what he had done is great. Looks lovely. I do not know how he got the volume calculated, but it sure looks good;
All the Best !!
Job well done.
cheers:
BHAGWAN is offline   Reply With Quote
Old 28th March 2008, 10:07   #24
panky12345's Avatar
Thanked: 150 Times
looks awesome, how much did you pay for this install??
Old 28th March 2008, 10:27   #25
navin's Avatar
What is the box volume? it loooks rather small. besides what happens if you need to change the tail light?
Old 28th March 2008, 10:30   #26
nice clean install. looking great. but with such a small volume does it produce enough bass?
Old 28th March 2008, 10:53   #27
dinu2506's Avatar
Thanked: 349 Times
Actually, the volume is not that small. The Civic has a cavernous recess at this point, which has been made use of. The volume should be easily 1 cu ft, but there is no way to measure it exactly. Yes, it does produce good tight clean bass.
Old 28th March 2008, 10:55   #28
dinu2506's Avatar
Thanked: 349 Times
There is quite a large recess at that point, so the volume is quite big, surely in the region of 1 cuft, though I cannot measure it exactly. Good question on the taillight, it is a bit difficult to replace the bulb, but this is a screwon enclosure and can be removed.
Old 28th March 2008, 11:05   #29
navin's Avatar
1 cu. ft. is quite small besides I would assume that the sub would take up some volume too. Yet without a listen one cannot comment on if the box is adequate.
Old 28th March 2008, 11:12   #30
dinu2506's Avatar
Thanked: 349 Times
The subwoofer manual (GT5-12) recommends 28 Lit for a sealed enclosure which is a shade below 1 cuft (including the driver displacement). Whatever it is, it sounds real clean. Best part, good punch even at low volumes, which is what I really wanted.
Adding second battery to Safari Rohit26 Technical Stuff 15 30th May 2011 11:25
Adding sub+amp to this configuration -> feasable? DCEite In-Car Entertainment 10 28th October 2010 01:12
Adding A Sub woofer on the Pioneer DEH-P5950 without amp? vikram31 In-Car Entertainment 17 9th September 2010 18:31
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Does adding one more sub make a difference? raajsree In-Car Entertainment 24 3rd July 2008 11:41
