Old 21st June 2008, 07:12   #16
BHAGWAN's Avatar
Thanked: 13 Times
Red face
Dude why not use a similar sub to the one in the i10. It is small (the swift does not have much space).
Also I think it is time you investigated FRP. It is stiffer and lighter (less stored energy) there is thread over on diyaudio on enclousre stiffness, damping, weight, etc..
Hello 'N' !
I was keen on a sub like the i-10.
However, this install is not going to be 'as simple' & plane jane looking [I hope]. Thr guys @ boom were keen to spruce the 'look' of the install up. I was not keen on this, but since Zohir is a friend, I gave in.
You have seen most of my work, it is onl functional - I do not believe in good looks and all that.
So now, we are to have the Steg amplifiers mounted on a slanted custom made tray right on the top & the x-over [04 of them] to be on a seperate board & the sub is not yet finalised.
By the way, I have many enclosures that I want to loose.
2 are from an older install - Swift - 12" sealed boxes - concrete loaded - double walled & extensively braced. I will give them away @ Rs. 2.5 K if some one wants them. They should be used in a pair.
Your suggestion for the material for the sub is good. But I have already spent 2 days on this. It will take 2 days more. I am not so sure if I can spare much more time to look into 'new' materials & fabrication etc. SO I am sorry.
This install story will continue. More snaps to follow during the day......
Thanks for looking & commenting !!
BHAGWAN is offline   Reply With Quote
Old 21st June 2008, 07:23   #17
greenhorn's Avatar
Thanked: 1,516 Times
hey B, do you have any more pics of the spare wheel well? what is the cylindrical surface to which the damping has been applied ?
Old 21st June 2008, 07:51   #18
BHAGWAN's Avatar
Thanked: 13 Times
Yes Greenhorn;
I do have more snaps. They are in another computer. Shall post it later, for sure....
I did not follow your question ? cylinder surface ? Can you be a bit more elaborate ? Please...
Old 21st June 2008, 07:58   #19
greenhorn's Avatar
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-sww.jpg
that is what i was asking about. has a custom enclosure been made to cover the rear of the sub, or has the damping been applied to the spare wheel ?
Old 21st June 2008, 08:03   #20
BHAGWAN's Avatar
Thanked: 13 Times
oh oh;
Now I get it.
I have just damped the spare wheel.
The Sub will be in a seperate enclosure.
I want to make it a sealed isobarik enclosure 0.7 cft in size.
Zohir of Boom wants me to make a 'double enclosure' so that both the carbon ND 12 subs from Illusion Audio are visible. This is a dispute - hope to settle it by today - over coffee....
Old 21st June 2008, 11:09   #21
navin's Avatar
Thanked: 4,282 Times
Ishan Tyrewalla Raghava was looking for a sub box. B&T will know more. Ishan is thinking of "going iso" with his sub too.
I assume when Zohir realises that a 3 cu. ft. box (2 x 1.5 cu.ft) will fill the entire boot in the Swift he'll see things your way.
ofcourse there are isobarik topologies that will show both woofers but none are offer the tight couplling of a face to face (push-pull) isobarik.
Old 21st June 2008, 11:15   #22
BHAGWAN's Avatar
Thanked: 13 Times
Thanks Navin - Helpful.
Now, Zohir needs to open his eyes and mind and accept a push - pull isobarik !!
Old 21st June 2008, 11:26   #23
navin's Avatar
If Z still wants to see 2 subs you could make 2 isobarik boxes and use 4 subs. it'll still be only 1.5 cu. ft.
Old 21st June 2008, 13:18   #24
BHAGWAN's Avatar
Thanked: 13 Times
Thumbs down Brilliant Suggestion - I shall send the Bill to Anita !!!
Navin, you are a star.
I will need to buy 4 carbon subs + 2 Stegs etc.
Will write in a bit.
Old 21st June 2008, 13:28   #25
greenhorn's Avatar
just one more doubt. While I understand the merit in damping the spare wheel, will there be any issue- i mean , when you have a flat, will the damping on the spare wheel be a hindrance when you want to install it ?
Old 21st June 2008, 17:01   #26
BHAGWAN's Avatar
Thanked: 13 Times
Thumbs down I did not understand..........Please explain.
Sir,
I did not follow;
What Flat / What hinderance ?
The Wheel Well is getting damped not the spare wheel; So what were you getting @ ?
Old 21st June 2008, 17:19   #27
BHAGWAN's Avatar
Thanked: 13 Times
Lightbulb Pictures - Damping completed.....
The Damping has been completed.
The Cables have been layed.
The Woofers have been soldered into place.
Pictures :-
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-trunk-after-damping-03-laters-21.06.2008.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-carbon-left-front-door-swift-21.06.2008.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-mb-quart-installation-left-rear-door-21.06.2008.jpg
Swift - Diesel - ICE - Steg + MB Quart [Q Line] + Illusion [Carbon].-right-rear-door-after-damping-before-midwoofer.jpg
Old 21st June 2008, 18:22   #28
cooldude1988765's Avatar
Thanked: 108 Times
Equipment and install so far look impressive.
One quick question won't an isobaric box reduce the efficiency of the woofer ?
cooldude1988765 is offline   Reply With Quote
Old 21st June 2008, 18:32   #29
BHAGWAN's Avatar
Thanked: 13 Times
Smile It sure does !!!
Yes Sir.
It sure does. You need double the power for the same output. But the main issue is space. Boot space is precious in a Swift. So it a compromise that is worth it.
My Amp is 2200 Watts @ 1 Ohm. So efficiency is the last of my worries.
Gt-trading - Attivitą
Potenza Stereo RMS @4ohm Watt 155 x 2 Potenza Stereo RMS @2ohm Watt 305 x 2 Potenza Stereo RMS @1ohm Watt 555 x 2 Potenza Mono a ponte RMS @4ohm Watt 615 x 1 Potenza Mono a ponte RMS @2ohm Watt 1110 x 1 Potenza SERIALPOWER RMS @4ohm Watt 2200 x 1
cheers:
Old 21st June 2008, 19:11   #30
greenhorn's Avatar
Thanks for the clarification the first post made me think that you had damped the actual wheel
My Carbon Steel Grey VW Polo 1.5 TDI (Comfort Line) kishore1984 Test-Drives & Initial Ownership Reports 10 2nd October 2016 22:10
ICE from The MB Quart Skoda blueraven316 In-Car Entertainment 21 21st September 2008 06:50
Skoda Superb ICE: Steg/ Illusion Audio/ Alpine Bass&Trouble In-Car Entertainment 56 13th August 2008 15:19
Skoda RS ICE - Re-Done: Carbon + Steg + Ground Zero + Stinger + Optima BHAGWAN In-Car Entertainment 142 4th June 2008 14:53
4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 Bass&Trouble Shifting gears 7 19th March 2008 09:27
