Old 18th June 2008, 09:21   #31
I plan to try out Driven, EOK for this. Hope he has it.
udit78 is offline   Reply With Quote
Old 18th June 2008, 11:48   #32
DerAlte's Avatar
Thanked: 2,879 Times
Unlikely that Driven would have it.
Old 18th June 2008, 18:20   #33
adityamunshi's Avatar
I had to use a plywood shelf because i couldnt get one made of MDF here. It flexes a bit at high volumes and makes a weird grinding sound. This is going to get worse once i get an amp.
Should i use fibre glass sheets as described here or is it better to try and get/make a MDF tray ?
Originally Posted by DerAlte View Post
This time around, ask the installer to stick a flat glass-fiber sheet (the type used to cover gates) to the MDF board with Araldite, before cutting the speaker holes. This will prevent the shelf from sagging and cracking. Navin recommends a sandwich of 2 FRP sheets and 12mm marine-grade ply for stiffness in woofer boxes. This should work for your shelf too.
While what Der Alte recommends will work for the shelf the total of 2 x FRP + 12mm MDf = 18mm. Not much of a saving in thickness. I beileve that 2 sheets of FRP (3mm each) on either side of a 6mm sheet of MDF might be adequately stiff. what it will lack is a bit of damping.
adityamunshi is offline   Reply With Quote
Old 18th June 2008, 19:51   #34
DerAlte's Avatar
Try the FG sheet - your existing investment will not be lost. If you can find the materials, you can do it yourself.
Old 21st June 2008, 11:42   #35
Now PMed Bass@Trouble to check for 4 inch illusion compos. Waiting his reply. Thanks DerAlte.
Need your help in adding on to Pio6850 & JBL GTO937 for my OHC KSM-Vtec In-Car Entertainment 28 24th February 2009 10:11
Replace GTO937 with Infinity 6953i? Pioneer Yellow cone TSE6996 johy In-Car Entertainment 4 3rd January 2008 16:21
Blaunpunkt MP27 cost stopOKgo In-Car Entertainment 9 18th December 2007 21:07
blaunpunkt speakers swathyd In-Car Entertainment 22 22nd August 2007 16:52
ICE for a Wagon R. Budget 10K. Sony CDX-GT460U Head unit with JBL speakers parag385 In-Car Entertainment 7 18th May 2007 09:04
