Old 1st May 2005, 23:18   #16
navin's Avatar
Thanked: 4,253 Times
why not both woofers?
Old 3rd May 2005, 03:17   #17
NSD
audiobahn need a right amp to get the power the quality of sound is better when u use a nice combination 4 it.
NSD is offline   Reply With Quote
Old 24th March 2006, 02:26   #18
buzzin_hornets's Avatar
im usin the audiobahn special edition woofer.. powered by a ProSound 800w 4 chan amp.. in a sealed box with one small vent.. good enuff effect.. although im gonna put it in a ported box now..
buzzin_hornets is offline   Reply With Quote
Old 24th March 2006, 14:02   #19
Bass&Trouble's Avatar
Thanked: 71 Times
What is a ProSound Amplifier? Can't find a reliable link on the web.
The Audiobahn Special Edition sub is quite a rock-star, but you'll need an accurate ported box. They do exceedingly well in sealed enclosures, do you want to take the trouble of venting it? I think the ported enclosure size would be quite huge too.
Old 27th March 2006, 10:48   #20
panky12345's Avatar
Thanked: 147 Times
i bet jbl is better buy that audiobahn, i bought one in US and it soundeed creep, the amp lasted for only 5 mins, and the sound too was HORRIBLE
Old 27th March 2006, 16:32   #21
Thanked: 294 Times
i bet correctly made ported is much better than the sealed on. I am using ported box my self. The seal sound little crappy But the ported is good man
Old 7th September 2008, 17:40   #22
chiragh_bir's Avatar
Thanked: 69 Times
can any one tell from where can we get audiobahn subs in India??
chiragh_bir is offline   Reply With Quote
Old 7th September 2008, 18:17   #23
Magma's Avatar
"boom" in bandra has a few
Magma is offline   Reply With Quote
Old 7th September 2008, 19:53   #24
nitrous's Avatar
Thanked: 285 Times
Hermit Audio distribute Audiobahn products.
Old 8th September 2008, 02:03   #25
Thanked: 7 Times
something a little offtopic, if two subwoofers from two different reputed companies are of same specs, same dimensions in inches, have the same exact rms and peak handling power and same number of coils, same frequency firing band, wouldnt they sound the same and even if not exactly the same almost the same? i know a little difference may be there because of the materials used in building the cone, but wouldnt that be barely noticable if powered from the exact same amp and hu setup
makanaka is offline   Reply With Quote
Old 8th September 2008, 10:54   #26
navin's Avatar
makanaka,
yes and no. if the woofers are firing directly into the cabin you should notice some differnce esp if corssed over slowly or above 200Hz, if the woofers are in the trunk and used purely for bass reinforcement and under 100Hz the differences will not be noticeable. In any case if two woofers had teh same specs (all specs and not just T/S specs) and materials (and wre built to same QC/toleracnes) they'd probably cost the same.
Old 8th September 2008, 10:58   #27
Thanked: 294 Times
NO it is discontinued.
Old 8th September 2008, 11:07   #28
Thanked: 69 Times
any idea about the price sir ?
Old 8th September 2008, 11:38   #29
ramie2400's Avatar
Thanked: 58 Times
It will cost somewhere close to 5k/- approximately
Old 8th September 2008, 13:30   #30
Magma's Avatar
i think thats about right.
however those are entry level ones.(if you are looking at 5000rs budget then GZ MK2 12 incher would be a better choice)
Which sub-woofer for JBL 601.1 Mono? jagrocks7 In-Car Entertainment 19 12th April 2010 12:37
JBL Speakers, Doubel coil woofer, Sony 4 channel amp for sale worrisomebear Shifting gears 10 12th January 2008 14:23
For Sale:JBL active sub-woofer angelfire Shifting gears 1 13th November 2006 14:03
Lancer - Audiobahn Install karthik247 In-Car Entertainment 65 16th August 2006 23:03
Audiobahn Special Edition Woofer buzzin_hornets In-Car Entertainment 2 23rd March 2006 14:11
