Old 31st May 2008, 20:04   #1
Default mounting oval speaker in parcel tray of SX$
Dear sir
How to intall 6.9`` rear speaker on parcel tray of SX4,because parcel tray is made up of metal.Or any idea for rich bass?
budrukkar is offline   Reply With Quote
Old 31st May 2008, 21:58   #2
arpandiv's Avatar
Thanked: 27 Times
you will need to install MDF rings to fit 6x9,even then the metal would have to be cut,
you might want to look into buying a amp+sub instead...
arpandiv is offline   Reply With Quote
Old 31st May 2008, 23:28   #3
flipsyde's Avatar
Thanked: 62 Times
i don't see how sub+amp is a replacement for rear ovals. anyway....
MDF rings alone might not give you the best quality sound you'd be better off replacing the entire rear parcel shelf with an MDF board.
or you could look at installing a good set of components in the door and getting a sub+amp. i have heard to this setup against a more conventional rear ovals + sub + amp and the component setup sounded better.
flipsyde is offline   Reply With Quote
Old 1st June 2008, 16:31   #4
arpandiv's Avatar
Thanked: 27 Times
Replies given in bold
he asked for base thats why.
MDF board mounting in SX4 is a tough task,due to the shape of the rear tray+ metal underneath
Getz parcel tray rattling? arunkumar_rec Technical Stuff 14 29th June 2009 21:35
Mounting speakers on Boot tray.. good or bad for tray?? varunghatge Modifications & Accessories 11 5th December 2008 20:07
What is in your Parcel Tray? mhafeez_13666 Shifting gears 22 23rd May 2008 10:13
Parcel/Speaker Tray saintsinner In-Car Entertainment 11 5th December 2007 10:23
Hyundai Getz Parcel Tray Rattling Noise arunkumar_rec Technical Stuff 4 24th August 2007 10:41
