Old 13th April 2009, 10:24   #46
nitinralli's Avatar
Thanked: 796 Times
Originally Posted by nitrous View Post
For the comps: 100@ 4 ohms & 150 @ 2 ohms
For the sub : 320W RMS @ 4 ohms
Thanks nitrous...Do u think if i run IDV3 12 on this amp, will it do justice to it?? or does it need more power than 320?
nitinralli is offline   Reply With Quote
Old 13th April 2009, 10:39   #47
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by govigov View Post
just found out that for stereo operations, the amp is stable at 2 ohms, but for bridged it has to be at 4 ohm, i.e that amp is not stable at 2 ohms bridged. i did not know that for bridged and stereo mode that the impedances are different.
When you bridge an amplifier (any amplifier) the impedance "seen" or perceived by the amplifier is halved. This stands true for all bridgeable amplifiers.
To run a 2 ohm load in bridged mode, you need an amplifier that is 1 ohm stable. True 1 ohm stable.
Old 13th April 2009, 11:16   #48
frankmehta's Avatar
Thanked: 2,334 Times
Sam, this question is for you. Some sites say the 1004 does 320RMS @ 4ohm bridged (ie for a sub)
Is it 320W RMS from 2 channels, when the other 2 channels are doing their 104*2 bit for the components/other speakers, or is it 320W RMS when its only supplying power through those 2 channels alone, and the other 2 are not in use. Confusing.
And the worst part is, different sites state different specs.
Well, we believe the JBL site of course, but the discrepancies are quite confusing even for someone who's decently ok with the already confusing numbers being thrown nowadays by all manufacturers.
Old 13th April 2009, 11:20   #49
karankapoor's Avatar
i think the better way to ask this,what rms power will this give in a tri mode operation.
is it 104 x 2 for the fronts and 320 x 1 for the sub.
karankapoor is offline   Reply With Quote
Old 13th April 2009, 14:42   #50
ID V3 is rated at 350W RMS i think. Running that with 1004 shouldnt be a problem, but IDV3 demands a dedicated mono amp to do justice to the Sub.
Nandan is offline   Reply With Quote
Old 14th April 2009, 01:46   #51
govigov's Avatar
Thanked: 531 Times
thanks sam. one can hardly find amps that are 1 ohm stable. :(
govigov is offline   Reply With Quote
Old 14th April 2009, 10:21   #52
your are mistaken there are many amps available which are stable @ 1 Ω,
just do a search you will find.
some from my side.
audiobahn
audison
dd
steg.
id
Old 14th April 2009, 19:04   #53
DocG's Avatar
@KK I think since the thread is about JBL, he was talking about amps in this range, I believe than all the amps you've mentioned are considerably more expensive...
DocG is offline   Reply With Quote
Old 14th April 2009, 20:32   #54
nitinralli's Avatar
Thanked: 796 Times
+1
Even i want to know this..
Old 14th April 2009, 21:21   #55
i thought he was talking about 1 Ω stable amps so i listed some of them.
even jbl has some (mono) amps which are stable @ 1 Ω
Old 20th July 2009, 11:12   #56
bullboy's Avatar
Thanked: 35 Times
what is the price of JBL GTO1004 market and grey
bullboy is offline   Reply With Quote
Old 20th July 2009, 16:21   #57
You get it for 9k change in grey.
ameenmaj is offline   Reply With Quote
Old 26th February 2011, 15:07   #58
Thanked: 158 Times
Default Re: Does the JBL GTO1004 compete the 75.4?
Is this amp good enough to power Infinity kappa 120.9w sub in bridged mode? I am looking for a a single amp/ single sub set up for my figo that can power front comps (bull audio) as well as a single sub (kappa 120.9w or infinity ref 1260w, both are rated at 300w rms at 4ohms). Ideally I wanted to go in for an mrp-m500 mono amp for the sub (using that in my ikon and very happy with it) but I just can't go in for 2 amps due to space limitations.
Also, ammenmaj mentioned that it's available for 9000 odd bucks in grey market, I checked up with Driven and he quoted 10,500 bucks for grey, could you let me know what's the grey market price in Delhi for gto 1004 amp these days?
Astleviz is offline   Reply With Quote
Old 26th February 2011, 15:11   #59
panky12345's Avatar
Thanked: 150 Times
GTO 1004 : 9-9.4K Grey, Karol Bagh, Delhi.
If you're looking for SQ with your bull comps, try Kenwood 8401/8404/840X/8XX amp.
Old 26th February 2011, 15:30   #60
Thanked: 158 Times
Thanks for your feedback panky, but then the kenwood amps will be grossly under powering the above mentioned subs. In bridged mode, the kenwood amps will send out 180w to the sub while I'd like to feed them at least 300w. Is there a kenwood option available that can deliver approx. 300w to the sub in bridged mode. I am more or less decided on the infinity sub.
Renault to launch a small car to compete with alto dZired The Indian Car Scene 36 13th April 2015 10:29
Lets compete on XBox Live... harmon_bro Gadgets, Computers & Software 44 10th March 2012 12:41
Indian driver to compete for place in FIA Institute Young Driver Excellence Academy jalsa777 Int'l Motorsport 3 10th November 2011 10:09
Tata not to compete with Fiat in same segment sridhga The Indian Car Scene 17 26th August 2008 19:01
Singhania/Sorabjee to compete in Supercar Rally! Rtech Indian Motorsport 15 20th January 2005 03:59
