Old 12th April 2008, 21:51   #1
vishnuvijay's Avatar
Default putting amplifier under the seat ?
helooo guys,
i'm thinking about placing my amplifier (JBL CS 60.4) under the rear seat of my car (Maruti Suzuki Wagon R). i don't want to place it in the boot since i don't want to sacrifice boot space nor spoil the fun of reclining rear seats.
what are the precautions to be taken while putting an amplifier under the seat. (Rear seat in this case).
is it ok if i cover the amplifier with cloth/plastic cover or something to protect it from dust/soil? will that effect the cooling of the amplifier ?
i don't want to place the amplifer under the front seats because dust and soil always gets accumulated there.
vishnuvijay is offline   Reply With Quote
Old 12th April 2008, 21:55   #2
greenhorn's Avatar
Thanked: 1,516 Times
The amps I've seen are installed on the sidewalls where they lead an unobtrusive existence. I doubt if they can decrease your boot space or interfere with the back rest at all
Old 12th April 2008, 22:33   #3
how can you fix the amplifier under the rear seat dude...???? i dont think there will be any place to put an amplifier iunder the rear seat..
i placed my amplifier under the front co-passenger seat and didnt face any peoblem till now...
zenopio is offline   Reply With Quote
Old 13th April 2008, 11:35   #4
hi greenhorn, installing the amplifier on the sidewalls of the boot does not decrease boot space but it sure hinders the reclining rear seats.
hi zenopio, there is enough space (height, width and depth) under the rear seats of the Wagon R to place 3 amplifiers.
is your car a Wagon R? i feel that the area under the front seats of the Wagon R is too open/exposed.
Old 13th April 2008, 11:47   #5
Sankar's Avatar
Thanked: 4,642 Times
Does the space under the rear seat have enough ventilation? If yes go ahead and fix it there. Otherwise don't as amps generate heat.
Old 13th April 2008, 12:34   #6
dont cover the amp it should be placed in area where there is proper ventilation so that amp can loose the heat produced
harry2223 is offline   Reply With Quote
Old 13th April 2008, 13:51   #7
i would suggest placing it on the back of the rear seat.
saintsinner is offline   Reply With Quote
Old 13th April 2008, 15:35   #8
u mean like fixing a plywood/mdf board on the back of the rear seat and placing the amplifier on in?
the levers/buttons for reclining the rear seats is on the back of the rear seat. i'm not sure about how this mechanism works. i don't know whether i can fix a board on the back of the rear seats.
images 1 and 2 shows the space under the rear seats.
image 3 shows the rear seat in one of the many upright positions and also the lever/pull button for the recliner.
image 4 shows the seats fully reclined.
image 5 shows the ample space in the sidewall, but it will hinder the reclining action of the seats.
Old 13th April 2008, 15:48   #9
hydrashok's Avatar
If you'd like to keep the option of reclining the seats, I think under the rear-seat seems to be the best option here.
The amp can be fitted and tuned after removing the seats. There does seem to be enough space down there.
Maybe the amp can be fitted onto one of the seats by still keeping the reclining angle intact, but in this case, I think under the rear-seats is the best choice.
Old 13th April 2008, 15:57   #10
thank you hydra. and congratulations on the new hot hydra's hatch.
then i think i'll go with the under rear seat option. should i build a cage/cover with some wire mesh/grill which will still provide ventillation?
Old 13th April 2008, 16:13   #11
hydrashok's Avatar
Thank you, Vishnu!
In that position, I don't think that is required at all. There will be enough ventilation (it is open enough and not under a carpet or anything), and a grille is not needed, as there is no way anything is going to touch it or push against it when it is under the rear seat, going by the pics.
I hope the under-seat area will not reduce to the point where some weight will rest on the amp when somebody sits on the rear seat?
What you will need to be careful of, is the water-service guys getting water on the amp while washing the car. Dust will also be a bit of an issue, but dust and dirt will be much lesser here, than in an under-front-seat location. Just give the under-seat area a vacuuming once in 2 weeks or so.
Old 13th April 2008, 16:14   #12
vebmetal's Avatar
Thanked: 15 Times
I was thinking of the same thing in my Estilo (which for those who don't know is very similar to the WagonR). Here are a couple of pics. Is the space good enough for an amp, and possibly a carputer? I mean that in terms of fire safety / heating issues etc. is this a good place?
Like the original poster, sidewalls and behind the rear seat is not an option for me.
Here are a couple of pics:
vebmetal is offline   Reply With Quote
Old 13th April 2008, 23:38   #13
wow i never know that wagano r has so much lpace under the rear seats ...good man just go for it place the amps under the rear seats ...
Old 14th April 2008, 00:46   #14
vebmetal's Avatar
Thanked: 15 Times
^ I didn't either till a couple of days back when I dropped something in the back. My first reaction was: "What the?" and I thought they had skimped on seating or something. It seemed cheap. But then I thought, "oh sweet, space for an amp and a carputer!"
So an amp at least will go there sometime soon (i.e. could be tomorrow, could be 4 months from now).
Old 14th April 2008, 00:56   #15
Thanked: 17 Times
Take your wagonR to your installer. Put as much amps as you want below the rear seats as that's the best location in your car.
Don't worry about insulation/cover etc.... It's perfect there.
Btw, what amps do you plan to put in? If they're quiet high, you may have some problems fitting it.
Putting a Free Flow Exhaust in Esteem 2001 passion4cars Technical Stuff 5 29th January 2008 23:36
Advise me Please"is it worth putting CNG in one year old Swift" mitesh vardhan Technical Stuff 0 26th September 2007 16:39
Putting an indian car engine in a Sera cool_sizzlers Modifications & Accessories 10 6th August 2005 20:52
Putting The Hammer Down At Ferrari comfortablywacky The International Automotive Scene 0 28th January 2005 02:19
