Old 5th June 2008, 18:04   #31
nura's Avatar
@razor - You are most welcome & thank you for the suggestions. I will certainly test-drive the cars you have mentioned before deciding.
Are you aware of anyone doing fibreglassing in Kolkata?
nura is offline   Reply With Quote
Old 5th June 2008, 18:42   #32
shuvd's Avatar
@ Nura - The usual suspects, Glix people told me that they have started fabricating.
shuvd is offline   Reply With Quote
Old 5th June 2008, 18:52   #33
nura's Avatar
That's nice. Thanks, shuvd.
@razor - Any idea about the stock speaker options in the Fusion?
Old 5th June 2008, 19:09   #34
navin's Avatar
Thanked: 4,283 Times
Most Ford cars use 5"x7"
navin is online now   Reply With Quote
Old 5th June 2008, 22:29   #35
shuvc's Avatar
Thanked: 287 Times
Originally Posted by nura View Post
Mohan says there is a waiting period of 3 months for the Dzire.
Checked with my contact there. 3 months is the official statement for both diesel and petrol. It's more of a ballpark lead time. They seem to have no clue. Apparently, Maruti isn't helping matters either.
Old 6th June 2008, 09:48   #36
nura's Avatar
@shuvc - You are absolutely right. Forum members from other cities have been told 6 months.
Old 6th June 2008, 11:43   #37
Most of these claims are just guesses and exaggerated on top of it. There has been no such word from maruti. You never know, tomorrow the production scene might ease off and in a month or so market flooded with dzires.
Nakul Kishan is offline   Reply With Quote
Old 6th June 2008, 12:12   #38
nura's Avatar
One could be forgiven for thinking that Maruti wants it that way.
Old 15th June 2008, 11:02   #39
nura's Avatar
I have almost decided to book a Dzire, but only after the hullabaloo is over.
What I understand is that if I want to install the cone midrange in the door panel, I will need to isolate its back. Will this be like putting the midrange in a sealed enclosure? Will this have any negative impact on the sound quality or the life of the midrange? If so will it be better if I replace the cone midrange with a dome midrange which has a rear chamber?
Really appreciate all the help.
Old 16th June 2008, 00:02   #40
DerAlte's Avatar
Thanked: 2,879 Times
That is a simple thing to do. If you size the MDF mounting ring in such a way that the front of the speaker is flush with the door pad, for all practical purposes the front wave never gets to meet the rear wave. It is quite difficult, if not impossible, to make a sealed box out of the door volume, but the issue is actually isolating the front wave from the rear wave. Check the Getz installation thread by Gunbir, and how LBM has done it for his Swift.
You don't need to replace the cones with a dome mid, since the real problem is at the lowest frequencies that the mid-bass produces.
Old 16th June 2008, 10:19   #41
navin's Avatar
car woofers are designed to be installed in lossy doors.
Old 16th June 2008, 10:30   #42
DerAlte's Avatar
*Abhi samajh mein pada hai* Navin, thanks, your post made me realize the doctor's dilemna about the mid's backside.
Daktar-babu, Navin has achieved the same with a foam cup behind the mid's frame - prevented the low frequencies from affecting the mids. Check out @iraghav's story on Navin's Octavia - there are pics of the same. Will also give you an idea how his sub is mounted in the dicky.
Old 16th June 2008, 10:35   #43
navin's Avatar
Daktar-babu, Navin has achieved the same with a foam cup behind the mid's frame - prevented the low frequencies from affecting the mids. .
actually the foam is open cell foam. it is virtually useless at low frequencies. However it does at as a resistive membrane and in that manner does reduce doppler distortion quite a bit. I have used 2 layers of the open cell foam. It lasts about 3 years before it shows signs of deteriorating.
Old 16th June 2008, 10:45   #44
DerAlte's Avatar
Thanks again, Navin. I guess @nura's concern was the same - reduction of Doppler distortion - for which he wanted to isolate the mid's backside with a sealed box.
Old 17th June 2008, 12:14   #45
nura's Avatar
Yeah, sure
Can you describe, in layman language please, the problem I would face, if I didn't isolate the midrange back?
I tried googling "Doppler Distortion" but it was stirring a hornet's nest
Crutchfield sells foam speaker baffles.
Foam Speaker Baffles at Crutchfield.com
Would these work? Does anyone sell foam speaker baffles in India? Any downside if one installs them?
Thanks in advance.
Help needed to choose my new ride, priced between 12-16lacs hvishwanathan Sedans 50 12th March 2010 19:55
Help me Choose a car from OLD Palio / Uno Diesel & OHC Vicky_s_world Hatchbacks 17 6th May 2009 12:46
Need help to choose an Automatic Transmission hatchback chittybang Hatchbacks 17 28th April 2008 10:38
What would you choose? New Comet or Old 400? manson Superbikes & Imports 69 26th April 2005 04:53
