Old 23rd May 2008, 12:21   #1
esteem_lover's Avatar
Thanked: 451 Times
Angry HELP! - Amplifier switching off
My Sony 4 channel amp switches off after a few minutes. If I switch off the HU & switch it back on immediately, the amp comes to life for 2 seconds & goes to sleep. Sometimes it works for 5-10 minutes before going to sleep again. What could be the issue here ? I have checked the wire from the battery terminal, seems ok.
Old 23rd May 2008, 13:28   #2
redfire's Avatar
Hi EL,
As a basic workaround, check your power cables at both battery and amp end. Also check remote wire (the one used to switch on the amp when HU is turned on) at both HU end and amp end. I am saying this because, during my DIY I have experienced a loose / cut connection once and amp powering off.
redfire is offline   Reply With Quote
Old 23rd May 2008, 13:30   #3
mohang_j's Avatar
Thanked: 18 Times
I think remote signal is having problem or amp is going to protect mode,to confirm you can connect a wire from power supply to remote terminal at the amp with a diode in series and check the amp goes to sleep mode. If it goes sleep amp has some problem otherwise there is some issue with remote.
mohang_j is offline   Reply With Quote
Old 23rd May 2008, 14:17   #4
DerAlte's Avatar
Thanked: 2,880 Times
Thermal protection acting - the amp must be overheating. When you switch off and then on immediately, it works for 2 seconds - but switches off again since it has not cooled down enough.
1. Check if any of the speaker terminals / wires are shorting (with each other or ground; check with multimeter, with amp off)
2. Check air circulation around amp
Old 23rd May 2008, 14:26   #5
Thanked: 451 Times
Thank you guys.
The air circulation is ok since it has been running in that place for more than 2 years now. Amp is installed under the front passenger seat.
I will check with the point no.1, i fear that may be the reason. I hope there would be no damages.
Old 23rd May 2008, 14:58   #6
Thanked: 295 Times
Like Deralte Phaji suggested check the speaker wires. They would be the major culprit in this tripping. Since you have check the power cable. Check the ground cable also. It might have come loose.
There can be a case of dry solder also. If rechecking the wiring does not solve the problem get the amp checked.
Old 23rd May 2008, 15:12   #7
Thanked: 451 Times
I fear the same since i hear some scrappy sound from the components sometimes. The door pad has been opened & refitted quite unprofessionally a couple of times. Thanks
Old 23rd May 2008, 15:52   #8
praveen_v's Avatar
Thanked: 120 Times
There should be some light indicating if the amp goes into the protection mode. If it goes into the protection mode, then it might be the issue with the speaker wires.
If it does not go into protection mode, but switches off(No power), then check
1.Remote wire
2.Power wire
3.Ground wire
in that order.
praveen_v is offline   Reply With Quote
Old 23rd May 2008, 16:18   #9
ECM
ECM's Avatar
Thanked: 9 Times
Do you have a multimeter?If yes do a simple test and check input voltage in Amp.keep a close look at it and see what happens when it switches off,do you see any change in Voltage?Many other things I can write if you know basis electronics else you may totally burnout your blackbox-Let me know if you have basic knowledge(PM me if that is the case).
ECM is offline   Reply With Quote
Old 23rd May 2008, 17:01   #10
jkdas's Avatar
Thanked: 1,436 Times
It was placed underseat and hence maybe rca or speaker wires got look thanks to occasional stamps from passenger or as DerAlte etc said.
Why not DIY and find the cause? one set at a time. Unscrew a speaker and play music and see. Repeat.
Old 23rd May 2008, 17:34   #11
i was also facing the same problem then after all that r n d
if found then one of cell in my battery was weak and the battery was not able to get charge as fast as discharge rate hence battery can bare the load of the amp for small duration.so amp gets switch off when there is no minimum voltage to run the amp.try connecting another battery from your friend car and see, if clicks change the battery.
mabhi10 is offline   Reply With Quote
Old 23rd May 2008, 21:27   #12
blueraven316's Avatar
Even if all connections etc are okay, it sometimes happens to Sony amps, they just give up, so try getting the amp checked by some good technician if everything seems all right in the vehicle.
blueraven316 is offline   Reply With Quote
Old 23rd May 2008, 22:00   #13
its all because or overheating. If all the connections are correct then the amp is gettin old and caps inside of amp needs to be changed!
bmdesai1987 is offline   Reply With Quote
Old 29th May 2008, 14:15   #14
Thanked: 451 Times
Thanks everyone for your inputs. My car seems to have some electrical problem somewhere. My PWs suddenly cease to work & come back after a while, same is the case with the low beam. So i have removed the face plate of my HU & kept it at home until I find time to resolve these issues. Will get an update as soon as I fix them.
cheers
Old 29th May 2008, 21:17   #15
Raxx's Avatar
i am also having the same problem with my jbl gto 75.4, having problem with the fornt components actually the problem is with the amp it suddenly stops working after a trip sound but the rear works fine, after sometime i switch it back again it works fine and also whenever i tried to adjust the gain on the amp a tripping sound comes and the amp front channel stop working after sometime it working fine. please help.
Raxx is offline   Reply With Quote
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Amplifier switching off!! Please Help buntydey In-Car Entertainment 4 16th August 2010 10:45
Why diesel engines are revved before switching ignition off? DCEite Technical Stuff 57 7th May 2008 00:53
Switching off with AC dsinz Technical Stuff 5 13th September 2006 11:51
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
