Old 23rd May 2008, 09:51   #31
SRShrikanth's Avatar
Wink
That is one well-documented & clearly explained DIY job there Dr.Aditya.
I felt i was watchin a surgeon at his job through a screen outside the OT.
Cheers mate.
SRShrikanth is offline   Reply With Quote
Old 23rd May 2008, 12:12   #32
Thats an outstanding effort Aditya, i'm sure the end result will be well worth it.
shldn is offline   Reply With Quote
Old 23rd May 2008, 12:33   #33
adityamunshi's Avatar
Originally Posted by DerAlte View Post
Shabash, Aditya, wonderful work! Keep it up.
Thank you DerAlte ji. Such DIY jobs are only possible because of the collective knowledge of T-BHPians
Cheers mate.
Thanks Shrikanth ji. Am not a surgeon by any means .
Anyways, glad to know you found the pics informative. I wanted it to be step - by - step to make it easier for anyone else going the DIY way.
Thanks again
adityamunshi is offline   Reply With Quote
Old 14th July 2008, 16:08   #34
AbhiJ's Avatar
Thanked: 553 Times
Nitrile is Oil proof. If you want to check if the sheet is nitrile, throw a piece in engine oil for 2 days. If is swells up, it aint nitrile.
To check for Neoprene, set a small piece on fire. If the flame dies out on its own... its Neoprene. If it continues burning... It aint neoprene.
Also, dont smell the fumes if you try burning them..
AbhiJ is offline   Reply With Quote
Old 16th August 2008, 00:37   #35
ultimatechamp's Avatar
Thanked: 98 Times
Superb DIY work done Addy.The effort and time that you have put in shows how much it means to you.Wish you all the best for an enduring aural bliss!
ultimatechamp is offline   Reply With Quote
Old 13th February 2009, 18:47   #36
Default Upgraded !!!
I installed a Kenwood 8401 last month.
The SQ has improved tremendously and the speakers sound great!!!
But im having trouble fixing the speaker wires to the underside of the wooden parcel tray. No matter what tape i use it just falls off. Gurus please suggest a way out of this.
Old 13th February 2009, 19:05   #37
I just use small nails to secure the speaker wires. Just hammer in 2 nails close together and run the speaker wire between them. Bend the nails a little to hold the wire in place
PaulBarber is offline   Reply With Quote
Illusionized Swift !! Amey In-Car Entertainment 324 14th April 2010 10:03
SANTRO just got Illusionized! yayaati In-Car Entertainment 40 13th September 2008 17:32
Illusionized My Palio - Mindblowing SQ! moralfibre In-Car Entertainment 135 17th April 2008 16:48
Illusionized Santro.. yayaati In-Car Entertainment 2 14th April 2008 17:19
illusionized palio_ver 2. payam In-Car Entertainment 46 5th September 2007 14:19
