Old 2nd May 2008, 22:26   #31
sonic_boom's Avatar
Thanked: 12 Times
IMO , this has got nothing to do with data transfer for long durations or mismatch of read/write speeds or any other such bunkum.
It's simply a defective HU and depending on the kind of damage the dealer may or may not have a liability for replacement , which , of course , doesn't mean that you shouldn't push for one .
sonic_boom is offline   Reply With Quote
Old 2nd May 2008, 23:01   #32
NetfreakBombay's Avatar
Thanked: 408 Times
Yes most probably shopowner is trying to save some work and trying to avoid hassles of replacement.
Old 2nd May 2008, 23:29   #33
Sankar's Avatar
Thanked: 4,676 Times
Buy thumb drive with the toggle switch that will allow it to be toggled between read only and read write mode. Mount the thumb as read only while using it with a HU.
Old 3rd May 2008, 00:06   #34
Sam Kapasi's Avatar
Thanked: 1,490 Times
Sankar that is a lovely solution! So simple.
What thumb drives come with a write-protect switch? Anyone?
Old 3rd May 2008, 00:11   #35
adityamunshi's Avatar
This was a feature in many of the earlier drives. Dont see it on any models nowadays.
adityamunshi is offline   Reply With Quote
Old 3rd May 2008, 02:33   #36
Originally Posted by DerAlte View Post
Commiserations, @akash_m, either your HU is giving a massive jolt of static to the pen-drives (HU grounding problem), or passing on massive amount of heat through the connector/tracks, or you have got 'lemons'/fakes twice.
Heat could be a possible factor.
A simple solution for avoiding heat from HU would be, instead connecting pen drive directly to the HU, connect it via a male-female USB cable which is easily available at comp. stores...
Haste is offline   Reply With Quote
Old 3rd May 2008, 09:32   #37
phantom76's Avatar
I use a 4GB mini SD card through a sandisk USB adapter. All SD cards have the read protect switch.
Slightly expensive solution, but solves some of the problems.
phantom76 is offline   Reply With Quote
Old 6th May 2008, 22:59   #38
redfire's Avatar
When ever I connect my N95 to 4050UB headset, I used to switch off player before unplugging the USB. Since N95 can be used as a mass storage device (plays well in my HU), and an intelligent device than the USB sticks / HDDs, it shows "safe to remove" message on phone screen when the player is switched off like it shows with PCs (press and hold source button to switch off player functionality only, no need to remove key to turn full power off). So I assume it is the good pracitce with other USB storge devices too as the HU stops the read / access functions and releases the file system properly.
redfire is offline   Reply With Quote
Old 7th May 2008, 17:10   #39
rocksterraghu's Avatar
Thanked: 113 Times
All Transcend flash drives that I broke/opened had it. It is on the inside and not accessible.
The question is whether or not someone wants to get down to opening one up and use it.
Old 7th May 2008, 19:02   #40
clevermax's Avatar
Thanked: 447 Times
I have this USB pedndrive mp3 -> FM converter which I plug in to my car's cig. lighter jack, and I just turn on radio in my headunit, and tune to the frequency displayed in the transmitter. The pen drive is of course plugged into the USB host of the transmitter before plugging in the transmitter to the cig. lighter jack.
FM sound quality, pen drive electrically and mechanically isolated completely from th HU! I can even give a direct audio output to the transmitter.
clevermax is offline   Reply With Quote
Old 8th May 2008, 23:18   #41
Thanked: 36 Times
Or more probably this might have been caused due improper pulling out or plugging in the drive causing some of them to short out.
zaks is offline   Reply With Quote
Old 8th May 2008, 23:54   #42
MillionSwords's Avatar
good analysis.
1. Heat - first culprit in most Indian conditions, connect to a 1 meter USB cable.
2. Grounding - Double check if your HU Grounding is proper.
3. Bad Lemons? confirm this pal - did u get fakes or with B&W ???
MillionSwords is offline   Reply With Quote
Old 9th May 2008, 10:37   #43
Thanked: 295 Times
I had one with 64 mb memory. It was some zoltirx make.
Old 9th May 2008, 11:48   #44
navin's Avatar
Thanked: 4,351 Times
I think LBM is a closet trekie!
Old 9th May 2008, 15:04   #45
somebodystopme's Avatar
Thanked: 17 Times
I have been using my sandisk cruser 4gb pedrive with my HU since a year now. No problems at all. whenever i disconnect my pendrive and connect it to my HU later on. Somehow my HU knows what song I was listening to ie if in between I dont write anything new on my drive.
After reading this thread am kind of scared about my Pen Drive. Thankgod I havent started connecting my newly bought cell phone to HU.I think I 'll get HU's grounding checked all over again.
One more thing I have never bothered about Safely remove thing on my HU. I have taken it out without switching off my HU on many occasions. It doesnt make a difference and even when i switch off the HU with pendive still connected the light on pendrive still glows. Does that mean its still connected??
somebodystopme is offline   Reply With Quote
Pen Drives : Compatibility issues with Head-Units Safari_Beast In-Car Entertainment 109 6th June 2017 16:08
All about USB Flash Drives a.k.a Pen Drive / Thumb Drive / Memory Stick / Jump Drive KSM-Vtec Gadgets, Computers & Software 1 28th February 2012 12:04
USB Pen Drive speeds and HU vebmetal In-Car Entertainment 76 15th October 2008 23:27
Scorpio slx Nippon HU USB not reading pen drive easyrider In-Car Entertainment 22 13th August 2008 18:40
Head units with USB input katalyst In-Car Entertainment 19 22nd January 2007 15:05
