Old 5th June 2008, 15:31   #16
RAC
RAC's Avatar
Originally Posted by greenhorn View Post
the JBL coax's take only about 35W rms, and most HU's provide ~ 22W, so they're already taking a lot of power. but the rears are more powerful, and more sensitive too. I think using a fader would be the right approach. if you want more sound up front/amplify them , use components who can take more power
My experience has not been good on using the fader. If moved 2-3 points to the front, it is bearable, but move it 6-7 points to the front and the rears completely loose the mids and the vocals dip.
RAC is offline   Reply With Quote
Old 5th June 2008, 15:55   #17
greenhorn's Avatar
Thanked: 1,519 Times
RAC , what are your fronts and rears ?
Old 6th June 2008, 11:46   #18
RAC
RAC's Avatar
fronts: some bronze coloured pioneer 4"
rear: JBL 936
The rears and the sub are powered by JBL 1004.
Old 6th June 2008, 12:01   #19
greenhorn's Avatar
the jbl 936's must be a lot more sensitive than your fronts, and hence the huge mismatch.
EDIT : and to make it more imbalanced , they're driven by an amp.
Old 6th June 2008, 22:57   #20
RAC
RAC's Avatar
^ and that is the reason why i felt it is better to amp the 4" fronts.
Old 7th June 2008, 10:48   #21
greenhorn's Avatar
some unknown pios ( are you sure they're originals ?) I dont think its worth amping them, even if you did , not much of a difference. A better option would be to get a pair of decent 4" comps . kicker/illusion make them. that should help restore the front/rear balance
Old 12th June 2008, 11:26   #22
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by cyclops View Post
Even I am in a similar doubt. Is it okay to power 4" co-ax with an amp? is it worth the effort? or the 4" co-ax's sound similar with or without a amp?
Sorry I just saw this.
If you have a pair of high quality 4" coaxial speakers then it is a great idea to amplify them, provided you cut them off at least at 130-150 Hz using the HPF on the amplifier.
Old 13th June 2008, 12:01   #23
cyclops's Avatar
Thanked: 9 Times
i have a gt5-402, quite sure of its good quality! i hope you second that!
cyclops is offline   Reply With Quote
Old 14th June 2008, 11:15   #24
Moby's Avatar
I have JBL 4'' GT0 427 & GTO 937 at rear. I also have a 10'' bass tube & JBL 60.2 Amp. My head unit is Pio 7950. I am planning to remove my sub to another car. I am looking for clean sounding system with tight bass.
so here are my options.
1 : Getting a 4 channel amp like JBL 60.4 connect the front & rears.
2 : Using JBL 60.2 to power there front 4'' & leave rear GT0 937
3 : Connecting speakers directly to head unit (no amps)
What are best amp 4 channel in 5-8k range?
Moby is offline   Reply With Quote
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
JBL GT5 Series Raja In-Car Entertainment 298 19th June 2009 12:29
Pio 3050UB (2 RCA) + JBL 4Ch GT5-A604 = HOW to GET A SubWoofer "DILEMMA" svsantosh In-Car Entertainment 12 7th April 2009 06:40
GTO 608 Component Speaker - Part of the newly released JBL 8 Series blueraven316 In-Car Entertainment 56 2nd September 2008 18:50
