Old 29th December 2009, 12:47   #16
Thanked: 91 Times
In fiesta, can we play ipod music by connecting the ipod USB cable with that of car and play the music, will it happen when we put a USB connector in the 12v supply.
as per me the ipod cable is only used for charging and integration with PC or it can be used to play music as well.
ruchirtnt is offline   Reply With Quote
Old 29th December 2009, 19:52   #17
DerAlte's Avatar
Thanked: 2,879 Times
If you are referring to the stock HU in Fiesta, no it won't accept the iPod USB cable.
The USB cable that comes with the iPod (connects to the dock connector for charging) is usable with some iPod-capable HUs. In other iPod-capable HUs, there is a specific cable that comes with the HU, or - as with Blaupunkt HUs - there is a separate cable for it. In these cases, the iPod charges from the HU, i.e. +5V is supplied at the designated pin on the dock connector.
USB connector has a pin designated for +5V for charging / powering purposes. If you manage to somehow get +12V to it, quite likely you will have a toasted iPod!
Old 29th December 2009, 20:01   #18
sathee46's Avatar
The stock fiesta HU does not have a USB port. How do you plan to integrate it?
sathee46 is offline   Reply With Quote
Old 30th December 2009, 00:25   #19
nura's Avatar
I want to buy a cable to connect my iPod to the aux-in. What is this cable called, where should I look for it & should I ask for a particular brand?
nura is offline   Reply With Quote
Old 30th December 2009, 10:04   #20
Thanked: 91 Times
It is available with any one of the music or electronic shop, i purchased two cables to check the aux in, the music played is superb but a spark is coming from the car aux in, may be the wire is not able to set properly
Old 30th December 2009, 18:39   #21
DerAlte's Avatar
What kind of spark? Are you getting that at the iPod EP socket while connecting or disconnecting? I don't think you meant that the spark is coming while connecting at the rear of the HU.
Old 30th December 2009, 20:19   #22
nura's Avatar
The aux-in socket in the Fiesta has been fitted to the console below the dash. Certainly makes it a lot easier to attach the cable.
But I need to buy a cable first.
An accessories shop has quoted 100 & 150 for 2 varieties of aux-in cables. The Blaupunkt distributor has quoted 650.
Which one should I buy?
Old 30th December 2009, 22:24   #23
oss
oss's Avatar
I bought the cable for Rs.150/- and it works just fine. 650 is insane
oss is offline   Reply With Quote
Old 31st December 2009, 13:57   #24
Thanked: 91 Times
the spark sound is coming from the speakers when connecting to the aux in port of the car, i think the aux in wire is not getting fixed properly in the socket, do i need to take the car to the service center, may be an issue with the car aux port.
Old 31st December 2009, 20:51   #25
DerAlte's Avatar
Sounds normal, can happen when you are inserting the cable. To avoid it, keep the volume low at the HU when connecting. If the connector is not mating, you will get interrupted sound.
Old 1st January 2010, 12:17   #26
Thanked: 91 Times
i do not think it will be a problem for my ICE or car electrical wiring or system
Old 7th January 2010, 17:18   #27
Thanked: 91 Times
I am now using a aux in cable for my ipod, got to see a ipod charger for car, costing around 350, and also bought a original nokia car charger for 200.
Old 9th January 2010, 18:29   #28
Thanked: 91 Times
Is there any such system whereby i can control the Ipod through the stock HU
Old 9th January 2010, 18:32   #29
sathee46's Avatar
you mean something like the Harman/Kardon Drive + Play?
Old 10th January 2010, 15:27   #30
Thanked: 91 Times
Could not get the message out of it.
NEED Inputs to FINALISE: Fiesta Petrol 1.6 SXi or Diesel 1.4 TDCi SXi. Specific query sachinchavan Sedans 17 26th September 2012 00:00
Is it 2 Player(MP3 Player & DVD player) Possible in my i10? camon In-Car Entertainment 4 17th October 2010 11:35
'DUAL 7610' In dash CD player... Have a look guru's extreme_torque In-Car Entertainment 15 29th August 2007 20:04
Mp3 Player Or Cassette Player With 12 Cd Changer. zulfikar In-Car Entertainment 6 20th March 2006 14:55
