Old 9th May 2008, 23:53   #1
Magma's Avatar
Default My i10 IC'ed-Illusion,GZ,Kenwood BOOM!
After a lot of waiting,deliberating and deciding, i finally iced my new car.
Its an entry level setup and since boot space is important to me now (i just became a dad!) i chose a setup without a sub.
I must say i am really satisfied with the outcome and dont miss the sub considering the kind of music i hear.(maybe my ears arent so trained anyway)
I thank Mr Ajay Kamath,NAvinji,Der Alte,Raghuvinderji , Bhagwan and Zohir for their support and patience.( who still provide me their help for all the tweaking and tuning that seems to be an everlasting affair)
Tbhp as a whole and all its members whose posts helped immensely in choosing the right stuff for me and yes for doubling my budget too!
but whose comlaining.
i love my ICE
Pictures speak a thousand words - so here are a few thousand
My Car(The sticker at the back gives away my installer)
Magma is offline   Reply With Quote
Old 10th May 2008, 00:03   #2
Magma's Avatar
Fronts are illusion Audio EL6.1
Damping is Noisekill 25 sq ft of it ( went way past what i thought i would use)
Hu - Pioneer 5950 ( i liked the older models more, i dont use usb so i didnt miss that feature)
Rears- Ground Zero GZ mk2 690 (have adequate punch and bass to substitue a sub for my requirement)
They are loaded onto a custom rear parcel shelf that opens up just like the stock parcel shelf so i can fit my air travel luggage!
Amp KAC 8401 - real VFM. i liked the neat work on the amp tray that Zohir did for me
The last pic is of the temporary tweeter position ( till i finish fabricating cups to hold the tweeter pods to be placed in the same position -only facing the front passengers-off axis)
The i pod aux cable is neatly tucked into the glove box
Old 10th May 2008, 00:27   #3
Magma's Avatar
A question
The Amp has a switch
"B Ch Bass Boost"
it is currently set if the Off position
What do the gurus advice? should i turn it ON considering there is no Sub
What is its effect?
Currently i have wired my front compos as B channel
i am planning to change the wiring connections of the amp so that the GZ's on the rear are channel B so as to utilize the bass boost to the fullest through the 6*9's
is the above assumption correct?
Old 10th May 2008, 00:43   #4
nishantgandhi's Avatar
Thanked: 151 Times
Great setup and choice of equipment Magma!
Can you post individual prices please?
Did you buy the HU, amp, wiring from elsewhere? Because AFAIK, Zohir does only speakers, right?
nishantgandhi is offline   Reply With Quote
Old 10th May 2008, 07:33   #5
Magma's Avatar
thanks nishant
Individual prices here
http://www.team-bhp.com/forum/sound-...-price-34.html
Only, damping actaully cost me over 3000rs (there is a mistake in what i posted in the link above)
Zohir stocks each and every item you need for an ICE instal if not he can procure them.
i got only speakers from him though
Old 10th May 2008, 09:18   #6
Thanked: 13 Times
Hey seems like iLLusions are invading a lot of hatches these days.
Damping too is getting popular
Magma, Enjoy the sound !
Edit : I just saw the other thread and that you mostly listen to classic rock... great choice of speakers in that case.
Old 10th May 2008, 10:29   #7
Thanked: 294 Times
Firsts congrats on the setup.
About the BASS boost keep it switched off as it is not required. If you feel the you need more bass fiddle a little with the HU eq. Keep all the setting in the AMP to FLAT.
Old 10th May 2008, 10:50   #8
DerAlte's Avatar
Thanked: 2,879 Times
Fantastic! Congratulations, @Magma. Enjoy your music - though right now the baby's sounds will override all other sounds!
Old 10th May 2008, 10:53   #9
navin's Avatar
Thanked: 4,284 Times
Hope you got a care seat for the baby as well. we have a thread on TBHP that covers that.
Old 10th May 2008, 11:54   #10
Magma's Avatar
A thread on baby car seats!
WOW (i have already purchased one)
i should have done my research here rather than running around in amarsans and mother care trying to find out whats good!
Old 10th May 2008, 12:11   #11
nitrous's Avatar
Thanked: 285 Times
Good install.
Btw, let me guess. Those are MX RCAs. right?
Old 10th May 2008, 12:55   #12
navin's Avatar
well we on TBHP try to please everyone. We even have an inhouse expert on how to make babies!
Old 10th May 2008, 14:04   #13
bossman's Avatar
Congrats Magma !! for both the new Music makers in your life... ...will be good if you enjoy them both singing in unison... there should'nt be any phase lag... ...Cheers...cheers:
bossman is offline   Reply With Quote
Old 10th May 2008, 14:35   #14
Magma's Avatar
lol
hmm ,you know, i wud believe an expert is one who has actually made a baby not 1 who KNOWS evrything about making one
so in all probability you would be as expert as anyone else
yep nitrous those are the MX digital RCA's.
its wierd- i had a set ;i cut them up (i cut into a scoshe too)- i found the MX to be quite good
Note: my ears are not trained enough to notice the difference between MX and the ENTRY level kits from low/mid fi reputed brands
Old 10th May 2008, 14:36   #15
Bass&Trouble's Avatar
Thanked: 71 Times
Magma-ji, congrats on the setup. Looking good! Hope to see you soon.
"B Ch Bass Boost"
What is its effect?
Above assumption is correct, but a 6-12 dB boost at 45Hz will be a bit too much for both the amp and the speakers. Firstly the poor amp is not the most powerful giant and using it for so much bass would not be the best idea. Plus, so much bass is not ideal for the speaker either. Unless you lower the gain greatly on the rears and the subtle addition of lows then becomes just barely audible and supplementing the fronts.
Another option would be Navin's "psycho" approach. Adding a touch of boost between 100-140Hz depending on the center frequency allowed by the head unit's parametric equalizer. This is sometimes perceived beneficially in systems without a sub and with electronic dance and rock music.
BTW, what ICE have you installed in the other 73 cars that you bought over the last 2 and a half months?
As Biofuels boom, will more people go hungry? iraghava The International Automotive Scene 7 11th March 2010 10:38
i10 Magna ICEd - Kenwood, Focal, Blaupunkt superbhikari In-Car Entertainment 20 10th March 2009 23:48
SONIC BOOM Suggestions PLease gemithomas In-Car Entertainment 22 1st April 2007 12:51
Palio 1.2, ICE Config, No Boom Boom rohitgaur In-Car Entertainment 9 29th January 2007 22:46
