Old 15th June 2008, 22:41   #1
abhinav.gupta88's Avatar
Thanked: 310 Times
Question Which Amp for GZ RW 12 XD-AL Sub
Hey people
I have decided for the following sub
GROUND ZERO
GZRW 12 XD-AL
30 cm 500 watts, cast basket, 2 inch 2 x 4ohm, Alucone, woven in leads, Xmax 18mm, SPL 91,4dB
What i wanted to know is that
Is the following amplifier ok to be fitted with this sub without any problems ( low bass or distortions or disturbed bass)
JBL 301.1
  • 204 watts RMS x 1 channel at 4 ohms and ≤ 1% THD + N (BR>
  • 294 watts RMS x 1 channel at 2 ohms & 14.4V supply and ≤ 1% THD + N
  • Signal-to-Noise Ratio: 77 dBA (reference 1 watt into 4 ohms)
  • Dynamic Power: 320 watts at 2 ohms
  • Effective Damping Factor: 6.39 at 4 ohms
  • Frequency Response (3dB): 10Hz - 302Hz
  • Maximum Input Signal: 4.7V
  • Maximum Sensitivity: 220mV
  • Output Regulation: .098 dB at 4 ohms
  • Dimensions (W x H X D): 11-5/8" x 12-5/16" x 2-3/8"
Because My ICe with the 601.1 is going a bit out of budget so have to decide for it.
Please Gurus , Help Me out
Old 15th June 2008, 22:46   #2
navin's Avatar
Thanked: 4,282 Times
Originally Posted by abhinav.gupta88 View Post
..Xmax 18mm, SPL 91,4dB
if the sub is doing 91db/1w/1m it is pretty efficient. at 100W it will be 114db. I am sure this will be more than adequate.
Bass & Trouble represents GZ so it would make sense to PM him.
Old 15th June 2008, 22:53   #3
adityamunshi's Avatar
Navinji, how is this calculation done ?
adityamunshi is offline   Reply With Quote
Old 15th June 2008, 23:10   #4
navin's Avatar
for power it is 20 log P2/P1
Old 15th June 2008, 23:36   #5
Still not getting it, what do we substitute for p1 and p2 ?
Old 16th June 2008, 10:12   #6
navin's Avatar
depends; in this case it is 20 log 100(W)/1(w)
Old 16th June 2008, 11:29   #7
Thanked: 294 Times
There are lots of amp in the market today what is your budget ?
Old 16th June 2008, 11:52   #8
ramie2400's Avatar
Thanked: 58 Times
Hey people
GROUND ZERO
GZRW 12 XD-AL
JBL 301.1
I am using the same GZ 12XD-AL Sub x 2nos. powering up with a 2ohms stable Assembled amp Bridge mode on DVC mode,man its kicka$$ and very loud,i know if i plan to install a 2 x monoblock it can power up more.
As LBM described whats your budget as there are many amps available in the market to power up the subwoofer
Old 16th June 2008, 12:18   #9
Thanked: 310 Times
See The amps Sub will be around 12000
the JBL 75.4, around 8k
illusion components 6490
so my budget now lies around 13500
the 601.1 is a bit higher priced than this.
Old 16th June 2008, 12:18   #10
Thanked: 310 Times
the 75.4 will run the components etc while the 301.1/601.1 will power the sub
Old 16th June 2008, 12:48   #11
Thanked: 294 Times
If you are planning to add only fronts then you can run the sub with a 75.4 only. No need to get another amp.
Old 16th June 2008, 22:31   #12
Thanked: 310 Times
Well actually i was thinking to keep the front ones stock and replace the rear with components and run those along with the front and mids with the 75.4
So want to keep a seperate amp for the Sub
Old 17th June 2008, 00:02   #13
Thanked: 294 Times
If you want to keep the front stock then run them through the HU. And wire the rears and the sub through the 75.4
Old 17th June 2008, 11:23   #14
navin's Avatar
Wont this push the imaging to the rear.
Old 17th June 2008, 12:20   #15
Thanked: 294 Times
Navin Ji he is powering 4 inch full range drivers from 75.4. Which will be over kill for a 4 inch driver thats why I recommended to run it thorough the HU
Which sub/amp to add to existing system? sidharth_j In-Car Entertainment 61 30th April 2010 09:46
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
which sub and amp harry2223 In-Car Entertainment 6 25th June 2008 09:38
Which Sub will get enough power from Sony XM-ZR602 amp !! amit_mechengg In-Car Entertainment 50 13th March 2008 23:38
