Old 9th June 2008, 18:43   #16
DerAlte's Avatar
Thanked: 2,879 Times
This time around, ask the installer to stick a flat glass-fiber sheet (the type used to cover gates) to the MDF board with Araldite, before cutting the speaker holes. This will prevent the shelf from sagging and cracking. Navin recommends a sandwich of 2 FRP sheets and 12mm marine-grade ply for stiffness in woofer boxes. This should work for your shelf too.
Old 9th June 2008, 19:34   #17
thirst4torque's Avatar
Exactly what was done in my friends car. The end result was quite good and its not a very costly affair as well. I have noticed some installers use a metal pipe like thing along the lenght of the tray from where it is hinged. Not quite sure what pupose it serves. Any idea DerAlte?
thirst4torque is offline   Reply With Quote
Old 10th June 2008, 08:24   #18
Looks like, i should replace my tray with MDF (which i am guessing is of the same plastic material used on doors of cars). and replace front speaker with compos. Can someone please suggest me good compos available (only original nothing grey) and approximate prices of them. Also, would i need to change the cables used to play the system and speakers.
udit78 is offline   Reply With Quote
Old 10th June 2008, 09:30   #19
greenhorn's Avatar
Thanked: 1,516 Times
MDF = medium density fibreboard. commonly known as nuwud/chipboard. its made out of wood
without an amp, the stock cables should be adequate
Old 10th June 2008, 10:42   #20
Cool, that helps, now i know what MDF is. Now, i need to know about the compos for front. Somebody help me.
Old 10th June 2008, 11:01   #21
I believe Wagon R has 4" speaker provisions in the dash. If you don't want to cut the door panels, you can go for Illusion 4" components.
Old 10th June 2008, 11:15   #22
greenhorn's Avatar
illusion 4" components. PM Team-BHP - View Profile: Bass&Trouble
Old 10th June 2008, 11:17   #23
How much would they cost? Illusion 4"
Old 10th June 2008, 11:23   #24
nickoo's Avatar
Thanks mate!!
Will surely bug my installer.
nickoo is offline   Reply With Quote
Old 10th June 2008, 11:24   #25
greenhorn's Avatar
as mentioned previously, 5k. check out the link on his profile for more info
Old 10th June 2008, 11:32   #26
Also Check this thread for reference
http://www.team-bhp.com/forum/sound-...-sounding.html
Old 10th June 2008, 11:38   #27
navin's Avatar
Thanked: 4,282 Times
While what Der Alte recommends will work for the shelf the total of 2 x FRP + 12mm MDf = 18mm. Not much of a saving in thickness. I beileve that 2 sheets of FRP (3mm each) on either side of a 6mm sheet of MDF might be adequately stiff. what it will lack is a bit of damping.
Old 10th June 2008, 13:23   #28
DerAlte's Avatar
Originally Posted by thirst4torque View Post
... I have noticed some installers use a metal pipe like thing along the lenght of the tray from where it is hinged. Not quite sure what pupose it serves. Any idea DerAlte?
The metal pipe is acting as a stiffener on one edge. Alternates are screwing a steel (alu won't do) L- or T-channel to the edge or underside, preferably on both long sides.
Old 17th June 2008, 14:23   #29
Any one knows where can i get genuine Illusions 4 inchers compos for my WagonR in South Delhi?
Old 17th June 2008, 18:03   #30
DerAlte's Avatar
PM @bass&trouble, he should be able to get it couriered to you.
Need your help in adding on to Pio6850 & JBL GTO937 for my OHC KSM-Vtec In-Car Entertainment 28 24th February 2009 10:11
Replace GTO937 with Infinity 6953i? Pioneer Yellow cone TSE6996 johy In-Car Entertainment 4 3rd January 2008 16:21
Blaunpunkt MP27 cost stopOKgo In-Car Entertainment 9 18th December 2007 21:07
blaunpunkt speakers swathyd In-Car Entertainment 22 22nd August 2007 16:52
ICE for a Wagon R. Budget 10K. Sony CDX-GT460U Head unit with JBL speakers parag385 In-Car Entertainment 7 18th May 2007 09:04
